Marketplaces / The Iconic Technical Scope Overview / The Iconic Order Management Technical Scope - In p
The Iconic Order Management Technical Scope - In progress - Mimi
The Get Orders call and Get Order Items calls to be incorporated in 1 cron, i.e. to work together because in Hemi we could not download the orders without the items.
Get Orders
The purpose of this document is give detailed description how to download orders for the ‘The Iconic’ marketplace.
We will split orders download into 2 parts: Get New Orders & Get Modified Orders. Get New Orders will look for “Created After“ & “Created Before“, and Modified Orders will look for “Updated After“ and “Updated Before“.
Get New Orders
GET - https://api.sellercenter.net/?Action=GetOrders
Parameters:
Parameter Name Parameter Value Comment Required
Action “GetOrders“ for product remove our action will always be “GetOrders“ Yes
Format “XML“ or “JSON“ both options are available, If not supplied, 'XML' is assumed. No
Timestamp the current time in ISO8601 format relative to UTC e.g., Timestamp=2015-04-01T10:00:00+02:00 for Berlin Yes
UserID Account The Iconic > User ID The ID of the user making the call Yes
Version “2.6.20“ hardcoded the latest available version Yes
Signature Account The Iconic > Signature The cryptographic signature, authenticating the request. A caller must create this value by computing the SHA256 hash of the request, using the API key of the user specified in the UserID parameter Yes
CreatedAfter Date format: YY/MM/DD Limites the returned order list to those created after or on a specified date, given in ISO 8601 date format Yes
CreatedBefore Date format: YY/MM/DD Limites the returned order list to those created before or on a specified date, given in ISO 8601 date format No
Limit “100“ (integer) The maximum number of orders that should be returned, default 100. The value is configurable in config parameter core:api/get_orders/limit Yes
Offset Numer of orders to skip at the beginning of the list (i.e., an offset into the result set; toghether with the Limit parameter, simple resultset paging is possible; if you do page through results, note that the list of orders might change during paging).
TBD: Not listed Status, Sort by & SortDirection - necessary?
Get Modified Orders
Parameters:
UpdatedAfter datetime Limites the returned order list to those updated after or on a specified date, given in ISO 8601 date format Yes
UpdatedBefore datetime Limites the returned order list to those updated before or on a specified date, given in ISO 8601 date format No
Example request:
url = "https://api.sellercenter.net/"
get
data-urlencode Action=GetOrders
data-urlencode CreatedAfter=2014-01-01T00%3A00%3A00%2B0200
data-urlencode CreatedBefore=2014-12-31T23%3A59%3A59%2B0200
data-urlencode Offset=0
data-urlencode Limit=100
data-urlencode Status=pending
data-urlencode Timestamp=2015-07-01T11:11+0000
data-urlencode UserID=maintenance@sellercenter.net
data-urlencode Version=1.0
data-urlencode Signature=d4ff93cccb165295ed8357fe42082208b781a3b576bbb7d3fe7a624270b047b9
Example response ( for Get Orders & Get Modified Orders)
<?xml version="1.0" encoding="UTF-8"?>
<SuccessResponse>
  <Head>
    <RequestId></RequestId>
    <RequestAction>GetOrders</RequestAction>
    <ResponseType>Orders</ResponseType>
    <Timestamp>2013-08-27T14:44:13+0000</Timestamp>
    <TotalCount>15</TotalCount>
  </Head>
  <Body>
    <Orders>
      <Order>
        <OrderId>1</OrderId>
        <CustomerFirstName>John</CustomerFirstName>
        <CustomerLastName>Doe</CustomerLastName>
        <OrderNumber>3000</OrderNumber>
        <PaymentMethod>CashOnDelivery</PaymentMethod>
        <Remarks></Remarks>
        <DeliveryInfo></DeliveryInfo>
        <Price>100.00</Price>
        <GiftOption>0</GiftOption>
        <GiftMessage></GiftMessage>
        <CreatedAt>2013-09-02 02:28:17</CreatedAt>
        <UpdatedAt>2013-09-02 02:28:17</UpdatedAt>
        <AddressBilling>
          <FirstName>John</FirstName>
