Marketplaces / The Iconic Technical Scope Overview / The Iconic Order Management Technical Scope IN PRO
The Iconic Order Management Technical Scope IN PROGRESS
Get New Orders
After each successful run we create a new record in Last Run Date. If cron runs for first time we look back 9 months. If we have record in Last Run Date we get the date created and revert back 1 hour as overlap
Get Modified Orders
