ASOS - Ship Orders
Once we have Orders > Update Shipping Pending = Yes, first we need to update the shipping details (Courier, Tracking, Tracking URL) using OR23 then we just mark the order as shipped in Mirakl with OR24 but before all this happen we need to validate the shipping details. In order to do so we check if the Orders > Courier is part from the Mirakl shipping list (SH21).
At the moment when sending shipping updates to Asos, we are using the courier from Order Shipments > Carrier We want to introduce Courier mapping. Thus we need to create a slave table under Courier called “Asos Courier Mapping”. In this table we need to have a dropdown field with all the carriers.
| field name | notes |
| Asos Courier | This should be a drop-down menu with the carriers which we get with the GET SH21 - List all carriers. ASOS - Ship Orders. We need to send the carrier_code related to the carrier as well. |
Have all this structure the mapping will works based on: If Order Shipment > Carrier match Courier > Name we send the selected courier from Asos Courier Mapping > Asos Courier
We also would like to introduce a default case in Account Asos called “Default Carrier” where again the same list with carriers (GET SH21 - List all carriers.) to be displayed and to be able to select on specific carrier.
This way the logic will be first we are checking if there is any mapping set in Asos Courier Mapping and if we match any of the couriers. If not We are checking if there is default carrier set in Account Asos. If not error to be returned.
This will be our pilot mapping for a Mirakl integration and ideally we would want to implement it across all Mirakl integrations at some point.
Please note it would be good if we can have button to update the carriers in Asos Courier Mapping table.
With this call we get all carriers that we could ship with. Please, bear in mind, If we do not match any courier we are shipping with “other“ carrier we have to push carrier code as “Other“ with carrier name (Order Shipment > Carrier) and tracking num (Order Shipment> Tracking Number)
API Docs: https://asosuk-dev.mirakl.net/help/api-doc/seller/mmp.html#SH21
"carriers": [
"code": "20-FED",
"label": "Fed Ex",
"tracking_url": "http://www.fedex.com/Tracking?action=track&tracknumbers={trackingId}&zipcode={zipCode}"
"code": "45-UPS",
"label": "UPS",
"tracking_url": "https://wwwapps.ups.com/WebTracking/track?track=yes&trackNums={trackingId}"
"code": "23-EVRI",
"label": "EVRI",
"tracking_url": "https://www.evri.com/track/receipt/{trackingId}/list"
Via this call, we should push to order the reuired information as stated into the below example.
API Docs: https://asosuk-dev.mirakl.net/help/api-doc/seller/mmp.html#OR23
Parameters:
| order_id | String | |
| Order identifier | Yes |
Example Call:
"carrier_code": "UPS",
"carrier_name": "UPS",
"tracking_number": 5555
carrier_code |
String | |||
carrier_name |
String | |||
| The name of a carrier. This information is mandatory for an unregistered carrier. | Y | N/A | We Get this from the Shipping List if we match our Order Shipment > Courier with the label | |
carrier_url |
String | |||
| The tracking url of a carrier. This information is unused for registered carriers (because computed automatically). This information is optional for unregistered carriers. | Y | N/A | We Get this from the Shipping List if we match our Order Shipment> Courier with the label | |
tracking_number |
String | |||
Example Call with “Other“:
"carrier_code": "Other",
Mapping with Other:
carrier_code |
String | |||
| The code of a carrier. This information is mandatory for a registered carrier. | N | Hardcoded as “Other“ | ||
| (If there is no match with the ASOS carrier list) | ||||
carrier_name |
String | |||
| The name of a carrier. This information is mandatory for an unregistered carrier. | Y | Order Shipment > Courier | ||
carrier_url |
String | |||
| The tracking url of a carrier. This information is unused for registered carriers (because computed automatically). This information is optional for unregistered carriers. | Y | Order Shipment >Tracking URL | ||
tracking_number |
String | |||
API Docs: https://asosuk-dev.mirakl.net/help/api-doc/seller/mmp.html#OR24
Parameters:
Again to update our orders > tool status as “Shipped”.
