Yoox Authentication & Database structure & Limits
| 1.0 | 14/12/2022 | Hristiyan Georgiev | First publish |
Authentication:
- Log into your Mirakl shop; ( Please contact Bogomil Pavlov)
End point: https://richemontit3-dev.mirakl.net/api
Limits
GET OR11 - List orders
CALL FREQUENCIES
Recommended:
Maximum:
