Marketplaces / Tesco (on Marketplacer) / Tesco Technical Scope / Tesco Order Management / Tesco Get Orders
Tesco Get Orders
v1.0 04/01/2025 Hristiyan Georgiev Initial version
v1.1 04/29/2025 Hristiyan Georgiev Payload and mapping changes
v1.2 05/21/2025 Hristiyan Georgiev Changed logic and mapping on Total and Subtotal amounts.
The Tesco Order Model
The diagram below illustrates the relationship between Order, Invoices and Line Items:
Put simply:
  • A Seller is an individual entity (usually a business) that the marketplace operator has invited to sell on their marketplace. Multiple sellers can “participate” in a single order.
  • An Order is the “marketplace-level” object that acts as the container for a customer’s entire purchase. An order object in Tesco will always have at least 1 Invoice attached to it.
  • An invoice is the individual seller’s “view” of the order. Given that we are dealing with a marketplace, it is conceivable that customers will purchase items from 1 or more Sellers. It is therefore necessary to “split” the order into seller-level components, in this case the invoice object. Even if there is only 1 seller participating in the transaction, there will still be an invoice created on the order
  • A Line Item is the individual item that a customer will purchase. Line items start their journey as Variants placed for sale on the marketplace by the seller. When a variant object is purchased a lineItem object is created.
The primary takeaway from the above is that as a Seller on Tesco, we will primarily be interested in querying Invoice objects.
Get Orders
The first run will check for new orders in the last 90 days and afterwards we will get the date from last_date_run table and filter orders using a variable that will be explained below. We want to overlap the time with 1 hour, meaning that we should use the time of last_date_run - 1 hour.
API Docs : https://api.marketplacer.com/docs/seller-api/examples/orders/invoices/
<v1.1>GraphQL Query :
query GetInvoicesCreatedSince($pageSize: Int $endCursor: String, $filters: InvoiceFilters){
  invoices(first : $pageSize, after: $endCursor filters: $filters){
    pageInfo{
        hasNextPage
        endCursor
        totalCount
        nodes{
            legacyId
            id
            statusFlags
            buyerFirstName
            buyerSurname
            buyerPhone
            buyerEmailAddress
            buyerMessageToSeller
            shippingAddress {
                address
                city
                country {
                    name
                    code
                postcode
                state {
                    name
             buyerBillingAddress {
                    address
                city
                country {
                    name
                    code
                postcode
                state {
                    name
            createdAt
            deliveryType
            statusFlags
            paidAt
            shipments {
                id
                dispatchedAt
                carrier
                trackingNumber
                trackingLink
                shippedItems{
                    quantity
                    lineItem{
                        id
             totalFormatted(currency: "GBP")
             subtotalFormatted(currency: "GBP")
             shippingCostFormatted(currency: "GBP")
             taxShippingFormatted(currency: "GBP")
             taxTotalFormatted(currency: "GBP")
            lineItems{
                id
                advertTitle
                variantBarcode
                variantId
                variantSku
                variantName
                legacyId
                quantity
                itemAmountFormatted(currency: "GBP")
                postageFormatted(currency: "GBP")
             updatedAt
Please note that we are not querying for any refund related stuff in the Get Orders call as this will be handled with the Get Claims functionality </v1.1>
We need to pick the currency from Account > Exchange Rate Calculator Currency as this will be the currency in which the information for the order will be returned for.
Query Variables :
    "pageSize": 50,
    "endCursor": null,
    "filters": {
        "createdSince": "2024-10-16T09:58:00"
Variables Mapping :
Integration FIeld Hemi Mapping Hemi Notes
pageSize This will be our page size for this query
endCursor Should be null when doing the first query, and then if in the response we have hasNextPage = true, we need to use the string returned in the endCursor field.
