Marketplaces / BOL Technical Scope [In Progress] / Order Management / Bol Order Return
Bol Order Return
v1.0 10/05/2023 Bogomil Pavlov First publish
v1.1 17/07/2023 Danail Deltchev General explanations
v1.2 23/08/2023 Bogomil Pavlov Marketplace Feed > Type changed
v1.3 28/08/2023 Bogomil Palov Store error if EAN is missing
v1.4 29/08/2023 Bogomil Palov Store return request only for shipped lines
v1.5 11/09/2023 Bogomil Pavlov Changes in the mapping and the way store claims
v1.6 15/09/2023 Bogomil Pavlov Response mapping changes
<v1.1>Bol do not have the concept of “Refund” (money transaction) that we can use. Everything is handled by a “return” functionality working on a quantity by quantity basis. As for the cancellation we might have a return request initiated by the buyer OR even without any such a return request created by the seller. The below explains how to track and handle the case when a buyer has initiated a return
This flow is to be treated as Hemi Post Shipment Refund flow</v1.1>
The purpose of this document is to describe how we handle returns on Bol marketplace. The returns on Bol are straightforward and we can either Accept or Reject a return. We should be checking if there are new returns (claims) with handled = “false“ only and please note we are storing only handled = “false“ returns and we do not want to download any rejected or accepted returns. If we get the return we need to store it as a claim in Order Claims table in Hemi. Then we have to decide if we want to reject or accept the return request. We can process a return manually or we should have default actions in Account Bol for the Accept and Reject claims which are optional. If we reject the claim there are no any other steps we need to do just update the status of the claim on Bol.
Get Returns
We will be downloading only returns with status handled = “false“ and for the relevant fulfilment-method which is set in Account Bol <v1.5>Please note we will be receiving claims with more than one product and more than one quantity however we want to split the return into different claims based on the products (rmaId). For example if we have a return with two products we want to store two claims in Hemi with one claim row. This way we can refund both products using our refund UI because our relation between refunds and claims is 1-to-1. </v1.5>
API Call: GET https://api.bol.com/retailer/returns
API Docs: https://api.bol.com/retailer/public/redoc/v9/retailer.html#operation/get-returns
Query parameters:
page integer >= 1 Default: 1 The page to get with a page size of 50. Used to go through the pages
handled boolean
The status of the returns you wish to see, shows either handled or unhandled returns. always “false”
fulfilment-method string
Default: "FBR" Enum: "FBR" "FBB" The fulfilment method. Fulfilled by the retailer (FBR) or fulfilled by http://bol.com (FBB). | Account Bol > Fulfilment Method |
Sample Request: https://api.bol.com/retailer/returns?handled=false&fulfilment-method=FBR
Sample Response:
  "returns": [
      "returnId": "1",
      "registrationDateTime": "2016-11-14T11:06:48.423+01:00",
      "fulfilmentMethod": "FBR",
      "returnItems": [
          "rmaId": "31234567",
          "orderId": "4012345678",
          "ean": "9789076174082",
          "expectedQuantity": 1,
          "returnReason": {
            "mainReason": "Niet naar verwachting",
            "detailedReason": "Niet naar verwachting",
            "customerComments": "Lorem Ipsum"
          "handled": false,
Bol Field Hemi Field Comment
returns
returnId
registrationDateTime Order Claim > Marketplace Date
fulfilmentMethod N/A
returnItems
rmaId Order Claim > Marketplace ID <v1.5>Please note that we want to store each rmaID as individual claim.</v1.5>
orderId N/A used to map to which order the claim belongs
ean N/A Used to map the correct Order Claim Row > Order Item Line ID.
We have to map the Product in Order > EAN and get the Order Item Line > ID
<v1.4> Since in Hemi we can make offline refunds we do not want to make any additional validation for storing the Order Claim Rows but we just need to make sure the total returned quantity match the our Order Item Lines. If for some reason there is a discrepancy we want to store an error in Order error table and set Order Claim > Status = **Error <v1.4><v1.3> If the EAN is missing and we ae not able to get the Order Item Line > ID we want to store an error in Order error table and set Order Claim > Status = **Error <v1.3> | | | | expectedQuantity | | N/A | The quantity which need to be returned. Based on this we will know how many Order Item Line Ids to add in Order Claim Row if quantity is > 1 | | | | returnReason | | | | | | | | mainReason | Order Claim > Marketplace Reason | | | | | | detailedReason | N/A | | | | | | customerComments | N/A | | | | | handled | | N/A | Always “false“ |
When we are downloading returns we need to be checking if the default actions are set or we store it with empty Order Claim > Action and Order Claim > Status
Also we want to set the Order Claim > Claim Status = “Created“
Accept Returns
The accepting is simply handling the status of the return. There is couple of ways of accepting a claim it can be set as default or triggered manually.
