Argos Orders Read FTP
| Date | Version | Author | Comment |
| 27.02.2024 | v1.0 | Bogomil Pavlov | First Publish |
| 15.03.2024 | v1.1 | Bogomil Pavlov | Add mapping for cost price |
| 19.03.2024 | v1.2 | Bogomil Pavlov | Order Item Name and Description mapping |
| 27.05.2024 | v1.3 | Hristiyan Georgiev | mapping changes + shipping city logic |
| 15.07.2024 | v1.4 | Milen Markov | Added a logic to filter products by promised_date |
The purpose of this document is to detail the read of orders from Argos and all accompanying functions to ensure seamless and sameness in the process of management on Marketplaces
The Edge will be exporting each order in a separate file that we have to read and store in Hemi. Each order will be in a txt file on the designated FTP folder and we should only read said order when we find the same file name with a “.DONE” extension at the end. We are not to read the .DONE file but use it only to acknowledge the original file is actually competed and can be processed.
Standard Order Filename Format: order-yyyymmddhhmmssnnnnnn.txt
Standard Folder structure: /live/incoming/ (for testing /uat structure will be used)
Ftp Path Label for the setting: OrderDownload
File format is slightly odd - there are two sets of headers: On line 1 there will always be the headers for the order main section. line 2 will be the values for the Order itself. Line 3 contains the headers for the order items section. From line 4 onwards we have the actual values for the ordered products. If an order has only 1 product that’s it, we have 4 lines. If there are 3 products in an order there is a total of 6 content lines (one for each of the SKUs ordered). At the end of the file there is always a checksum value noting how many lines there should’ve been in this file which we should use as a validation and if it doesn’t match the actual total of lines we read we should set the order on an Incomplete status with a corresponding error message: “There is a mismatch between expected lines and actual read lines within the order file”. The error should be stored in the new Order Error table. This error is with a high severity so the order should go to an “Incomplete” status if we face it
Example order file:
order-20240220151530371526.txt
Example Mapping: Please note there are two mapping sections below for better differentiation between the main order section and the ordered items section
Order:
| Integration Field | Integration Notes | Integration Format | Hemi Mapping | Hemi Notes |
| order_number | The unique purchase order reference (to be used when updating The Edge) | 1 alphabetic character followed by 9 numeric digits | Order > Marketplace Order ID | |
| order_date | Date and time at which the order was created | YYYY-MM-DD HH:MM:SS | Order > Order Created Time | |
| customer_ref | N/A | |||
| retailer_ref | Argos internal reference (specific to a single delivery) | 23 digits, numeric | Order Argos> Retailer Reference | |
| po_enduser | Argos customer order number (to be quoted in all customer correspondence) | 9 digits, numeric | Order > Selling Manager SalesRecordNumber | |
| currency_code | N/A | Hardcode GBP | ||
| carrier | N/A | |||
| service | N/A | |||
| giftwrap | Contains 'n' to indicate not used | N/A | ||
| signature | Contains 'n' to indicate not used | N/A | ||
| expected_delivery_date | Set when the order is placed (order date plus lead-time) | YYYY-MM-DD HH:MM:SS | Order > Ship By Date | Might need to move it to a new field if it turns out it is for final delivery to Buyer |
| shipping_title | Customer title | Order > Shipping Title | ||
| shipping_full_name | Customer forename(s) and surname | Order > Shipping Buyer Name | ||
| shipping_address_1 | Property | Order > Shipping Street 1 |
Order > Shipping Street 2 | If Order > Shipping Street 1 is empty we want to get Order > Shipping Street 2 |
| shipping_address_2 | Street | | Order > Shipping Street 2
N/A | If Order > Shipping Street 2 is added as Order > Shipping Street 1 we keep this empty |
| shipping_address_3 | Town / City | | Order > Shipping City | <v1.3> Argos could send us the City in two fields : shipping_address_3 or shipping_city . We need to create a logic and if we have filled one or the other we store the info only from the filled field. If we have both filled we treat shipping_city with priority. |
| shipping_address_4 | | | N/A | Every The Edge connection user can set the way they utilise their fields. Argos have decided that this is the way they want their address set, hence why these fields are not used by them at all |
| shipping_city | Town / City | | <v1.3> Order > Shipping City | Argos could send us the City in two fields : shipping_address_3 or shipping_city . We need to create a logic and if we have filled one or the other we store the info only from the filled field. If we have both filled we treat shipping_city with priority.. </v1.3> |
| shipping_state | | | N/A | |
| shipping_postcode | Postcode | | Order > Shipping Postal Code | |
