Yoox Taxonomy
| 1.0 | 14/12/2022 | Hristiyan Georgiev | First publish |
API Call:/api/hierarchies
API Docs: https://richemontit3-dev.mirakl.net/help/api-doc/seller/mmp.html#H11
"hierarchies": [
"code": "5911111",
"label": "Suncare",
"label_translations": [
"locale": "en",
"value": "Suncare"
"locale": "fr",
"value": "Protection solaire"
"level": 2,
"parent_code": "59"
"code": "5911112",
"label": "Toiletries",
"locale": "en",
"value": "Toiletries"
"locale": "fr",
"value": "Articles de toilette"
"level": 2,
"parent_code": "59"
"code": "5911113",
"label": "Womens Hair Removal",
"locale": "en",
"value": "Womens Hair Removal"
"locale": "fr",
"value": "Épilation Femmes"
"level": 2,
"parent_code": "59"
API Docs: https://richemontit3-dev.mirakl.net/help/api-doc/seller/mmp.html#PM11
"attributes": [
"channels": [
"code": "string"
"code": "string",
"default_value": "string",
"description": "string",
"description_translations": [
"locale": "string",
"value": "string"
"example": "string",
"hierarchy_code": "string",
"label": "string",
"locale": "string",
"value": "string"
"locale": "string",
"product_feeds": [
"code": "string"
"required": "boolean",
"requirement_level": "string",
"roles": [
"parameters": [
"name": "string",
"value": "string"
"type": "string"
"transformations": "string",
"type": "string",
"type_parameter": "string",
"type_parameters": [
"name": "string",
"value": "string"
"unique_code": "string",
"validations": "string",
"values": [
"code": "string"
"values_list": "string",
"variant": "boolean"
API Call: /api/values_lists
API Docs: https://richemontit3-dev.mirakl.net/help/api-doc/seller/mmp.html#VL11
"values_lists": [
"code": "string",
"label": "string",
"locale": "string",
"value": "string"
"values": [
"code": "string",
"label": "string",
"locale": "string",
"value": "string"
Taxonomy export file
In order to generate the taxonomy file we will need to create a new record in Taxonomy export with: Marketplace = Yoox Status = pending Category for Export = all (or we can specify which exact categories) Email = email to which the file will be send
Please find ore details on the file structure how it should look like after exported here - Taxonomy General requirements .
