Part Synergy PFG Custom Integration
| v1.0 | First Publish |
In order to incorporate the custom integration for each warehouse we want to build a centralized structure where we gonna add all the authorization and setup details which will connect to the relevant location. In order to achieve this we will need to have a new structure with the following details:
Part Synergy Warehouse Integration (Please note this is should be added in the menu under Custom section only for Part Synergy instance)
| Field Name | Type | Require | Default | Comment |
| Active | checkbox | No | false | |
| Name | varchar | Yes | ||
| API Type | dropdown | Yes | List with all available custom API integration we have for PartSynergy warehouses | |
| API URL | varchar | No | ||
| API Username | varchar | No | ||
| API Password | varchar | No | ||
| API Access Token | varchar | No | ||
| API Account | varchar | No | ||
| Create Order | checkbox | No | false | |
| Get Shipment | checkbox | No | false | |
| Get Stock | checkbox | No | false | |
| Get Price | checkbox | No | false | |
| Location | dropdown | Yes | List with all locations |
Integration Documentation:
Staging URL: http://woscustomerservices-staging.usautoparts.com/wosCustomerService.php Production URL: https://wosapiext.usautoparts.com/wosCustomerService.php
The API Type for PFG will be - “PFG”
