ASOS - Offer Full Update
| 03/10/2022 | 1.1 | Bogomil Pavlov | MP feed type updated |
| 01.02.23 | 1.1 | Bogomil Pavlov | Split the flow to two separate feeds with and without prices |
API Docs: https://asosuk-dev.mirakl.net/help/api-doc/seller/mmp.html#OF01
| Mirakl Field | Mirakl Notes | Integration Required | Hemi Field | Comment | ||
sku |
product-id |
Unique product identifier for a given product-id-type - Required at offer creation - Maximum 40 characters | Yes | Product Account >Marketplace EAN |
Product >EAN | |
| product-id-type | | | | Yes | hardcoded as “ean“ | If we have ean populated we hardcoded the type as “ean“
Note: We always need to have EAN when we check call for listing create |
| internal-description | | | The description of the offer as shown in the back office view - Optional - Maximum 2000 characters | Optional | N/A | |
Character string limited to 100 characters | No | Product Account ASOS > Price Additional Info | |
The accepted values are defined from the Mirakl back office | Required | see notes | Mapping to our conditions:
11- New > 1000;
1-Excellent > 1500;
2-Very Good >4000;
3-Good >5000;
4-Sufficient >6000;
5-Refurbished_like_new > 2750
6-Refurnished_very_good >2500
7-Refurbished_good > 2000
yyyy-MM-dd
or
yyyy-MM-ddThh:mm:ss+00
| No | N/A | |
yyyy-MM-dd
or
| No | N/A | |
| logistic-class | | | The code for the logistic class. This logistic class overwrites the default logistic class defined for the product or Marketplace category assigned to the offer. | No | Account ASOS > Logistic class
Product Account ASOS > Logistic class | Our default Logistic Class is selected on account level and if we have selected on Product Account we pick it with priority |
"", "update", "delete" | No | N/A | |
| all-prices | | | | | | |
| | pricing | | | No | | |
| | | channel-code | | No | Account ASOS > Channel Code | We will use on GB channel for ASOS By default to be only the option GB |
| | | price | | No | Product Account > Price
Product Account > RRP | we send Product Account > RRP If RRP is populated and is bigger than Price |
| | | discount-price | | No | Product Account > Price | If RRP > Price
If RRP <= Price
discount-start-date| The first day the discount becomes available (if blank, the discount has no start date and is immediately active) - Optional - Valid date Date format:2022-09-01| No | Product Account ASOS> Discount Start Date | If RRP > Price and If we do not specify any dates in the relevant fields we hardcoded current date (“NOW“) Date format -2017-02-20T10:45:53+01If RRP <= Price We include the discount fields with empty values | | | |discount-end-date| The last day the discount is available (if blank, the discount has no end date) - Optional - Valid date | No | Product Account ASOS > Discount End Date | If RRP > Price and If we do not specify any dates in the relevant fields we hardcode current date + 2 year (“NOW“ +2y) Date format -2017-02-20T10:45:53+01If RRP <= Price We include the discount fields with empty values |
sku |
product-id |
Product >EAN | |
| product-id-type | | Yes | hardcoded as “ean“ | If we have ean populated we hardcoded the type as “ean“
| description | Offer description - Recommended - Maximum 2000 characters | No | Product Account > Description | |
| internal-description | The description of the offer as shown in the back office view - Optional - Maximum 2000 characters | Optional | N/A | |
11- New > 1000;
1-Excellent > 1500;
2-Very Good >4000;
3-Good >5000;
4-Sufficient >6000;
| available-start-date | The first day the offer becomes available. The offer has no start date if blank.
yyyy-MM-dd
or
| No | N/A | |
| available-end-date | The last day the offer is available. The offer has no end date if blank.
yyyy-MM-dd
or
| No | N/A | |
| logistic-class | The code for the logistic class. This logistic class overwrites the default logistic class defined for the product or Marketplace category assigned to the offer. | No | Account ASOS > Logistic class
| update-delete | Used only in "Normal" import mode. Update mode is used if blank.
Аfter successful product creation should have Channel Item ID, which for MIRAKL integration is the SKU!
Case1:
Product status **= Product Published ; Listing Status **= Active; List/Update the whole item = Pending
Product status = Product Published; **Listing Status =Active; List/Update the whole item = Not Needed**
Product status **= Product Published ; Listing Status **= Active; List/Update the whole item = Error
(The error need to be stored into Update item error field.
Case2:
Product status **= Product Published ; Listing Status **= Inactive; List/Update the whole item = Pending
Product status = Product Published; **Listing Status =Inactive; List/Update the whole item = Not Needed**
Product status **= Product Published ; Listing Status **= Inactive; List/Update the whole item = Error
"import_id": 2035
API Docs: {{TBA}}
