The Range - Delete Product - N/A
The purpose of this page is to describe in details the flow of deleting products on The Range.
As per The Range confirmation, deletion by the user is not possible at the moment (we will be introducing this as a feature later), but we are able to delete products upon request when necessary.The page will be described once detailed call and requirements are provided to us. At this stage, we will consider deletion of product as not applicable.
