Inno Offer Stock Update
| 1.0 | 09/12/2022 | Hristiyan Georgiev | First Publish |
API Docs: https://galeriainnobe2-dev.mirakl.net/help/api-doc/seller/mmp.html?#OF01
sku |
product-id |
Product > EAN | |
| product-id-type | | Yes | hardcoded as “ean“ | |
The accepted values are defined from the Mirakl back office | Yes | Product > ConditionID | Mapping to our conditions:
11- New > 1000;
1-Excellent > 1500;
2-Very Good >4000;
3-Good >5000;
4-Sufficient >6000;
5-Refurbished_like_new > 2750
6-Refurnished_very_good >2500
7-Refurbished_good > 2000
8-Refurbished_acceptable > 8000 |
"import_id": 2035
| Marketplace Feed > Type | Hardcoded as “Offer Stock Price Update“ | |
API Docs: https://galeriainnobe2-dev.mirakl.net/help/api-doc/seller/mmp.html?#OF02
Protect Quantity - This call should not go through if there is protect quantity, as there will be nothing to update.
Protect Price - We can exclude the price from the payload when we are doing updates so we do not update the price when we have Protect Price raised. This will work only under the condition explained earlier in the document.
Protect the whole item - This call should not go through if there is protect the whole item, as there will be nothing to update.
