NordStrom Create Products
Please note we do not need to select all variants if only one them is set for revision or creation because they goes as separate products on MIRAKL and the only thing which associate them is the variant_group_code So we can add variants to a variation group only by specifying the correct variant_group_code If we want to remove a product from a variation we need to push the product for update again without the variant_group_code
API Docs: https://help.mirakl.net/help/api-doc/seller/mmp.html#P41
Complete flow:
If we receive success after performing P42 (when we send product to MIRAKL & When both "error_report" and "transformation_error_report" are equal to “false“ ) we can proceed to following:
There will be two cases how to handle channel item ids in MIRAKL depends on the type :
- The first case is after successful product creation we need to fill the Channel Item ID, which will be the SKU.
- The second option is to use P31 Get products for a list of product references which will map the SKUs between Hemi and MIRAKL and store the MIRAKL id as Channel Item ID.
For BestBuy integration we will go for option 1
If we receive an error (any of "error_report" and "transformation_error_report" are equal to “true“):
Yes |
| No |
Example File:
<products>
<product>
<attribute>
<code>category</code>
<value>accessories</value>
</attribute>
<attribute>
<code>shop_sku</code>
<value/>
</attribute>
<attribute>
<code>variant_group_code</code>
<value/>
</attribute>
<attribute>
<code>brand_code</code>
<value/>
</attribute>
<attribute>
<code>size</code>
<value/>
</attribute>
<attribute>
<code>image_main</code>
<value/>
</attribute>
<attribute>
<code>translations_required</code>
<value/>
</attribute>
<attribute>
<code>product_name-en_GB</code>
<value/>
</attribute>
<attribute>
<code>product_name-nl_NL</code>
<value/>
</attribute>
<attribute>
<code>product_name-nl_BE</code>
<value/>
</attribute>
<attribute>
<code>product_name-fr_BE</code>
<value/>
</attribute>
<attribute>
<code>description-en_GB</code>
<value/>
</attribute>
<attribute>
<code>description-nl_NL</code>
<value/>
</attribute>
<attribute>
<code>description-nl_BE</code>
<value/>
</attribute>
<attribute>
<code>description-fr_BE</code>
<value/>
</attribute>
<attribute>
<code>ean</code>
<value>14536728947656</value>
</attribute>
<attribute>
<code>image_2</code>
<value/>
</attribute>
<attribute>
<code>image_3</code>
<value/>
</attribute>
<attribute>
<code>image_4</code>
<value/>
</attribute>
<attribute>
<code>image_5</code>
<value/>
</attribute>
<attribute>
<code>image_6</code>
<value/>
</attribute>
<attribute>
<code>measurements-en_GB</code>
<value/>
</attribute>
<attribute>
<code>measurements-nl_NL</code>
<value/>
</attribute>
<attribute>
<code>measurements-nl_BE</code>
<value/>
</attribute>
<attribute>
<code>measurements-fr_BE</code>
<value/>
</attribute>
<attribute>
<code>condition</code>
<value/>
</attribute>
<attribute>
<code>gender</code>
<value/>
</attribute>
<attribute>
<code>colour</code>
<value/>
</attribute>
<attribute>
<code>fabric-en_GB</code>
<value/>
</attribute>
<attribute>
<code>fabric-fr_BE</code>
<value/>
</attribute>
<attribute>
<code>fabric-nl_BE</code>
<value/>
</attribute>
<attribute>
<code>fabric-nl_NL</code>
<value/>
</attribute>
<attribute>
<code>material</code>
<value/>
</attribute>
<attribute>
<code>care_advice-en_GB</code>
<value/>
</attribute>
<attribute>
<code>care_advice-fr_BE</code>
<value/>
</attribute>
<attribute>
<code>care_advice-nl_BE</code>
<value/>
</attribute>
<attribute>
<code>care_advice-nl_NL</code>
<value/>
</attribute>
<attribute>
<code>warranty-en_GB</code>
<value/>
</attribute>
<attribute>
<code>warranty-fr_BE</code>
<value/>
</attribute>
<attribute>
<code>warranty-nl_BE</code>
<value/>
</attribute>
<attribute>
<code>warranty-nl_NL</code>
<value/>
</attribute>
</product>
</products>
category |
Product Category | Yes | Product Account > Primary Category ID | |
shop_sku |
Shop SKU | Yes | Product > SKU | |
variant_group_code |
Variant Group Code | Yes | Product Account > Variation Group | |
brand_code |
Brand | Yes | Product Account > Item Specifics |
Product > Brand | Product Account > Item Specifics is with priority.
