How does the Gmarket Korea integration work with WAPT
As 11street Korea has quite a few specifics to how it works in this page you can find a description of how things work in WAPT.
- Account set up
In the first section of the account(Main screen) you populate the standard information. Which is the marketplace, the time zone and if the account is activated.
In the first tab you add the seller again standard to what is being done for other marketplaces.
Then you have to go to the next tab which is the Account Gmarket
From top to bottom explanation of each field and what it is supposed to have as information filled in and how:
Username -
Gmarket seller ID -
Secret Key -
Token -
Cancel Action Default -
Return Action Default -
Exchange Action Default -
Discount Start Date -
Discount End Date -
Price Round Up
Origin Goods Type
Origin Type
Origin Country Code
Multiple Origin
Allow Price Comparison Coupon
Shipping Type
Shipping Courier
Shipping Address Code
Bundle Shipping Template ID
Free Shipping Fee Type
Shipping Return and Exchange Address Code
Shipping Return and Exchange Company
Shipping Return and Exchange Fee(one way)
Dispatch Policy Code
Allow Quick Service
Convert exchange claims to returns?
Next section - Account stock profile is working in the standard way
Next section - Shipping template from here the only important thing you have to populate is if the shipping is domestic or international.
Next section - Account Location works in the standard way
Next section - Payment is not in use for this integration
Next section - Return Policy - this section is not in use for this integration
Next section - Location Address - this section is not in use for this integration
Next section - Design Template - it works in the standard way
- Product and Product Account - creating listings
In the product section there is nothing specific when creating new SKU's. We are sending EAN or Barcode as Gmarket requires it. If you don't have anything to input there add "N/A".
In the product account there are a lot of specifics.
First when we go in the Item Specifics there are a few in there that are required.
isAdultProduct -
isYouthNotAvailable -
modelNumber -
brandCode -
sellerBrandCode -
sellerBrandName -
weightKg -
lifeCertificationType - if you use "1" as value that would mean that this type of certification is not applicable for this product.
childCertificationType - if you use "1" as value that would mean that this type of certification is not applicable for this product.
harmfulCertificationType - if you use "1" as value that would mean that this type of certification is not applicable for this product.
electricCertificationType - if you use "1" as value that would mean that this type of certification is not applicable for this product.
For any of the above if value selected is "0" then you have to add two additional item specifics that you need to add in order to register the actual certificate.
The additional IS are:
{given certification type}CertificationTarget with value "0".
{given certification type}CertificationCode with the actual code provided by the client.
Other specific thing for Gmarket Korea is the notifications. Those are some Item Specifics that are specific for Gmarket Korea and are categorised in a separate categorisation.
In here you can find the taxonomy for those Notifications -
https://drive.google.com/open?id=1H0YKSp0vihdtOkldw7GopYRV0dAUOdksmXS5JLQLrH0
How to set the Notifications in WAPT:
In product account eleven street which can be found at the bottom of the product account screen as shown below:
You can find a table similar to the
Item Specifics
table. It works in the same way and it looks like this:
You need to input first the Parent Category Code then the Parent Category Properties taken from the Notifications Taxonomy File HERE.
First the category has a specific numeric ID then for each property you have a specific numeric ID that you have to input as header (Property) and a Value which is free text. This is going to be displayed in the listing on 11Street and is very important to be correctly populated.
