LaRedoute Authentication & Database structure & Limits
| 1.0 | 06/03/2023 | Hristiyan | First publish |
Authentication:
- Log into your Mirakl shop; ( Please contact Bogomil Pavlov or Hristiyan Georgiev )
End point: https://laredoutestg-stg.mirakl.net/api
Limits
GET OR11 - List orders
CALL FREQUENCIES
Recommended:
Maximum:
