Showroom Prive Taxonomy
| 1.0 | First publish |
API Call:/api/hierarchies
API Docs: {{TBA}}
{{TBA}}
API Docs: {{TBA}}
{{TBA}}
API Call: /api/values_lists
API Docs: {{TBA}}
{{TBA}}
Taxonomy export file
In order to generate the taxonomy file we will need to create a new record in Taxonomy export with: Marketplace = {{TBA}} Status = pending Category for Export = all (or we can specify which exact categories) Email = email to which the file will be send
Please find ore details on the file structure how it should look like after exported here - Taxonomy General requirements .