          <LastName>Doe</LastName>
          <Phone>0123456789</Phone>
          <Phone2></Phone2>
          <Address1>testtestcarmen</Address1>
          <Address2>testtestcarmen</Address2>
          <CustomerEmail>hello@sellercenter.net</CustomerEmail>
          <City>Kuala Lumpur</City>
          <PostCode>12345</PostCode>
          <Country>Germany</Country>
        </AddressBilling>
        <AddressShipping>
          <Phone2></Phone2>
          <PostCode>11111</PostCode>
          <Country>Malaysia</Country>
        </AddressShipping>
        <NationalRegistrationNumber/>
        <ItemsCount>12</ItemsCount>
        <PromisedShippingTime>2015-06-13 17:35:22</PromisedShippingTime>
        <ExtraAttributes>{color:"red", isGift:"true"}</ExtraAttributes>
        <ExchangeForOrderId/>
        <ExchangeByOrderId/>
        <Statuses>
          <Status>shipped</Status>
          <Status>returned</Status>
          <Status>return_waiting_for_approval</Status>
          <Status>return_shipped_by_customer</Status>
          <Status>return_rejected</Status>
          <Status>ready_to_ship</Status>
          <Status>processing</Status>
          <Status>pending</Status>
          <Status>failed</Status>
          <Status>delivered</Status>
          <Status>canceled</Status>
        </Statuses>
      </Order>
    </Orders>
  </Body>
</SuccessResponse>
After each successful run, we create a new record in last Run date. If cron runs for the first time we look back 9 months. If we have record in Last Run date we get the date created and revert 1 hour back as overlap.
The Iconic Field Hemi Field Comment Type Required
1 TotalCount N/A Displayed in the Head section, this number tells the complete number of all orders for the current filter set in the database Unsigned
2 OrderId Orders > Marketplace Order ID Identifier of this order as assigned by SellerCenter. Unsigned Yes
3 CustomerFirstName Orders > Buyer Name The customer's first name String Yes
4 CustomerLastName Orders > Buyer Name The customer's last name String Yes
5 OrderNumber Order The Iconic > Order Number The human-readable order number Unsigned Yes
6 PaymentMethod Order > Order Payment method The method of payment String Yes
7 Remarks N/A A human-readable remark String
8 DeliveryInfo Order > Order type Delivery information for that order String No?
9 Price Order Item > Item Price The total amount for this order. Float Yes
10 GiftOption N/A 1 if item is a gift, 0 if it is not Boolean
11 GiftMessage N/A Gift message as specified b the customer. String
12 CreatedAt Order > Order created time Date and time when the order was placed DateTime Yes
13 UpdatedAt TBD Date and time of last change to the order DateTime Yes
14 AddressBilling Order > Billing Details > Name Node that contains additional nodes, which make up the billing address: FirstName, LastName, Phone, Phone2, Address1, Address2, City, PostCode, Country Subsection No?
15 Order > Billing Details > Country Code No
16 Order > Billing Details > City Name No
17 Order > Billing Details > Billing Street 1 No
18 Order > Billing Details > Billing Street 2 No
19 Order > Billing Details > Country Name No
20 Order > Billing Details > Phone No
21 AddressShipping Order > Shipping Details > Shipping Buyer Name Node that contains additional nodes, which make up the shipping address: FirstName, LastName, Phone, Phone2, Address1, Address2, City, PostCode, Country Subsection Yes
22 Order > Shipping Details > Shipping Postal Code No
23 Order > Shipping Details > Country Name Yes
24 Order > Shipping Details > Shipping City Yes
25 Order > Shipping Details > Shipping Street 1 Yes
26 Order > Shipping Details > Shipping Street 2 No
27 NationalRegistrationNumber N/A? Required in some countries. String
28 ItemsCount Order > Products on Orders Number of items in order. Integer Yes
29 Statuses Orders > Order Status Unique statuses of the items in the order. (hint: you can find all of the different status codes in the response example Array Yes
