Showroom Prive Offer delete
| 1.0 | First Publish |
"update_delete": "delete"
API Docs: {{TBA}}
If error, we will have:
<offer_import_tracking>
</offer_import_tracking>
API Docs: {{TBA}}
API Docs: {{TBA}}
