Marketplaces / Shein / Shein Authorization and Limits
v1.0 11.05.2024 Bogomil Pavlov First publish
v1.1 02.08.2024 Bogomil Pavlov Added language mapping based on country
The purpose of this document is to give good understanding how Hemi will be integrated with new Shein API.
Using the Shein Rest API we will be able to manage orders and products completely from Hemi but before that there is an authentication process. In Hemi we will have separate account for each Shein territory and we should be able to select it in Account Shein. The available countries are:
Country Name Country Code Shein country code <v1.1>Language
Brazil BR shein-br pt-br
Thailand TH shein-th th
United States US shein-us en
Mexico MX shein-mx es
Germany DE shein-de de
France FR shein-fr fr
Spain ES shein-es es
Italy IT shein-it en
Netherlands NL shein-nl en
Poland PL shein-pl en
Portugal PT shein-pt pt-br
Sweden SE shein-se en
United Kingdom GB <v1.1>shein-uk</v1.1> en</v1.1>
Please note we want to show the Country Name and pusht the Shein country code.
Also we need to think for a solution because all errors are in Chinese and they do not bring any value storing them in Hemi thus we need to look for a translation solution.
The whole authorization looks like we have to generate a link which the seller will use to authenticate our application then the seller will be redirected and from the URL we will need to obtain the temporary code. Thus we will have to use our callbacks in order to obtain that temporary code.
Here are the steps of the Authentication:
Then we have to make additional request in order to receive the Secret and API key
  1. The third-party application is spliced to generate an authorization link and jumps to the SHEIN account unified login authentication page.
  2. The seller/supplier completes the main account login authentication and confirms authorization
  3. After the authorization is completed, jump to the redirection address maintained by the third-party application and return the temporary key to the third-party application.
  4. Third-party applications exchange temporary keys for long-term keys
  5. Third-party applications initiate interface calls through long-term key generation signatures
End points:
Production https://openapi.sheincorp.com
Sandbox https://openapi-test01.sheincorp.cn
https:*//openapi-sem.sheincorp.com/#/empower?appid=F9D87342D803BA78E1EE49997162&redirectUrl=aHR0cHM6Ly93d3cuYmFpZHUuY29t&state=AUTH-SHEIN-1624700000000*
Field Is it required? describe use
appid Required Developer application id Authorize applications to specific developers
redirectUrl Required redirect address BASE64 encode Jump back to the redirect address of the third-party application with parameters,BASE64 encode
state Required Developer-defined value Return as is after the jump, used to identify which authorized return it is.
**Credentials:
Production
APP_ID 116F3B227480397C4365326F467CD
APP_Secretkey EB1F5B5D77FE482CAD095018D46E67B6
Sandbox
APP_ID F510417C664448D386E87D47665213D6
APP_Secretkey 1743FEBC5E314E92A63C112EFDF600A3
Signature:
Signature can be generated using the following JS within the request code:
pm.globals.set("url_path", "/open-api/order/order-list");
pm.globals.set("x-lt-openKeyId", "F510417C664448D386E87D47665213D6");
pm.globals.set("secretKey", "1743FEBC5E314E92A63C112EFDF600A3");
pm.globals.set("randomKey", "test0");
pm.globals.set("x-lt-timestamp", (new Date()).getTime().toString());
var key = pm.globals.get("secretKey") + pm.globals.get("randomKey");
var value = pm.globals.get("x-lt-openKeyId") + "&" + pm.globals.get("x-lt-timestamp") + "&" + pm.globals.get("url_path");
var midSignature = (CryptoJS.HmacSHA256(value,key)).toString();
var midUtf8 = CryptoJS.enc.Utf8.parse(midSignature);
var signature = pm.globals.get("randomKey") + CryptoJS.enc.Base64.stringify(midUtf8);
pm.globals.set("signature", signature);
Exchange Temporary code
API Call: POST /open-api/auth/get-by-token API Docs:https://open.sheincorp.com/documents/system/2EB1F5B5D77FE482CAD095018D46E67B6169474d-1d4a-41a9-b9fd-427f63f54a63 Body:
"tempToken": {{the temporary code from the redirect URL}}
Sample request: POST https://openapi.sheincorp.com**/open-api/auth/get-by-token Body:**
    "tempToken": "de723b1c-210b-4ecc-8da4-5f1da6ea0a9b"
Sample response: 200OK
    "code":"0",
    "msg":"success",
    "info":{
        "secretKey":"1743FEBC5E314E92A63C112EFDF600A3",
        "openKeyId":"AA52A169C0BD409D96B7D24BE5315477",
        "appid":"104C19B96F8009DFA721F38186337",
        "state":""
Shein Field Hemi Field Comment
code N/A
msg N/A
info
secretKey Need to be store within the system for future request. Do not expire until we generate a new one
openKeyId Need to be store within the system for future request. Do not expire until we generate a new one
appid N/A
state N/A
If for some reason the authentication is returning an error we want to see the error in the terminal.
Limits:
Request Limit
Get Order List 20 requests per second
Get Order Details 50 requests per second
Get Order Address 50 requests per second
Ship Orders
Stock Update Up to 100 skus in a payload
