Marketplaces / NordStrom Technical Scope / NordStrom Product & Offer management / NordStrom Offer Price Update
v1.0 29.05.2025 Bogomil First publish
API Docs:https://help.mirakl.net/help/api-doc/seller/mmp.html#OF01
product-id Unique product identifier for a given product-id-type - Required at offer creation - Maximum 40 characters Yes Product Account > Marketplace EAN
OR Product >EAN | Product Account > Marketplace EAN is with priority | | product-id-type | | Yes | hardcoded as “ean“ | Must be lowercase | | price | The selling price in the currency. It is up to the operator to define with the seller whether the selling price includes or excludes taxes. Decimal number; a period is used to separate cents | Yes | Product Account > Price OR Product Account> RRP | We send Product Account > RRP If RRP is populated and is bigger than Price | | min-quantity-alert | | | N/A | | | state | The state code of the offer The accepted values are defined from the Mirakl back office | Yes | Product > Condition | Mapping to our conditions:
11- New > 1000; 1- Vintage> 1500; | | discount-price | | No | Product Account > Price | If RRP > Price
  2. If there are no dates imported in Hemi we use the default dates (Now) and (Now + 2y) If RRP <= Price 3.We include the discount fields with empty values | | discount-start-date | | No | Product Account BestBuy> Discount Start Date | If RRP > Price and If we do not specify any dates in the relevant fields we hardcoded current date (“NOW“) Date format - 2017-02-20T10:45:53+01 If RRP <= Price We include the discount fields with empty values | | discount-end-date | | No | Product Account BestBuy> Discount End Date | If RRP > Price and If we do not specify any dates in the relevant fields we hardcode current date + 2 year (“NOW“ +2y) Date format - 2017-02-20T10:45:53+01 If RRP <= Price We include the discount fields with empty values |
<offer_import_tracking>
</offer_import_tracking>
import Import identifier Yes
    <herror_report>false</error_report>
Error case: If "error_report": true this means there is an error and we need to reach each of the reports in order to check for which item and what is the error.
Protect Price (Stop all price updates) If Protect Price = Yes and Update Price= Pending - We skip the product
Protect the whole item - (Stop all product updates apart from Quantity) If Protect the whole item = Yes and Update Price= Pending - We skip the whole variation