filters
createdSince last_date_run - 1hour
Should be in a ISO8601 date format : 2024-10-16T09:58:00 |
Example response (please note that for the sake of mapping this is a full case scenario response, with a shipped and refunded order. In most cases when we are getting brand new orders, we will have empty shipments and refundrequests objects) :
    "data": {
        "invoices": {
            "pageInfo": {
                "hasNextPage": true,
                "endCursor": "MQ"
            "totalCount": 27,
            "nodes": [
                    "legacyId": 13913,
                    "id": "SW52b2ljZS0xMzkxMw==",
                    "statusFlags": [
                        "PAID",
                        "SENT",
                        "AWAITING_RETURN"
                    "buyerFirstName": "Erling",
                    "buyerSurname": "Boehm",
                    "buyerPhone": "0405510001",
                    "buyerEmailAddress": "hs@email.com",
                    "buyerMessageToSeller": null,
                    "shippingAddress": {
                        "address": "35 Collins Street",
                        "city": "Sydney",
                        "country": {
                            "name": "Australia",
                            "code": "AU"
                        "postcode": "2000",
                        "state": {
                            "name": "New South Wales"
                    "buyerBillingAddress": {
                        "city": "Sydney",
                        "country": {
                            "code": "AU"
                        "postcode": "2000",
                        "state": {
                    "createdAt": "2024-10-16T09:58:22+11:00",
                    "deliveryType": "BUY_ONLINE",
                    "paidAt": "2024-10-16T09:58:23+11:00",
                    "shipments": [
                            "id": "U2hpcG1lbnQtMTAzNA==",
                            "dispatchedAt": "2024-10-23T22:13:27+11:00",
                            "carrier": "DHL",
                            "trackingNumber": "9887456321",
                            "trackingLink": "http://www.dhl.com.au/en/express/tracking.html?brand=DHL&AWB=9887456321",
                            "shippedItems": [
                                    "quantity": 1,
                                    "lineItem": {
                                        "id": "TGluZUl0ZW0tNDMyNQ=="
                    "totalFormatted": "£50.23",
                    "subtotalFormatted": "£50.23",
                    "shippingCostFormatted": "£0.00",
                    "taxShippingFormatted": "£0.00",
                    "taxTotalFormatted": "£0.00",
                    "lineItems": [
                            "id": "TGluZUl0ZW0tNDMyNQ==",
                            "advertTitle": "Electronic Rubber Cheese",
                            "variantBarcode": null,
                            "variantId": "VmFyaWFudC0xMDU0Njc=",
                            "variantSku": "LnYy",
                            "variantName": "blue / Navy",
                            "legacyId": 4325,
                            "quantity": 1,
                            "itemAmountFormatted": "£50.23",
                            "postageFormatted": "£0.00",
                    "updatedAt": "2024-10-23T23:41:07+11:00"
Response Mapping (<v1.1> the changes here are that refund related mapping was removed, also one of the existing fields was changed </v1.1>) :
Integration Field Hemi Mapping Hemi Notes
data
invoices
pageInfo
hasNextPage N/A
endCursor N/A
totalCount
nodes
legacyId Orders > Selling Manager SalesRecordNumber
id Orders > Marketplace Order ID
statusFlags Orders > Status
AND Orders > Marketplace Status | Since Tesco are sending us all statuses of the order (including past statuses) we need to have a logic and always update the status in Hemi according to the latest status from Tesco. (the latest status will be the most bottom one from the statusFlags object.)Mapping of Tesco-Hemi statuses will be below. | | | | | buyerFirstName | | | | Orders > Shipping Buyer Name AND Orders > Billing Name | Concatenate with buyerSurname with a single space between them | | | | | buyerSurname | | | | Orders > Shipping Buyer Name AND Orders > Billing Name | Concatenate with buyerFirstName with a single space between them | | | | | buyerPhone | | | | Orders > Shipping Phone AND Orders > Billing Phone | | | | | | buyerEmailAddress | | | | Orders > Buyer Mail | | | | | | buyerMessageToSeller | | | | Orders > Note | | | | | | shippingAddress | | | | | | | | | | | address | | | Orders > Shipping Street 1 | | | | | | | city | | | Orders > Shipping City | | | | | | | country | | | | | | | | | | name | | | Orders > Shipping Country Name | | | | | | | code | | | Orders > Shipping Country Code | | | | | | | postcode | | | Orders > Shipping Postal Code | | | | | | | state | | | | | | | | | | name | | | Orders > Shipping State Province | | | | | | buyerBillingAddress | | | | | | | | | | | address | | | Orders > Billing Street 1 | | | | | | | city | | | Orders > Billing City Name | | | | | | | country | | | | | | | | | | name | | | Orders > Billing Country Name | | | | | | | code | | | Orders > Billing Country Code | | | | | | | postcode | | | Orders > Billing Postal Code | | | | | | | state | | | | | | | | | | name | | | Orders > Billing State Province | | | | | | createdAt | | | | Orders > Order Created Time | We need to convert it into unix timestamp so we can store it properly | | | | | deliveryType | | | | Orders Tesco > Delivery Type | New field | | | | | paidAt | | | | Order Payment Details > Payment Date | We need to convert it into unix timestamp so we can store it properly | | | | | shipments | | | | | | | | | | | id | | | Order Shipment > External Id | | | | | | | dispatchedAt | | | Order Shipment > Shipment Time | We need to convert it into unix timestamp so we can store it properly | | | | | | carrier | | | Order Shipment > Courier | | | | | | | trackingNumber | | | Order Shipment > Tracking Number | | | | | | | trackingLink | | | Order Shipment > Tracking URL | | | | | | | shippedItems | | | | | | | | | | | quantity | | Order Shipment Rows > Quantity | | | | | | | | lineItem | | | | | | | | | | | id | | We need to map this with Product in Order > Item Order Line ID to find out which products are shipped and then create Order Shipment Rows for those products. | | | | | totalFormatted | | | | | <v1.2> Due to discrepancies because of exchange rates, we want to calculate the total based on the sum of the products + the shipping cost. We sum all products’ costs plus shippingCostFormatted and store the total in Orders > Order Total Amount</v1.2> | | | | | subtotalFormatted | | | | | <v1.2> Due to discrepancies because of exchange rates, we want to calculate the subtotal based on the sum of the products and without the shipping cost and store it in Orders > Order Subtotal Amount</v1.2> | | | | | shippingCostFormatted | | | | Orders > Shipping Service Cost | We need to remove any extra symbols in this field. Depending on the currency they will be different symbols (US$, £, AU$ etc) | | | | | taxShippingFormatted | | | | Orders > Total Shipping Marketplace VAT OR Orders > Total Shipping Sales Tax | This would depend on Account > Country IF we have Account > Country = United States we use the Total Shipping Sales Tax field, IF we have Account > Country != United States we use Total Shipping Marketplace VAT | | | | | taxTotalFormatted | | | | Orders > Total Sales Tax OR Orders > Total Marketplace VAT | This would depend on Account > Country IF we have Account > Country = United States we use the Total Sales Tax field, IF we have Account > Country != United States we use Total Marketplace VAT | | | | | lineItems | | | | | | | | | | | id | | | Product in Order > Item Order Line ID | | | | | | | advertTitle | | | Product in Order > Item Title | | | | | | | variantBarcode | | | Product in Order > EAN | | | | | | | variantId | | | Product in Order > Channel Item ID | | | | | | | variantSku | | | Product in Order > SKU | | | | | | | variantName | | | N/A | | | | | | | legacyId | | | Product in Order Line > Marketplace Order Item ID | | | | | | | quantity | | | Product in Order> Quantity | | | | | | | itemAmountFormatted | | | Product in Order > Item Price | We need to remove any extra symbols in this field. Depending on the currency they will be different symbols (US$, £, AU$ etc) | | | | | | postageFormatted | | | Product in Order > Item Shipping Cost | We need to remove any extra symbols in this field. Depending on the currency they will be different symbols (US$, £, AU$ etc) | | | | | | <v1.1>taxTotalFormatted | | | Product In Order > Item Sales Tax Price OR Product In Order > Marketplace VAT Item Price | This would depend on Account > Country IF we have Account > Country = United States we use the Total Sales Tax field, IF we have Account > Country != United States we use Total Marketplace VAT </v1.1.> | | | | | updatedAt | | | | N/A | |
Order Statuses
Tesco Order Status Description Hemi Status Notes
AWAITING_REFUND A Cancellation (pre-dispatch) or Return (Post-dispatch), has been requested and items have been marked as having been returned to the Seller. The refund request is awaiting the Operator to either approve or deny the refund request. N/A We always want to check the previous status in statusFlags that we have mapping for and set the Hemi status to the last mapped status. Incase we receive this for a brand new order, again we check for the previous status in statusFlags in the response and map it to the relevant MC Pro status.
AWAITING_RETURN A Cancellation (pre-dispatch) or Return (Post-dispatch), has been requested. The refund request is awaiting on the Seller to mark the items as having been returned in acceptable condition. N/A We always want to check the previous status in statusFlags that we have mapping for and set the Hemi status to the last mapped status. Incase we receive this for a brand new order, again we check for the previous status in statusFlags in the response and map it to the relevant MC Pro status.
CANCELLED [Non-Connected Only] Order / Invoice had been awaiting payment but the payment has subsequently been cancelled. Cancelled
COLLECTED [Non-Connected Only] Where a click and collect order / invoice had been placed, and the line items on that invoice had been collected. At the time of writing Click and Collect functionality is only available in Non-Connected instances. Shipped
PAID Order has been completed and payment has been “processed”. This includes US-based scenarios where delayed payment capture is being used. Ready for Shipping
PARTIALLY_SENT Only some items of an invoice have been dispatched. This includes scenarios where: 1) Multiple quantities of a single line item were ordered and only a subset have been dispatched, 2) Multiple line items had been ordered and only some of those line items have been dispatched Partially Shipped
PAYMENT_UNDER_REVIEW [Non-Connected Only] Where payments are being taken by Tesco the payment gateway has placed the payment in a review status. Pending We dont want to store payment row on this status
READY [Non-Connected Only] Where a click and collect order / invoice has been placed, and the items on that invoice are ready to be collected. At the time of writing click and collect functionality is only available in Non-Connected instances. Ready for Shipping
REFUNDED A Cancellation (pre-dispatch) or Return (Post-dispatch), has been requested and approved. Cancelled
REMITTED Remittance has been paid to the seller of this Invoice. N/A We always want to check the previous status in statusFlags that we have mapping for and set the Hemi status to the last mapped status. Incase we receive this for a brand new order, again we check for the previous status in statusFlags in the response and map it to the relevant MC Pro status.
SENT All line items on the invoice have been sent. Shipped
Get Modified Orders
We want to have the functionality to get info on modified orders. The GraphQL Query is the same as the Get orders one, the only difference will be in the variables where we need to change the createdSince variable with updatedSince. The response and mapping are all the same as the Get Orders. We want to implement the last_date_run table for this cron too and it should search for orders with last_date_run - 30 minutes