30 PromisedShippingTime N/A Target shipping time for the soonest order item if they were available DateTime
31 ExtraAttributes N/A Extra attributes which were passed to SellerCenter on getMarketPlaceOrders call.
It is JSON string which client should parse it. String
Statuses:
The Iconic Order Status Hemi Status / Status Comments
1 pending Pending When we have status on “Pending”, it means that something is missing ( payment method for example) or simply we wait for something to happen in order to proceed
2 processing Ready For Shipping
3 ready_to_ship Ready For Shipping Means that order is already fulfilled by the seller
4 shipped Shipped The order was fully shipped.
5 failed Incomplete information missing (example - address fields, no products, no payment info at all when such is expected, etc.)
6 delivered Shipped
7 canceled Cancelled When order is fully canceled.
8 returned Cancelled?
9 return_waiting_for_approval ?
10 return_shipped_by_customer ?
11 return_rejected ?
Errors (The Iconic):
Error code Message
14 E014: "%s" Invalid Offset
17 E017: "%s" Invalid Date Format
19 E019: "%s" Invalid Limit
36 E036: Invalid status filter
74 E074: Invalid sort direction.
75 E075: Invalid sort filter.
We prefer Get Orders & Get Order Items calls to be incorporated in 1 cron, i.e. to work together, because in Hemi we could not download the orders without the items.
Get Order Items
GET- https://api.sellercenter.net/?Action=GetOrderItems
Parameters:
Action “GetOrderItems“ for product remove our action will always be “GetOrderItems“ Yes
OrderId The order identifier that was assigned to the order by SellerCenter Yes
get
data-urlencode Action=GetOrderItems
data-urlencode OrderId=1
Example response:
<SuccessResponse>
  <Head>
    <RequestId/>
    <RequestAction>GetOrderItems</RequestAction>
    <ResponseType>OrderItems</ResponseType>
    <Timestamp>2015-05-29T12:35:54+0200</Timestamp>
  </Head>
  <Body>
    <OrderItems>
      <OrderItem>
        <OrderItemId>1</OrderItemId>
        <ShopId>1</ShopId>
        <Name>Checkmate Contrasted Two Pocket Short Sleeve Check Shirt</Name>
        <Sku>32132132121321321321</Sku>
        <ShopSku>CH650FA84EFZANMY-113840</ShopSku>
        <ShippingType/>
        <ItemPrice>69.00</ItemPrice>
        <PaidPrice>69.00</PaidPrice>
        <Currency>EUR</Currency>
        <WalletCredits>0.00</WalletCredits>
        <TaxAmount>0.00</TaxAmount>
        <ShippingAmount>12.50</ShippingAmount>
        <VoucherAmount>0</VoucherAmount>
        <VoucherCode/>
        <Status/>
        <IsProcessable>1</IsProcessable>
        <ShipmentProvider/>
        <IsDigital>0</IsDigital>
        <DigitalDeliveryInfo/>
        <TrackingCode>7489</TrackingCode>
        <Reason/>
        <ReasonDetail/>
        <PurchaseOrderId>72587</PurchaseOrderId>
        <PurchaseOrderNumber>MPDS-D1405061201</PurchaseOrderNumber>
        <PackageId/>
        <PromisedShippingTimes>2015-05-26 10:29:03</PromisedShippingTimes>
        <ShippingProviderType/>
        <CreatedAt>2015-05-26 10:21:13</CreatedAt>
        <UpdatedAt>2015-05-26 11:55:53</UpdatedAt>
        <ReturnStatus />
        <Vouchers /> // only populated, when enabled in Seller Center
