End Listing
| Date | Version | Applied changes | |
| 28/09/2022 | 1.0 | Bogomil Pavlov | Initial Version |
| 01/02/2023 | 1.1 | Bogomil Pavlov | Additional Details updated |
"update_delete": "delete"
API Docs: https:///decathlonbelgium-preprod.mirakl.net/help/api-doc/seller/mmp.html#OF01
Mapping is the same as Update Stock
Аfter successful product creation should have Channel Item ID, which for MIRAKL integration is the SKU!
If error, we will have:
<offer_import_tracking>
</offer_import_tracking>
API Docs:https://richemontit3-dev.mirakl.net/help/api-doc/seller/mmp.html#OF02
