Yoox Offer Stock Update
| 15.01.23 | 1.0 | First Publish | |
| 01.02.23 | 1.1 | Bogomil Pavlov | Additional Info updated. |
| Changes in the mapping. |
API Docs: https://richemontit3-dev.mirakl.net/help/api-doc/seller/mmp.html#OF01
sku |
product-id |
Unique product identifier for a given product-id-type - Required at offer creation - Maximum 40 characters | Yes | Product >EAN | |||
product-id-type |
Yes | hardcoded as “ean“ | If we have ean populated we hardcoded the type as “ean“ | |||
quantity |
The quantity available in stock (maximum: one billion). | |||||
| Integer greater than or equal to 0 | Yes | Product Account > Quantity | ||||
min-quantity-alert |
N/A | |||||
state |
The state code of the offer | |||||
| The accepted values are defined from the Mirakl back office | Required | see notes | Mapping to our conditions: | |||
| 11- New > 1000; |
"import_id": 2035
API Docs: https://richemontit3-dev.mirakl.net/help/api-doc/seller/mmp.html#OF03
