Inno Create Products
| Version | Date | Created/Updated | Applied changes |
| 1.0 | 08/12/2022 | Hristiyan Georgiev | First Publish |
The purpose of this document is to give detailed description of the flow of creating product.
In order to create a product we will need to make couple of API Calls, which are POST P41 (Import products to the operator information system), GET P42 (Get the import status for a product import), GET P44 (Get the error report file for a product import), GET P47 (Get the transformation error report file for a product import)
- If we DO NOT HAVE Product Account > Variation Group: We use only the Item Specifics from the product if any Variation Specifics are also populated we ignore them
- If we HAVE Product Account > Variation Group: We use all of the Variation Specifics and all of the Item Specifics. If there are no Variation Specifics we should return an error. If we have the same attribute added as a Variation Specific and as a Item Specific we pick it only from the Variation Specifics.
Please note we do not need to select all variants if only of one them is set for revision or creation because they go as separate products on MIRAKL and the only thing which associate them is the variantGroupCode
So we can add variants to a variation group only by specifying the correct variantGroupCode
If we want to remove a product from a variation we need to push the product for update again without the variantGroupCode
API Docs: https://galeriainnobe2-dev.mirakl.net/help/api-doc/seller/mmp.html#P41
Complete flow:
If we receive success after performing P42 (when we send product to MIRAKL & When both "has_error_report" and "has_transformation_error_report" are equal to “false“ ) we can proceed to following:
There will be two cases how to handle channel item ids in MIRAKL depends on the type.
- The first case is after successful product creation we need to fill the Channel Item ID, which will be the SKU.
- The second case is to use P31 Get products for a list of product references which will map the SKUs between Hemi and MIRAKL and store the MIRAKL id as Channel Item ID.
For INNO integration we will go for first option so we wont need to make P31
If we receive an error (any of "has_error_report" and "has_transformation_error_report" are equal to “true“):
Yes |
| No |
Example File:
women-beauty-faceAndEyeCare-example.xml
<products>
<product>
<attribute>
<code>category</code>
<value>women-beauty-faceAndEyeCare</value>
</attribute>
<attribute>
<code>shopSKU</code>
<value/>
</attribute>
<attribute>
<code>name [nl_BE]</code>
<value/>
</attribute>
<attribute>
<code>EAN</code>
<value/>
</attribute>
<attribute>
<code>variantGroupCode</code>
<value/>
</attribute>
<attribute>
<code>image_2</code>
<value/>
</attribute>
<attribute>
<code>variant_image_1</code>
<value/>
</attribute>
<attribute>
<code>image_3</code>
<value/>
</attribute>
<attribute>
<code>image_4</code>
<value/>
</attribute>
<attribute>
<code>image_5</code>
<value/>
</attribute>
<attribute>
<code>productDepthUnit</code>
<value/>
</attribute>
<attribute>
<code>productDiameterValue</code>
<value/>
</attribute>
<attribute>
<code>productWidthValue</code>
<value/>
</attribute>
<attribute>
<code>productHeightUnit</code>
<value/>
</attribute>
<attribute>
<code>productWidthUnit</code>
<value/>
</attribute>
<attribute>
<code>productLengthValue</code>
<value/>
</attribute>
<attribute>
<code>productDiameterUnit</code>
<value/>
</attribute>
<attribute>
<code>productHeightValue</code>
<value/>
</attribute>
<attribute>
<code>productWeightUnit</code>
<value/>
</attribute>
<attribute>
<code>productWeightValue</code>
<value/>
</attribute>
<attribute>
<code>productLengthUnit</code>
<value/>
</attribute>
<attribute>
<code>productDepthValue</code>
<value/>
</attribute>
<attribute>
<code>brands</code>
<value/>
</attribute>
<attribute>
<code>name [fr_BE]</code>
<value/>
</attribute>
<attribute>
<code>image_1</code>
<value/>
</attribute>
<attribute>
<code>color</code>
<value/>
</attribute>
<attribute>
<code>subbrands</code>
<value/>
</attribute>
<attribute>
<code>otherColor [nl_BE]</code>
<value/>
</attribute>
<attribute>
<code>otherColor [fr_BE]</code>
<value/>
</attribute>
<attribute>
<code>shortDescription [nl_BE]</code>
<value/>
</attribute>
<attribute>
<code>shortDescription [fr_BE]</code>
<value/>
</attribute>
<attribute>
<code>longDescription [nl_BE]</code>
<value/>
</attribute>
<attribute>
<code>longDescription [fr_BE]</code>
<value/>
</attribute>
<attribute>
<code>collection</code>
<value/>
</attribute>
<attribute>
<code>seasonal</code>
<value/>
</attribute>
<attribute>
<code>series</code>
<value/>
</attribute>
<attribute>
<code>ingredients</code>
<value/>
</attribute>
<attribute>
<code>formatBeauty</code>
<value/>
</attribute>
<attribute>
<code>content</code>
<value/>
</attribute>
</product>
</products>
category |
The product category | Yes | Product Account > Primary Category ID | |
shopSKU |
The shop sku | Yes | Product > SKU | |
name [nl_BE] |
Product title | Yes | Product Account > Title | |
EAN |
Unique product barcode | Yes | Product Account > Marketplace EAN |
Product > EAN | If we do not have EAN filled, we should display an error ( EAN is required and we could not proceed to product creation without EAN)
Product Account > Marketplace EAN is with priority |
| variantGroupCode | The variant group code | No | Product Account > Variation Group | |
| image_1 | One of the image url used to retrieve the image from Mirakl | Yes | Product Account Inno> Main Image
Product > Main Image | Product Account Inno is with priority. |
| image_2 | One of the image url used to retrieve the image from Mirakl | No | Product Account Inno> More Images
Product > More Picture URLs | Inno Specifics.
