Yoox Offer delete
| 19.10.22 | 1.0 | First Publish | |
| 01.02.23 | 1.1 | Bogomil Pavlov | Split the flow to two separate feeds with and without prices |
"update_delete": "delete"
API Docs: https://richemontit3-dev.mirakl.net/help/api-doc/seller/mmp.html#OF01
If error, we will have:
<offer_import_tracking>
</offer_import_tracking>
API Docs:https://richemontit3-dev.mirakl.net/help/api-doc/seller/mmp.html#OF02
