Update Offerr
| 22/11/2022 | 1.0 | Bogomil Pavlov | Initial Version |
Submits an offer package
The Full Offer Update structure is the same as Create Offerr
After each successfully send feed for creation we will receive the packageId from the response and need to store it in Marketplace Feeds table.
| Cdiscount Field | Hemi Field | Comment |
packageId |
| Marketplace Feed > Type | Hardcoded as “Update Offers“ | |
| Marketplace Feed >ZIP Path | The url of the zip | |
| Marketplace Feed >Completed Date | When we process the feed | |
| Marketplace Feed >External Status | External Feed status |
Read Offer Package
API Call: GET https://api.octopia-io.net/seller/v2/offer-integration-packages[?packageId][>in][&pageIndex][&pageSize][&fields][&sort][&desc]
API Doc: https://developer.octopia-io.net/api-details#api=api-rest-seller-v2&operation=get-product-integration-reports
Request parameters
| Name | Required | Type | Description |
packageId |
true | string |
Format - int64. Package identifier. |
limit |
false | integer |
Format - int32. Must be written as follows $limit |
page |
false | integer |
Format - int32. Must be written as follows $page |
Sample Request: GET https://api.octopia-io.net/seller/v2/products-integration-reports?packageId=309592003&page=1&limit=50
Sample Response:
"package_id": 309592003,
"integration_state": "Integrated",
"number_of_errors": 1,
"offer_log_paged_list": [
"log_date": "2022-11-22T00:31:04.75+00:00",
"offer_integration_status": "Integrated",
"product_ean": "5056553233698",
"seller_product_id": "96581",
"property_list": [
"log_message": "96581|5056553233698|MP60297644-0004|OK|9000|Offer updated|Cdiscount",
"property_code": "0",
"property_error": "90"
"log_date": "2022-11-22T08:57:08.12+00:00",
"offer_integration_status": "Rejected",
"product_ean": "5054697499253",
"seller_product_id": "11806603270",
"property_list": [
"log_message": "11806603270|5054697499253||KO|3893|Données manquantes|Cdiscount",
"property_code": "93",
"property_error": "38"
"seller_id": 51102,
"page": 0,
"count_by_page": 50,
"total_logs_count": 2
Request Mapping:
| Cdiscount Field | Hemi Field | Comment | ||
package_id |
N/A | |||
integration_state |
Marketplace Feed >External Status | |||
number_of_errors |
N/A | |||
offer_log_paged_list |
log_date |
N/A | |||
offer_integration_status |
N/A | Based on this status we will know if the update of the SKU is successful or not | ||
product_ean |
N/A | |||
seller_product_id |
N/A | This is our SKU which we will be using to map the response | ||
property_list |
log_message |
Product Account > Update Item Error |
Product Account >Update Quantity Error
Product Account >Update Price Error
Product Account >End Item Error | Depends on the feed type we have pushed we will have to store the relevant message in the relevant field. |
| | | property_code | N/A | |
| | | property_error | N/A | |
| seller_id | | | N/A | |
| page | | | N/A | |
| count_by_page | | | N/A | |
| total_logs_count | | | N/A | |
In order to pick a product for offer creation we must HAVE Product Account > Channel Item ID populated, the relevant flags set and Product Account > Listing Status = Active/Inactive Product Account > Product Status =Product published Product Account > List / Update the Whole Item = Pending
Once the product is picked for offer creation we will have: Product Account > Listing Status = Active/Inactive Product Account > Product Status =Product published Product Account > List / Update the Whole Item = Sent
When we read the response if successful we will update the product: Product Account > Listing Status = Active/Inactive Product Account > Product Status =Product published Product Account > List / Update the Whole Item = Not Needed
When we read the response if error we will update the product: Product Account > Listing Status = Active/Inactive Product Account > Product Status =Product published Product Account > List / Update the Whole Item = Error With the relevant error message in Product Account > Update Item Error
Limits:
There is a a limit of 200 000 offers in a package but I think in order to have better performance we can set a limit of 50 000 or 100 000 offers per package.
Protect Quantity - We can exclude the quantity from the payload when we are doing updates so we do not add the quantity in the payload when have Protect Quantity raised
Protect Price - We can exclude the price from the payload when we are doing updates so we do not add the price in the payload when have Protect Price raised.
Protect the whole item - We update the quantity only.
