Inno Taxonomy
| 1.0 | 08/12/2022 | Hristiyan Georgiev | First publish |
API Call:/api/hierarchies
API Docs: https://galeriainnobe2-dev.mirakl.net/help/api-doc/seller/mmp.html#H11
"hierarchies":[
"code": "homeAndLeisure",
"label": "Home And Leisure",
"label_translations":[{"locale": "en", "value": "Home And Leisure" }, {"locale": "fr",…],
"level": 1,
"parent_code": ""
"code": "homeAndLeisure-bathing",
"label": "Bathing",
"label_translations":[{"locale": "en", "value": "Bathing" }, {"locale": "fr",…],
"level": 2,
"parent_code": "homeAndLeisure"
API Docs:https://galeriainnobe2-dev.mirakl.net/help/api-doc/seller/mmp.html#PM11
API Call: /api/values_lists
API Docs: https://galeriainnobe2-dev.mirakl.net/help/api-doc/seller/mmp.html#VL11
Taxonomy export file
In order to generate the taxonomy file we will need to create a new record in Taxonomy export with: Marketplace = Inno Status = pending Category for Export = all (or we can specify which exact categories) Email = email to which the file will be send
Please find ore details on the file structure how it should look like after exported here - Taxonomy General requirements .
