Real D Technical Scope
Authentication is set directly in TB.One. As TradeByte is our partner so we are integrating with TB and they have integration with Real D Germany.
| channel name | channel abbreviation | channel id |
| real SMS | hide | 179 |
Product flows
What you should do?
- Clarify with the channel, which brands you want to use and provide brand logos/keys to the channel if necessary. If you use the brand control in the TB.One basic data, it is mandatory to fill in the assignment fields for all brands.
- Check your settings for storage facility, export rate, stock reduction and maximum stock as well as delivery times in the menu "Basic data > Storage> Warehouse settings"
- Indicate a minimum price and/or a maximum price reduction in "Admin > Export > Channels" if necessary.
- For articles that legally require a base price, the base price is also mandatory for Real.de SMS. Check at "Basic data > Prices > Units" if all units you need are present, create them if they aren't. Add the according Real.de SMS keys. If you've created new units, don't forget to configure them at "Basic data > Prices > Base prices" so that TB.One can perform valid calculations during export.
- Provide your product data in German. If there is no product data in these languages yet, you need to create it in "Articles > Translation> Language" and deliver the appropriate translation later. A separate manual is available for the so-called translation desktop in TB.One (No.8016). If a data import is used for product maintenance, an import-key should be defined and mapped in your leading ERP-system immediately. Your Integration Manager then simply needs to be informed, which standard and alternative language should be used for the new channel.
- Create your API access credentials in your merchant account in the back-end of Real.de SMS and pass them on to your Integration Manager at Tradebyte. In addition to that you will receive further SMS API login data during your process negotiation agreements. Please send these to the Integration Manager, too.
What you shouldn't do?
- Don't try to sell articles that are forbidden by the T&C of the channel.
- Do not change the API access data without consulting your contact at Tradebyte first.
Set the value "Sonstige" for products without brand.
For Real.de SMS, the product title provided by means of the title profile is put together from brand, designation, size, colour and manufacturers article number. Technically, the length of the title isl imited to 512 characters. For an improved reading experience of the customers you should keep the product title significantly shorter.
Bullet points Bullet points serve for the fast orientation of the customer in the shop. Choose particular properties and notes that you didn't store as components. Usually, you create a list of three to eight highlights for each product. A bullet point should not exceed 5 words as this is the average number of words one can capture at a glance.
**Real.de SMS has no variant creation. The variants maintained in TB.One are split and are transferred to the channel as single products.**
Please note that EAN-Codes(13-digit) must be absolutely unique. Within one account, multiple identical codes are not permitted. The validity of the provided EANs is checked, so valid EAN check digits are essential.
Orders flows
Together with the dispatch advice, you must use the field "Comment" (XML node or, respectively, CSV field "COMMENT" in the DESADV file) to transfer a delivery note number to the channel. There is no format requirement for that number but it is important that it must also be listed on the goods invoice to Real.de SMS. This number is used to connect the order/delivery with the invoice in the accounting control. Real.de SMS normally handles it as "1 delivery note number = 1 delivery note". With collective invoices you may also combine several deliveries to one channel invoice
At
SMS the choice of the carrier is yours.
You don't need to create invoices for Real.de SMS, they are sent by the channel.
You must NOT add invoices to the packages!
What are the main differences between Real D and Zalando:
Bullet points are now available and can be pushed to TB.One. Description is displayed on the Marketplace. Title is provided from the product profile within TB.One. There are no variation groups on Real D. There is no specific carriers for Real D and we can ship with any carrier. Invoices are sent by the channel. First picture should be cropped-out.
