Showroom Prive Create Products
| 1.0 | First Publish |
Please note we do not need to select all variants if only one them is set for revision or creation because they goes as separate products on MIRAKL and the only thing which associate them is the {{TBA}}
So we can add variants to a variation group only by specifying the correct {{TBA}}
If we want to remove a product from a variation we need to push the product for update again without the {{TBA}}
- POST P41 - Import products to the operator information system {{TBA}}
API Docs: {{TBA}}
Complete flow:
If we receive success after performing P42 (when we send product to MIRAKL & When both "has_error_report" and "has_transformation_error_report" are equal to “false“ ) we can proceed to following:
There will be two cases how to handle channel item ids in MIRAKL depends on the type. The first case is after successful product creation we need to fill the Channel Item ID, which will be the SKU. The second option is to use P31 Get products for a list of product references which will map the SKUs between Hemi and MIRAKL and store the MIRAKL id as Channel Item ID. For {{TBA}} integration we will go for {{TBA}}
If we receive an error (any of "has_error_report" and "has_transformation_error_report" are equal to “true“):
Yes |
| No |
Example File:
{{TBA}}
<product_import_tracking>
</product_import_tracking>
API Docs: https://marketplace.kingfisher.com/help/api-doc/seller/mmp.html#P42
Example response:
<import_id>2005</import_id>
<has_transformation_error_report>false</has_transformation_error_report>
<shop_id>2000</shop_id>
Depends on the response of:
"has_error_report" and "has_transformation_error_report" we will need to call each of the error reports if we receive "true".
When both "has_error_report" and "has_transformation_error_report" are equal to “false“ is the success case (Import status = Completed) and we could proceed to creating and offer to this product.
If we receive success (When both "has_error_report" and "has_transformation_error_report" are equal to “false“ ) we can proceed to following:
We need to perform this call if we receive has_error_report = true, into the response from P42;
API Docs: {{TBA}}
Sample file
This call returns if the import is successful and how may warnings and errors we have in the file. We need to call this if we receive has_transformation_error_report = true
API Docs: {{TBA}}
Sample file - To be added
GET P31 - Get products for a list of product references
API Call: /api/productsAPI Docs:{{TBA}}
Sample Request: API call: GET {{TBA}} We will be using the EAN in order to obtain the product Ids. Please note we can specify many product_references in single request like:{{TBA}}
Samples Response:
<?xml version="1.0" encoding="UTF-8" standalone="yes" ?> <body> <total_count>1</total_count> <products> <product> <category_code>5110114</category_code> <category_label>Coffee Machines</category_label> <product_id>9312432012041</product_id> <product_id_type>EAN</product_id_type> <product_sku>MKP100000000037254</product_sku> <product_title>Breville Cafe Roma Stainless Espresso/Cappuccino Machine-ESP8C</product_title> </product> </products> </body>From the response we get the product_id and store it as Product Account > Channel Item ID.
