Marketplaces / Colizey Technical Scope / Colizey - Authentication
The purpose of this page is to describe the authentication process on Colizey.
Basically, there are no specifics steps for authentication - we simply use the APIKey provided by them.
Bear in mind the listed API key below is for the sandbox environment. We need to prepare the integration with presumption we will have different API Key and End point for the prod. environment.
In order to perform authorization, we need to push x-apikey into the Headers. You can find here the test collection in Postman, also the test collection provided by Colizey. Colizey Technical Scope
