Marketplaces / BOL Technical Scope [In Progress] / Bol Product Management / Bol Update Offer Stock
Date Version Created / Updated Notes
10/05/2023 v1.0 Bogomil Pavlov First publish
The purpose of this document is to describe how we update offer stock and end item on Bol We want stock updates and zero stock updates to be as per our standards. We want all triggers, validations and standardizations which are not mentioned to be a per Stock Update general requirements
Please note this request should work for all accounts which have Account Bol > Fulfilment Method = FBR
API Call: PUT https://api.bol.com/retailer/offers/{offer-id}/stockAPI Docs:https://api.bol.com/retailer/public/redoc/v9/retailer.html#tag/Offers/operation/update-offer-stock
The offer-id is our Product Account > Channel Item ID. The offer price updates are product per product
Sample Request:
  "amount": 6,
  "managedByRetailer": false
Bol Field Bol Comment Required Hemi Field Comment
amount The amount of stock available for the specified product present in the retailers warehouse. Note: this should not be the FBB stock! Defaults to 0. Yes Product Account > Quantity
managedByRetailer Configures whether the retailer manages the stock levels or that bol should calculate the corrected stock based on actual open orders. In case the configuration is set to 'false', all open orders are used to calculate the corrected stock. In case the configuration is set to 'true', only orders that are placed after the last offer update are taken into account. Yes “true“ Hardcoded as “true”
Sample Response:
  "processStatusId": "1234567",
  "entityId": "987654321",
  "eventType": "UPDATE_OFFER_STOCK",
  "status": "SUCCESS",
  "links": [
      "rel": "self",
      "method": "GET"
The offer stock update is asynchronous and we will have to create a new feed in Marketplace Feeds table. After each successfully sent feed for offer stock update i we will receive the processStatusIdfrom the response and need to store it in Marketplace Feeds table with the rest of the details as follows.
Bol Field Hemi Field Comment
processStatusId Marketplace Feed > External ID
eventType Marketplace Feed > External Type
Marketplace Feed > Type Hardcoded as “Update Stock“
createTimestamp Marketplace Feed > Submitted Date When the feed is submitted
Marketplace Feed > Status If the external status is “PENDING“ we want to set the status as “Processing“.
If the external status is “SUCCESS“ or “FAILURE” or “TIMEOUT” we want to set the status as “Completed“.
status Marketplace Feed > External Status
If any errors are returned we want to store them in Product Account > Update Quantity Error after the Bol Product Response Reader