| shipping_country | Country abbreviation | | Order > Shipping Country Code | |
| shipping_phone | Customer mobile number | | Order > Shipping Phone | |
| shipping_email | Customer email address | | Order > Buyer mail | |
| invoice_title | | | N/A | As we will not receive “Invoice” fields from Argos we are to automatically fill in our Billing fields corresponding to the available Shipping ones |
| invoice_full_name | | | N/A | |
| invoice_address_1 | | | N/A | |
| invoice_address_2 | | | N/A | |
| invoice_address_3 | | | N/A | |
| invoice_address_4 | | | N/A | |
| invoice_postcode | | | N/A | |
| invoice_country | | | N/A | |
| invoice_phone | | | N/A | |
| invoice_email | | | N/A | |
| comments | | | N/A | |
| test_flag | 'Y' or 'N' | | N/A | We don’t have use of this field at the moment |
Ordered Items:
| line_ref | Item sequence within this purchase order | Numeric | Product in Order > Item Order Line ID | |
| additional_ref | <v1.3>Argos populate this with the PO number in the format | Text | Product In Order > Item Transaction ID | |
| part_number | This is the Argos product code, in the format nnnnnnnn | Text | Product in Order > SKU |
| AND Product in Order > EAN | We are to Map the EAN in the Product in Order via the passed part_numberfrom Argos.
We are to also map the Product Account > Channel Item ID for the mapped SKU and store the value in Product In Order > Channel Item ID
If we can’t map a EAN we are to store an error with the message “Product with EAN {{EAN}} could not be matched with any existing item” - where {{EAN}} should be the value from the file. As the order will not have a SKU in this case we are to set the order on an “Incomplete” status. </v1.3> |
name | Product name or short description of the product | Product in Order > Item Title | <v1.2>We pick this field with priority ****If name is missing we use the description | description | Product description | Product in Order > Item Title | If name is presented we ignore the description</v1.2> | quantity | Product in Order > Quantity | cost | Argos selling price for one unit of this item | Product in Order > Item Price | <v1.1>We are to Map the EAN in the Product in Order via the passed EAN from Argos. This is to be mapped by the Product Account > Marketplace EAN or the Product> EAN (in that order of relevance) to get the correct Product Account > Price value to store in this field If we can’t map an EAN we are to store an error with the message “Product with EAN {{EAN}} could not be matched with any existing item” - where {{EAN}} should be the value from the file. As the order will not have a Item Price in this case we are to set the order on an “Incomplete” status</v1.1> | shipping | N/A | subtotal | Selling price multiplied by ordered quantity | N/A | tax | N/A | tax_rate | N/A | tax_code | N/A | total | N/A | promised_date | In practice this will be identical to the order-level expected delivery date at launch of Condor. | YYYY-MM-DD HH:MM:SS | N/A | This field is more important when we update information back to Argos |
- Workflow steps Besides reading the files there is no specific expectation of us to do anything with the files. Having in mind we will have also a “.DONE” file to take care of I believe the folder will fill up quite fast so it’d be better to move both such files to a sub /processed folder of the one from which the file was picked to keep things clean
From there on every order we receive we treat as a RFS, Paid order that needs to be stored in Hemi and go through all standard processes and validations (this includes but is not limited to taxes, debundling, country refinement, payment records creation, etc. https://www.notion.so/threecolts/Order-management-general-requirements-c345c9248c074bb1a06bbad16203f588)
We are not expecting to ever receive a subsequent order files for the same order which means that
- We are not expecting to get any subsequent cancellations and/or refunds that we need to store
- If we do receive such a file we want to map it correctly and store the right error: “Duplicated order file received from Argos for this order”. This error should go in the new Order Error section. It is with a low severity and should not have any effect on the already previously stored order. Meanwhile we want to move the file to processed folder.
- We need to calculate the Order Total & Subtotal as well - we are not going to be receiving any shipping cost associated so the subtotal will be equal to the total too
- If we face a completely broken file, such that we can’t begin or complete reading correctly we should move it into a sub “/error” folder of the one from which we’ve picked the order file
- Just a reminder - we are to process multiple files at a single run of the script otherwise we will get a huge backlog of files for processing 🙂
- <v1.4> We want to filter products by the last field (promised_date). If a product has no promised_date we don’t want to save it in Hemi at all and skip it. </v1.4>
