End Item
| 28/09/2022 | 1.0 | Bogomil Pavlov | Initial Version |
| 06.02.23 | 1.1 | Bogomil Pavlov | Split the flow to two separate feeds with and without prices. |
Аfter successful product creation should have Channel Item ID, which for MIRAKL integration is the SKU!
Mapping is the same as Update Stock
"import_id": 2035
