ASOS- Offer Stock Update
| Date | Version | Name | Comment |
| 29/09/2022 | 1.1 | Bogomil Pavlov | product-id-type field updated |
| 03/10/2022 | 1.2 | Bogomil Pavlov | MP feed type updated |
| 24/10/2022 | 1.3 | Bogomil Pavlov | Error with Case 2 statuses |
| 01.02.23 | 1.4 | Bogomil Pavlov | Split the flow to two separate feeds with and without prices. |
The process is quite straight forward as full offer updates. We are able to send updates to an offer using the call for creating an offer (OF01), but we need to specify the value in update_delete field to be equal to “update“ ( "update_delete": "update")
API Docs: https://asosuk-dev.mirakl.net/help/api-doc/seller/mmp.html#OF01
sku |
product-id |
Unique product identifier for a given product-id-type - Required at offer creation - Maximum 40 characters | Yes | Product >EAN | |
product-id-type |
Yes | Hardcoded as “ean“ | ||
quantity |
The quantity available in stock (maximum: one billion). | |||
| Integer greater than or equal to 0 | No | Product Account > Quantity | ||
state |
The state code of the offer | |||
| The accepted values are defined from the Mirakl back office | Yes | see notes | Mapping to our conditions: |
11- New > 1000; 1-Excellent > 1500; 2-Very Good >4000; 3-Good >5000; 4-Sufficient >6000; 5-Refurbished_like_new > 2750 6-Refurnished_very_good >2500 7-Refurbished_good > 2000 8-Refurbished_acceptable > New state(condition) to be created in Hemi (8000) |
We are able to send stock updates in two cases - once the product is active on the channel and once after we have already deactivated it and would want to send a positive stock. Аfter successful product creation should have Channel Item ID, which for MIRAKL integration is the SKU!
Case 1:
Product status = Product Published; Listing Status = Active; **Update Quantity = Pending**
Once we receive success, we should have following:
Product status - Product Published; Listing Status - Active; Update Quantity - Not Needed
If we receive an error, we will have:
Product status - Product Published; Listing Status - Active; Update Quantity - Error
Case 2:
Product status = Product Published; Listing Status = Inactive; **Update Quantity = Pending**
Product status - Product Published; Listing Status - Inactive; Update Quantity - Error
"import_id": 2035
API Docs: https://richemontit3-dev.mirakl.net/help/api-doc/seller/mmp.html#OF03