We need to map the brand_code with the label from the VL11 call in Taxonomy. |
| size | Size | Yes | Product Account > Variation Specifics | |
| image_main | Main Image | Yes | Product > Main Image or Product Account BestBuy > Main Image | Product Account BestBuy > Main Image with priority |
| translations_required | | No | N/A | |
| product_name-en_GB | Product Name | No | Product Account > Title | |
| product_name-nl_NL | | No | N/A | |
| product_name-nl_BE | | No | N/A | |
| product_name-fr_BE | | No | N/A | |
| description-en_GB | Product Description | No | Product Account > Description | |
| description-nl_NL | | No | N/A | |
| description-nl_BE | | No | N/A | |
| description-fr_BE | | No | N/A | |
| ean | | No | Product > EAN
Product Account > Marketplace EAN | Product Account > Marketplace EAN with priority |
| image_2 | Additional images | No | Product > More Picture URLs or Product Account BestBuy > More Images | Account BestBuy > More Images is with priority |
| image_3 | Additional images | No | Product > More Picture URLs or Product Account BestBuy > More Images | Account BestBuy > More Images is with priority |
| image_4 | Additional images | No | Product > More Picture URLs or Product Account BestBuy > More Images | Account BestBuy > More Images is with priority |
| image_5 | Additional images | No | Product > More Picture URLs or Product Account BestBuy > More Images | Account BestBuy > More Images is with priority |
| image_6 | Additional images | No | Product > More Picture URLs or Product Account BestBuy > More Images | Account BestBuy > More Images is with priority |
| measurements-en_GB | | No | N/A | |
| measurements-nl_NL | | No | N/A | |
| measurements-nl_BE | | No | N/A | |
| measurements-fr_BE | | No | N/A | |
| condition | | No | N/A | |
| gender | Product Gender | Yes | Product Account > Item Specifics | |
| colour | Product Colour | Yes | Product Account > Item Specifics | |
| fabric-en_GB | | No | N/A | |
| fabric-fr_BE | | No | N/A | |
| fabric-nl_BE | | No | N/A | |
| fabric-nl_NL | | No | N/A | |
| material | Product Material | No | Product Account > Item Specifics | |
| care_advice-en_GB | | No | N/A | |
| care_advice-fr_BE | | No | N/A | |
| care_advice-nl_BE | | No | N/A | |
| care_advice-nl_NL | | No | N/A | |
| warranty-en_GB | | No | N/A | |
| warranty-fr_BE | | No | N/A | |
| warranty-nl_BE | | No | N/A | |
| warranty-nl_NL | | No | N/A | |
<product_import_tracking>
</product_import_tracking>
API Docs: https://help.mirakl.net/help/api-doc/seller/mmp.html#P42
Example response:
<import_id>2005</import_id>
<transformation_error_report>false</transformation_error_report>
<shop_id>2000</shop_id>
Depends on the response of:
"error_report" and "transformation_error_report" we will need to call each of the error reports if we receive "true".
When both "error_report" and "transformation_error_report" are equal to “false“ is the success case (Import status = Completed) and we could proceed to creating and offer to this product.
If we receive success (When both "error_report" and "transformation_error_report" are equal to “false“ ) we can proceed to following:
We need to perform this call if we receive error_report = true, into the response from P42;
API Docs: https://help.mirakl.net/help/api-doc/seller/mmp.html#P44
Sample file
This call returns if the import is successful and how may warnings and errors we have in the file. We need to call this if we receive transformation_error_report = true
API Docs: https://help.mirakl.net/help/api-doc/seller/mmp.html#P47
Sample file
product-transformation-error.xml
Closed -will stop all the creation of the products to the MPs.
