Laredoute Offer Stock Update
| 07/03/2023 | 1.0 | Hristiyan | First Publish |
API Docs: https://laredoutestg-stg.mirakl.net/help/api-doc/seller/mmp.html#OF01
sku |
product-id |
Product > EAN | Product Account > Marketplace EAN is with priority |
| product-id-type | | Yes | hardcoded as “EAN“ | |
The accepted values are defined from the Mirakl back office | Required | see notes | Mapping to our conditions:
11- New > 1000; |
"import_id": 2035
API Docs: https://laredoutestg-stg.mirakl.net/help/api-doc/seller/mmp.html#OF02
API Docs: https://laredoutestg-stg.mirakl.net/help/api-doc/seller/mmp.html#OF03
Protect Quantity (Stop all quantity updates) If Protect Quantity = Yes and Update Quantity = Pending - We skip the product
Closed -will stop all the updates to the MPs.
