Afound Technical Scope
Authentication is set directly in TB.One. As TradeByte is our partner so we are integrating with TB and they have integration with Afound.
| channel name | channel abbreviation | channel id |
| Afound | afnd | 245 |
Afound provide a sandbox where we can test the integration. Provide your product data in English..
Clarify with the channel which brands you want to use and provide brand logos/keys to the channel if necessary.
Automatic changes by means of the API are no longer possible once the channel registered your products. You need to contact Afound.com directly to request an update.
Don't activate products for the channel if they do not use size AND colour as variant dimensions. Exceptions must be agreed upon with your Integration Manager.
Product flows
Product Specifications:
The following specifications apply for Afound.com:
- Brand: mandatory - (After you have agreed on the brands with the channel, Afound.com will provide a brand list, to which you have to assign your brands at "Basic data > Properties > Brands".)
- Designation/Common noun and proper name: via title configuration
- Special text: not used
- Description: no restrictions - (Afound.com does not limit the length of the description text.)
- Search terms: not used
- Bullet points: not used
- Components: colour, size, material, care instructions Components may be directly published on a channel in most cases. They are directly promotional so choose meaningful designations and values. Assign only those components to the product which are not used for variant creation. Variant dimensions (e.g. colour) are entered on the tab "Article list " and must not be assigned twice. Recommended default components are (if applicable for your assortment): Colour (often variant forming) Size (often variant forming), maybe additionally length, width, height and/or dimensions Material (regard Textile Labeling Regulation!), maybe additionally separated in upper material, inner material etc. Heel height, heel form a.s.
- Attributes: gender, pattern, country of origin, height, length, length unit, quantity, quantity unit, weight unit. Attributes are usually not visible for end customers and are only used for mapping purposes or as an element of a title profile. Attributes are often used for filter functions in the shops. Missing attribute values must be added to the value list in "Basic data > Properties > Attributes". Recommended standard attributes are (if applicable for your assortment): Season Target group (age and gender mixed, e.g. gents, ladies, boys, girls) Age group (e.g. adult, child, baby) Gender (male, female, unisex) Occasion (e.g. business, festive, leisure)
- Media - Number: 1-5 pictures, Still life or model, Background white to light grey, Aspect ratio: 1:1, max. 14 MB, Size: min. 1920 px, Resolution: 72 dpi, File format: JPG, JPEG or PNG, Consult the channel's image guide!
Following requirements are valid for the variant creation at Afound.com: you may only list products if they create variants via size AND colour.
Orders flows
The following requirements are valid for Afound.com: Pending orders possible Partial cancellations and partial deliveries on article level Carrier: free, with Tracking URL Delivery slips in package: delivery note Returns: partial reimbursement only via channel
Afound.com puts great emphasis on the uniformity of the delivery notes. Therefore, you should make a test print that has to be checked and approved by Afound.com. If you don't want to use the delivery notes that are stored in TB.One, you will need to obtain the channel's approval for the delivery notes created by your system.
Afound.com doesn't support the partial deduction of reimbursements at faulty return state. So if you have complaints regarding the condition of the returned goods, please contact the consultant at the channel.
