ASOS - Authentication
The purpose of this page is to describe in details the authentication process on MIRAKL.
The whole authentication is happening with API key generated directly from the seller account on MIRAKL. We will need to use this API key as a Authorization header.
End Point: https://asosuk-dev.mirakl.net/api/ If you need the API key please contact Bogomil Pavlov or Maria Mitreva (Unlicensed)