        <ShippingVoucher>3.96</ShippingVoucher>
        <WarehouseName/>
        <StoreCredits>0.00</StoreCredit>
      </OrderItem>
      <OrderItem>
        <OrderItemId>6</OrderItemId>
        <ShopId>6</ShopId>
        <ShippingType/>
        <VoucherCode/>
        <Status/>
        <ShipmentProvider/>
        <IsDigital>1</IsDigital>
        <DigitalDeliveryInfo>+00123456789</DigitalDeliveryInfo>
        <TrackingCode>12321</TrackingCode>
        <Reason/>
        <ReasonDetail/>
        <PackageId/>
        <ShippingProviderType>express<ShippingProviderType/>
        <CreatedAt>2015-05-26 10:29:03</CreatedAt>
        <UpdatedAt>2015-05-26 11:44:26</UpdatedAt>
        <ReturnStatus />
        <Vouchers> // only populated, when enabled in Seller Center
            <Voucher>
              <Code>AAAA</Code>
              <Amount>10.5</Amount>
              <AmountFundedBySeller>10.5</AmountFundedBySeller>
            </Voucher>
            <Voucher>
              <Code>BBBB</Code>
              <Amount>15.2</Amount>
              <AmountFundedBySeller>7.6</AmountFundedBySeller>
            </Voucher>
        </Vouchers>
          <ShippingVoucher>0</ShippingVoucher>
          <WarehouseName>warehouse_1</WarehouseName>
      </OrderItem>
      <OrderItem>
        <OrderItemId>7</OrderItemId>
        <ShopId>7</ShopId>
        <ShippingType/>
        <VoucherCode/>
        <Status/>
        <ShipmentProvider/>
        <Reason/>
        <ReasonDetail/>
        <PackageId/>
        <ShippingProviderType>standard<ShippingProviderType/>
        <ExtraAttributes>[]</ExtraAttributes>
        <ReturnStatus />
           <Voucher>
              <Code>ABCD</Code>
              <Amount>50</Amount>
              <AmountFundedBySeller>25.0</AmountFundedBySeller>
           </Voucher>
           <Voucher>
              <Code>CCXC</Code>
              <Amount>0.4</Amount>
              <AmountFundedBySeller>0.2</AmountFundedBySeller>
          </Voucher>
        </Vouchers>
        <ShippingVoucher>1.02</ShippingVoucher>
        <WarehouseName/>
      </OrderItem>
    </OrderItems>
  </Body>
</SuccessResponse>
OrderItemId Order > Product in Order > Item Order Line ID an ID on each product
ShopId N/A
OrderId Orders > Marketplace Order ID The order identifier that was assigned to the order by SellerCente
Name Order > Product in Order > Item Title
Sku Order > Product in Order > SKU
ShopSku N/A
ShippingType ?
ItemPrice Order > Product in Order > Item Price
PaidPrice N/A
Currency Order > Order Currency
WalletCredits N/A
TaxAmount Order > Taxes and Fees > Total Tax Ammount
ShippingAmount Order > Shipping > Shipping Service Cost
VoucherAmount N/A
VoucherCode N/A
IsProcessable N/A
ShipmentProvider Order > Shipping Details > Shipping carrier?
IsDigital Order > Shipping Details >Shipping Service?
DigitalDeliveryInfo N/A
TrackingCode Orders > Shipping Details > Shipping Track Num
Reason N/A
ReasonDetail N/A
PurchaseOrderId ?
PurchaseOrderNumber ?
PackageId ?
PromisedShippingTimes ?
ShippingProviderType Order > Shipping details > ?
ExtraAttributes ?
UpdatedAt Order > Order created time?
ReturnStatus ?
Vouchers ?
ShippingVoucher ?
WarehouseName ?
StoreCredits ?
ExchangeForOrderId ?
ExchangeByOrderId ?