| image_3 | One of the image url used to retrieve the image from Mirakl | No | Product Account Inno> More Images
| image_4 | One of the image url used to retrieve the image from Mirakl | No | Product Account Inno> More Images
| image_5 | One of the image url used to retrieve the image from Mirakl | No | Product Account Inno> More Images
| productWidthValue | Width of the product | No | Product > Width | |
| productWidthUnit | Unit of the width | No | Hardcoded as ‘cm’ | Accepted values by Inno are mm, cm, dm, m. Per standard we will be sending them in cm |
| productHeightValue | Height of the product | No | Product > Height | |
| productHeightUnit | Unit of the height | No | Hardcoded as ‘cm’ | Accepted values by Inno are mm, cm, dm, m. Per standard we will be sending them in cm |
| productWeightValue | Weight of the product | No | Product > Weight | |
| productWeightUnit | Unit of the weight | No | Hardcoded as ‘gr’ | Accepted values by Inno are gr, kg, gr/m². Per standard we will be sending them in gr |
| productLengthValue | Length of the product | No | Product > Length | |
| productLengthUnit | Unit of the length | No | Hardcoded as ‘cm’ | Accepted values by Inno are mm, cm, dm, m. Per standard we will be sending them in cm |
| brands | Brand of the product | Yes | Product Account> Item specifics
Product > Brand | Product Account > Item Specifics is with priority |
| color | Color of the product | Yes | Product Account> Item specifics | |
| subbrands | | No | Product Account> Item specifics | Inno Specifics |
| otherColor [nl_BE] | Other color | No | Product Account> Item specifics | Inno Specifics |
| longDescription [nl_BE] | Product description | No | Product Account > Description | Inno Specifics |
| collection | Product collection | No | Product Account> Item specifics | Inno Specifics |
| series | Product series | No | Product Account> Item specifics | Inno Specifics |
<product_import_tracking>
</product_import_tracking>
API Docs: https://galeriainnobe2-dev.mirakl.net/help/api-doc/seller/mmp.html?#P42
Example response:
<import_id>2005</import_id>
<has_transformation_error_report>false</has_transformation_error_report>
<shop_id>2000</shop_id>
Depends on the response of:
"has_error_report" and "has_transformation_error_report" we will need to call each of the error reports if we receive "true".
When both "has_error_report" and "has_transformation_error_report" are equal to “false“ is the success case (Import status = Completed) and we could proceed to creating and offer to this product.
If we receive success (When both "has_error_report" and "has_transformation_error_report" are equal to “false“ ) we can proceed to following:
We need to perform this call if we receive has_error_report = true, into the response from P42;
API Docs: https://galeriainnobe2-dev.mirakl.net/help/api-doc/seller/mmp.html?#P44
Sample file
This call returns if the import is successful and how may warnings and errors we have in the file. We need to call this if we receive has_transformation_error_report = true
API Docs: https://galeriainnobe2-dev.mirakl.net/help/api-doc/seller/mmp.html?#P47
Sample file -
- GET P31 - Get products for a list of product references
API Call: /api/productsAPI Docs:https://galeriainnobe2-dev.mirakl.net/help/api-doc/seller/mmp.html?#P31
Sample Request: API call: GET https://galeriainnobe2-dev.mirakl.net/api/products?product_references=EAN|1234567899876 We will be using the EAN in order to obtain the product Ids. Please note we can specify many product_references in single request like:https://galeriainnobe2-dev.mirakl.net/api/products?product_references=EAN|1234567899876,EAN|1234567899877,EAN|1234567899878,EAN|1234567899879
Samples Response:
<?xml version="1.0" encoding="UTF-8" standalone="yes" ?> <body> <total_count>1</total_count> <products> <product> <category_code>5110114</category_code> <category_label>Coffee Machines</category_label> <product_id>9312432012041</product_id> <product_id_type>EAN</product_id_type> <product_sku>MKP100000000037254</product_sku> <product_title>Breville Cafe Roma Stainless Espresso/Cappuccino Machine-ESP8C</product_title> </product> </products> </body>From the response we get the product_id and store it as Product Account > Channel Item ID.
Protect Quantity - We can exclude the quantity from the payload when we are doing updates so we do not add the quantity in the payload when have Protect Quantity raised
Protect Price - If we raise Protect Price flag, we would need sent to the MP last updated price, because into the offer is mandatory to send price. Last updated price - the last successfully sent to the MP price. If we successfully have updated the price we need to store Product Account > lastSuccessfulPriceSentValue and Product Account > lastSuccessfulPriceSentTime.
Protect the whole item - We update the quantity only but because we CANNOT exclude the price from the payload we will use again the Item Account > lastSuccessfulPriceSentValue
