BestBuy Order Acknowledgement
All validations, triggers and standardizations which are are as per
Order management general requirements
Orders Acknowledgement
With the introduction of the new Order Acknowledgement model we want to incorporate it within the Amazon Vendor integration. Thus in Account Amazon we want to introduce a new field which will indicate if we want to automatically accept the whole order or manually accept it.
The main trigger for the order acknowledgement will be Order Acknowledgement > Status = Pending and Order > Status = “Awaiting Acknowledge” however based on the flow we will have:
#1 Automatic Acceptance
We acknowledge all order items as Accepted and with the actual order download we will add the Order Acknowledgement details.
#2 Manual Acceptance When we have manual acceptance the trigger will be the actual user when from the Acknowledgment modal create the Order Acknowledgement .
Please keep in mind if we have bundle skus we want to acknowledge only the bundle SKU not the components.
Once we successfully sent the Acknowledgment and receive the success response we want to update all
Acknowledge statuses on the Order, Product In Order and Order Item Lines
Order Acknowledgement > Status = Completed
if there is an error during the acknowledgment we want to store it in Order Error table
This will leave the order with status
Order > Status = “Awaiting Acknowledge” with the relevant acknowledge statuses across Order, Product In Order and Order Item Lines
Oder Acknowledgement > Status = Completed.
Then we will have to wait for Get Orders to pick the order again and populate all the shipping information and mark the order as Order > Status = “Ready For Shipping”.
API Docs: https://help.mirakl.net/help/api-doc/seller/mmp.html#OR21
order_id = Orders > Marketplace Order Id
"order_lines": [
"accepted": true,
"id": "Order_00012-B-1"
"accepted": true,
"id": "Order_00012-B-2"
Mapping
| Parameter | Integration Notes / Value | Required | Hemi Field | ||
order_lines |
List of representations of order line for acceptance | Yes | |||
accepted |
Boolean indicating if the order line is accepted or refused | ||||
| ‘TRUE' or 'FALSE’ | Yes | Order Acknowledgement Row Line > Action | Order Acknowledgement Row Line > Action = Accept then we send “TRUE” |
Order Acknowledgement Row Line > Action = Reject then we sent “FALSE” |
| | id | string | Yes | Product In Order > Order Item Line | |
Since MIRAKL does not support acceptance on line level we can either accept or reject the whole product. Thus we want to add additional validation if not all line of the product in order are selected to return an error - “Acknowledgment at the line level is not supported”.
