Create Products
| 22/11/2022 | 1.0 | Bogomil Pavlov | Initial Version |
Submit Product Package
In order to create a product on Cdiscount we have to generate a JSON payload which contains the product information. After submitting we will receive a packageId which we use with the response reader.
API Call: https://api.octopia-io.net/seller/v2/products-integration
API Doc: https://developer.octopia-io.net/api-details#api=api-rest-seller-v2&operation=post-products
Sample Request:
"products": [{
"attributes": [{
"files": ["https://media.pdf"],
"propertyReference": "24077",
"values": ["Electrique", "Batterie"]
"brand": "My brand",
"categoryCode": "010201",
"description": "My description",
"gtin": "1234567890128",
"gtinReference": "8210987654321",
"sellerPictureUrls": [{
"index": 1,
"url": "https://static.education.francetv.fr/media/img/hd/img.gif"
"sellerProductReference": "AGRA39401",
"title": "My title"
Request Mapping:
Sample Response:
| CDiscount Field | Integration Required | Hemi Field | Comments | ||
products |
attributes |
No | ||||
files |
No | ||||
propertyReference |
No | ||||
values |
No | ||||
brand |
No | ||||
categoryCode |
No | ||||
description |
No | ||||
gtin |
No | ||||
gtinReference |
No | ||||
sellerPictureUrls |
No | ||||
index |
No | ||||
url |
No | ||||
sellerProductReference |
No | ||||
title |
No |
"packageId": "3fa85f64-5717-4562-b3fc-2c963f66afa6"
Response Mapping:
| Cdiscount Field | Hemi Field | Comment |
packageId |
| Marketplace Feed > Type | Hardcoded as “Create Products“ | |
| Marketplace Feed >ZIP Path | The url of the zip | |
| Marketplace Feed >Completed Date | When we process the feed | |
| Marketplace Feed >External Status | External Feed status |
Read Product Package
API Call: GET https://api.octopia-io.net/seller/v2/products-integration-reports[?packageId][>in][&pageIndex][&pageSize][&fields][&sort][&desc]
API Doc: https://developer.octopia-io.net/api-details#api=api-rest-seller-v2&operation=get-product-integration-reports
Request parameters
| Name | Required | Type | Description |
packageId |
true | string |
The package identifier |
gtin |
false | integer |
The gtin |
pageIndex |
false | integer |
The index of the page (Minimum: 1) |
pageSize |
false | number |
The pageSize parameter is a positive integer that allows you to limit the number of items per page. |
fields |
false | string |
The fields to display (By default all fields are displayed) |
sort |
false | string |
The sort parameter allows you to sort the response by the given field(s) which can be multiple and separated by commas. |
desc |
false | string |
The fields used to sort the items in descending order (By default not applied) |
We will be using only the packageId, pageIndex and pageSize
Sample Request: GET https://api.octopia-io.net/seller/v2/products-integration-reports?packageId=878e0c18-97b2-4227-b5fb-fdcbbf748592&pageIndex=1&pageSize=50
Sample Response:
In order to pick a product for creation we must NOT HAVE Product Account > Channel Item ID populated, the relevant flags set and Product Account > Listing Status = Inactive Product Account > Product Status =Product not created Product Account > List / Update the Whole Item = Pending
Once the product is picked for creation and validated against the taxonomy we will have: Product Account > Listing Status = Inactive Product Account > Product Status =Product not created Product Account > List / Update the Whole Item = Sent
When we read the response if successful we will populate the Product Account > Channel Item ID and update the product: Product Account > Listing Status = Inactive Product Account > Product Status =Product created Product Account > List / Update the Whole Item = Pending
When we read the response if error we WONT populate the Product Account > Channel Item ID and update the product: Product Account > Listing Status = Inactive Product Account > Product Status =Product not created Product Account > List / Update the Whole Item = Error With the relevant error message in Product Account > Update Item Error
Limits:
There is a a limit of 200 000 offers in a package but I think in order to have better performance we can set a limit of 50 000 or 100 000 offers per package.
Protect Quantity - We can exclude the quantity from the payload when we are doing updates so we do not add the quantity in the payload when have Protect Quantity raised
Protect Price - We can exclude the price from the payload when we are doing updates so we do not add the price in the payload when have Protect Price raised.
Protect the whole item - We update the quantity only.
