Marketplaces / Inno Technical Scope [DRAFT] / Inno Product & Offer management / Inno Offer Price Update
1.0 09/12/2022 Hristiyan Georgiev First Publish
API Docs:https://galeriainnobe2-dev.mirakl.net/help/api-doc/seller/mmp.html?#OF01
product-id Unique product identifier for a given product-id-type - Required at offer creation - Maximum 40 characters Yes Product >EAN
product-id-type Yes hardcoded as “ean“ If we have ean populated we hardcoded the type as “ean“
price The selling price in the currency.
It is up to the operator to define with the seller whether the selling price includes or excludes taxes. Decimal number; a period is used to separate cents | Yes | Product Account > Price OR Product Account> RRP | We send Product Account > RRP If RRP is populated and is bigger than Price | | min-quantity-alert | | | N/A | | | state | The state code of the offer The accepted values are defined from the Mirakl back office | Required | see notes | Mapping to our conditions: 11- New > 1000; 1-Excellent > 1500; 2-Very Good >4000; 3-Good >5000; 4-Sufficient >6000; 5-Refurbished_like_new > 2750 6-Refurnished_very_good >2500 7-Refurbished_good > 2000 8-Refurbished_acceptable > New state(condition) to be created in Hemi (8000) | | discount-price | | No | Product Account > Price | If RRP > Price
  2. If there are no dates imported in Hemi we use the default dates (Now) and (Now + 2y) If RRP < Price 3.We do not include the discount fields. (price,start-date,end-date) | | discount-start-date | | No | Product Account Inno > Discount End Date | If we do not specify any dates in the relevant fields we hardcoded current date (“NOW“) Date format - 2012-12-25 | | discount-end-date | | No | Product Account Inno > Discount End Date | If we do not specify any dates in the relevant fields we hardcode current date + 2 year (“NOW“ +2y) Date format - 2012-12-25 |
<offer_import_tracking>
</offer_import_tracking>
Marketplace Feed > Type Hardcoded as “Offer Stock Price Update“
API Docs: https://galeriainnobe2-dev.mirakl.net/help/api-doc/seller/mmp.html?#OF02
import Import identifier Yes
Error case: If "has_error_report": true this means there is an error and we need to reach each of the reports in order to check for which item and what is the error.
API Docs:https://galeriainnobe2-dev.mirakl.net/help/api-doc/seller/mmp.html?#OF03
Protect Quantity - We can exclude the quantity from the payload when we are doing updates.
Protect Price - This call should not go through if there is protect price, as there will be nothing to update.
Protect the whole item - We update the quantity only.
