Marketplaces / Shopee / SG - Developer account info Shopee SG
SANDBOX:
Date created Access
22.11.2017 1. API documents can be found here: https://partner.uat.shopeemobile.com/docs/
  1. Testing credentials: ◦ ShopID: 205741 ◦ Partner ID: 30001 ◦ Credential Key: 6525cdbd2bd787cb62808e612dbf25023e7e6cad2289df67ab225425cfae37f0
  2. Seller Test Account ◦ Seller Centre (UAT environment): seller.uat.shopee.sg ◦ Seller's store view (UAT environment): https://uat.shopee.sg/ ◦ Account: pentagonuat ◦ PW: 123456
  3. Buyer Test Account ◦ Buyer's store view: https://uat.shopee.sg/ ◦ Account: testbuyeraccount ◦ PW: 123456 ◦ You can use the credit card that has been bound to the account (use 1234 as the OTP)
  4. Notes: ◦ Seller centre and PC view is a single sign on. When doing the test do ensure logout for both side ◦ The buyer account is a common account shared by all. Please use it responsibly |
staging document: https://partner.staging.shopeemobile.com/docs/ partner_id : 1 Shopid (staging): 204878(SG)  204885(ID)  204891(TH)  204889(MY) Secret key(Staging): 9b754aba01a5d719cc70c57782941ae6ff90fcc687282908ee480a364901d181
PRODUCTION:
Date created Access Link Type User name Email
15.11.2017 https://seller.shopee.sg/ Seller dev.wap dev@wearepentagon.com
23.11.2017 https://shopee.sg/ Buyer buyer.wap testbuyer@wearepentagon.com
