SG - Developer account info Qoo10 Singapore
Sandbox: Not available
| Date created | Access Link | Type | User name | |
| Seller/Buyer? | ||||
| Seller/Buyer? |
Production:
| 26.6.2017 | https://my.qoo10.sg/gmkt.inc/Login/Login.aspx | Seller | dev@myhemisphere.com (ID: hemisphere) | dev@myhemisphere.com |
| 3.11.2017 | https://my.qoo10.sg/gmkt.inc/Login/Login.aspx | Buyer | testbuyer@wearepentagon.com | testbuyer@wearepentagon.com |
Note from Qoo10:
"No sandbox testing however, there is no need as you can set your shop/listings’ status to “On Queue”, and things will not be live"
Service fees:
Each seller and buyer account has health indicator and point system ("credits") is used to determine that.
BUYER CREDIT POINTS: SELLER CREDIT POINTS:
