Secret Sales Offer Full update
| 1.0 | 04/05/2023 | Hristiyan Georgiev | First Publish |
sku |
product-id |
| product-id-type | | | | Yes | hardcoded as “ean“ | Must be lowercase |
| internal-description | | | The description of the offer as shown in the back office view - Optional - Maximum 2000 characters | No | N/A | |
| min-quantity-alert | | | | | N/A | |
The accepted values are defined from the Mirakl back office | Yes | Product > Condition | Mapping to our conditions:
11- New > 1000;
10- Vintage> 1500; |
yyyy-MM-dd
or
yyyy-MM-ddThh:mm:ss+00
| No | N/A | |
yyyy-MM-dd
or
| No | N/A | |
| discount-price | | | | No | Product Account > Price | If RRP > Price
If RRP <= Price
discount-start-date| | | | No | Product Account Secret Sales> Discount Start Date | If RRP > Price and If we do not specify any dates in the relevant fields we hardcoded current date (“NOW“) Date format -2017-02-20T10:45:53+01If RRP <= Price We include the discount fields with empty values | |discount-end-date| | | | No | Product Account Secret Sales> Discount End Date | If RRP > Price and If we do not specify any dates in the relevant fields we hardcode current date + 2 year (“NOW“ +2y) Date format -2017-02-20T10:45:53+01If RRP <= Price We include the discount fields with empty values | |update-delete| | | Used only in "Normal" import mode. Update mode is used if blank. "", "update", "delete" | No | N/A | |
pricing |
sku |
product-id |
11- New > 1000;
yyyy-MM-dd
or
| No | N/A | |
yyyy-MM-dd
or
| No | N/A | |
<offer_import_tracking>
</offer_import_tracking>
Protect Quantity (Stop all quantity updates) If Protect Quantity = Yes and List/Update the Whole Item = Pending - We pick the product for full update but do NOT include the quantity in the payload
Protect the whole item - (Stop all product updates apart from Quantity) If Protect the whole item = Yes and List/Update the Whole Item = Pending - We skip the product
