Marketplaces / BOL Technical Scope [In Progress] / Bol Product Management / Bol Delete Offer
Bol Delete Offer
Date Version Created / Updated Notes
10/05/2023 v1.0 Bogomil Pavlov First publish
The purpose of this document is to describe how we delete offer on Bol
The delete request is product per product and the triggers is: Product Account > End Listing = YesProduct Account > Product Status = Product PublishedProduct Account > Channel Item Id != ““
API Call: DEL https://api.bol.com/retailer/offers/{offer-id}API Docs: https://api.bol.com/retailer/public/redoc/v9/retailer.html#tag/Offers/operation/delete-offer
The offer-id is our Product Account > Channel Item ID. The offer price updates are product per productSample Response: There is no body or parameters
Sample Response:
  "processStatusId": "1234567",
  "entityId": "987654321",
  "eventType": "DELETE_OFFER",
  "status": "SUCCESS",
  "links": [
      "rel": "self",
      "method": "GET"
The offer delete is asynchronous and we will have to create a new feed in Marketplace Feeds table. After each successfully sent feed for offer delete we will receive the processStatusIdfrom the response and need to store it in Marketplace Feeds table with the rest of the details as follows.
Bol Field Hemi Field Comment
processStatusId Marketplace Feed > External ID
eventType Marketplace Feed > External Type
Marketplace Feed > Type Hardcoded as “Delete Offer“
createTimestamp Marketplace Feed > Submitted Date When the feed is submitted
Marketplace Feed > Status If the external status is “PENDING“ we want to set the status as “Processing“.
If the external status is “SUCCESS“ or “FAILURE” or “TIMEOUT” we want to set the status as “Completed“.
status Marketplace Feed > External Status
If the offer is deleted successfully we want to mark it as: Product Account > End Listing = NoProduct Account > Product Status = Product RemovedProduct Account > Channel Item Id = ““
If any errors are returned we want to store them in Product In Order > End Listing Error after the Bol Product Response Reader
