NordStrom Offer Stock Update
sku |
product-id |
Product > EAN | |
| product-id-type | | Yes | Hardcoded as “ean“ | Must be lowercase |
The accepted values are defined from the Mirakl back office | Yes | Product > Condition | Mapping to our conditions:
11- New > 1000;
15- Vintage> 1500; |
"import_id": 2035
Protect Quantity (Stop all quantity updates) If Protect Quantity = Yes and Update Quantity = Pending - We skip the product
Closed -will stop all the updates to the MPs.