1 When Default Action is Not selected:
If we would like to manually accept a return we just need to set it as Order Claim > Action = Accept and Order Claim > Status = Pending which will trigger the status update of the claim After success we want to mark the Order Claim > Status = Completed and Order Claim > Claim Status = “Accepted & Refunded” and store the refund row with all the required details. If we receive an error we want to store it in Order Errors table with the relevant error message **and set Order Claim > Status = Error**
2 When default action Is selected as “Accept“:
If we have default action set as Accept with the actual download of the claim we need to set it as Order Claim > Action = Accept and Order Claim > Status = Pending which will trigger the status update of the claim. After success we want to mark the Order Claim > Status = Completed and Order Claim > Claim Status = “Accepted & Refunded”and store the refund row with all the required details. If we receive an error we want to store it in Order Errors table with the relevant error message **and set Order Claim > Status = Error**
API Call: PUT https://api.bol.com/retailer/returns/{rma-id}API Docs: https://api.bol.com/retailer/public/redoc/v9/retailer.html#operation/handle-returnPath parameters
rma-id integer The RMA (Return Merchandise Authorization) identifier of the return.
Request Body
handlingResult string Enum: "RETURN_RECEIVED" "EXCHANGE_PRODUCT" "RETURN_DOES_NOT_MEET_CONDITIONS" "REPAIR_PRODUCT" "CUSTOMER_KEEPS_PRODUCT_PAID" "STILL_APPROVED" The handling result requested by the retailer.
quantityReturned integer [ 1 .. 9999 ]
The quantity of items returned.
handlingResult “RETURN_RECEIVED“ Hardcoded
quantityReturned Based on the Order Claim Rows
*Sample Request:<v1.5>API Call: PUT https://api.bol.com/retailer/returns/{{Order Claim > Marketplace Id}}*</v1.5>
Body Request:
  "handlingResult": "RETURN_RECEIVED",
  "quantityReturned": 1
Sample Response:
  "processStatusId": "1234567",
  "entityId": "987654321",
  "eventType": "HANDLE_RETURN_ITEM",
  "status": "SUCCESS",
  "links": [
      "rel": "self",
      "method": "GET"
The acceptance is asynchronous and we will have to create a new feed in Marketplace Feeds table. After each successfully send feed for order return we will receive the entityId from the response and need to store it in Marketplace Feeds table with the rest of the details as follows.
<v1.6>processStatusId</v1.6> Marketplace Feed > External ID
eventType Marketplace Feed > External Type
Marketplace Feed > Type <v1.2>Hardcoded as “Order Return Accept“</v1.2>
createTimestamp Marketplace Feed > Submitted Date When the feed is submitted
Marketplace Feed > Status If the external status is “PENDING“ we want to set the status as “Processing“.
If the external status is “SUCCESS“ or “FAILURE” or “TIMEOUT” we want to set the status as “Completed“.
status Marketplace Feed > External Status
Based on the response reader afterwards we need to mark the order as “Cancelled“ or leave it with the current status if not fully cancelled. If any errors are returned we want to store them in Order Errors table after the Bol Order Response Reader
As previously mentioned all validations, triggers and updates are as per the validation based on the type of claim we can do here
Reject Returns
The rejecting is simply handling the status of the return.
If we would like to manually trigger a refund we just need to set it as Order Claim > Action = Reject and Order Claim > Status = Pending which will trigger the status update of the claim After success we want to mark the Order Claim > Status = Completed and Order Claim > Claim Status = “Rejected“
2 When default action Is selected as “Reject“:
If we have default action set as Reject with the actual download of the claim we need to set it as Order Claim > Action = Reject and Order Claim > Status = Pending which will trigger the status update of the claim. After success we want to mark the Order Claim > Status = Completed and Order Claim > Claim Status = “Rejected“
Path parameters
Request Body
handlingResult “RETURN_DOES_NOT_MEET_CONDITIONS" Hardcoded
Body Request:
  "handlingResult": "RETURN_DOES_NOT_MEET_CONDITIONS",
Sample Response:
  "eventType": "CREATE_RETURN_ITEM",
  "links": [
      "rel": "self",
      "method": "GET"
The rejection is asynchronous and we will have to create a new feed in Marketplace Feeds table. After each successfully send feed for order ship we will receive the entityId from the response and need to store it in Marketplace Feeds table with the rest of the details as follows.
Marketplace Feed > Type <v1.2>Hardcoded as “Order Return Reject“</v1.2>
