ASOS - Taxonomy
Note: Every time we send products for creation we have to do internal check if all required attributes are part of the the product as Item Specifics according to their taxonomy which we download and store on the instance. Please note that for the ASOS we will have only 5 categories that we will use! Also, there are no required attributes and values
API Call:/api/hierarchies
API Docs: https://asosuk-dev.mirakl.net/help/api-doc/seller/mmp.html#H11
Example response:
"hierarchies": [
"code": "accessories",
"label": "Accessories",
"label_translations": [
"locale": "en",
"value": "Accessories"
"level": 1,
"parent_code": ""
"code": "clothing",
"label": "Clothing",
"locale": "en",
"value": "Clothing"
"locale": "fr",
"value": "Vêtements"
"level": 1,
"parent_code": ""
"code": "depth",
"label": "Depth",
"locale": "en",
"value": "Depth"
"level": 1,
"parent_code": ""
"code": "footwear",
"label": "Footwear",
"locale": "en",
"value": "Footwear"
"level": 1,
"parent_code": ""
"code": "skincare",
"label": "Skincare",
"locale": "en",
"value": "Skincare"
"locale": "fr",
"value": "Soins"
"level": 1,
"parent_code": ""
"code": "width",
"label": "Width",
"locale": "en",
"value": "Width"
"level": 1,
"parent_code": ""
API Docs: https://asosuk-dev.mirakl.net/help/api-doc/seller/mmp.html#PM11
Example response:
"attributes": [
"code": "product-category",
"default_value": null,
"description": null,
"description_translations": [],
"example": null,
"hierarchy_code": "",
"label": "Product Category",
"locale": "en",
"value": "Product Category"
"required": false,
"requirement_level": "OPTIONAL",
"roles": [
"parameters": [],
"type": "CATEGORY"
"type": "TEXT",
"type_parameter": null,
"type_parameters": null,
"values": null,
"values_list": null,
"variant": false
"code": "seller-sku",
"description": "The seller Stock Keeping Unit (Shop SKU)",
"locale": "en",
"value": "The seller Stock Keeping Unit (Shop SKU)"
"example": null,
"label": "Seller product Identifier",
"locale": "en",
"value": "Seller product Identifier"
"required": true,
"requirement_level": "REQUIRED",
"roles": [
"parameters": [],
"type": "SHOP_SKU"
"type": "TEXT",
"values": null,
"variant": false
"code": "name",
"description": "Name of the Product",
"locale": "en",
"value": "Name of the Product"
"example": "Oversized sweatshirt in beige with flower back print",
"label": "Name",
"locale": "en",
"value": "Name"
"required": true,
"roles": [
"parameters": [],
"type": "TITLE"
"type": "TEXT",
"values": null,
"variant": false
"code": "description",
"example": null,
"label": "Description",
"locale": "en",
"value": "Description"
"required": true,
"roles": [
"parameters": [],
"type": "DESCRIPTION"
"type": "LONG_TEXT",
"values": null,
"variant": false
"code": "brand",
"description": "Brand of the Product",
"locale": "en",
"value": "Brand of the Product"
"example": null,
"label": "Brand",
"locale": "en",
"value": "Brand"
"required": false,
"requirement_level": "RECOMMENDED",
"roles": [
"parameters": [],
"type": "BRAND"
"type": "LIST",
"type_parameter": "brand",
"type_parameters": [
"name": "LIST_CODE",
"value": "brand"
"values": null,
"values_list": "brand",
"variant": false
"code": "ean",
"example": null,
"label": "EAN",
"locale": "en",
"value": "EAN"
"required": true,
"roles": [
"parameters": [
"name": "code",
"value": "EAN"
"type": "UNIQUE_IDENTIFIER"
"type": "TEXT",
"values": null,
"variant": false
"code": "image-1",
"description": "Main image of the Product",
"locale": "en",
"value": "Main image of the Product"
"example": null,
"label": "Main image",
"locale": "en",
"value": "Main image"
"required": false,
"roles": [
"parameters": [],
"type": "MAIN_IMAGE"
"type": "MEDIA",
"type_parameter": "1024",
"name": "MAX_SIZE",
"value": "1024"
"name": "TYPE",
"value": "IMAGE"
"values": null,
"variant": false
"code": "color",
"example": null,
"label": "Color",
"locale": "en",
"value": "Color"
"required": false,
"roles": [],
"type": "LIST",
"type_parameter": "color",
"value": "color"
"values": null,
"values_list": "color",
"variant": true
"code": "supplier-ref",
"description": "Supplier Reference used to regroup Products as being Variations",
"locale": "en",
"value": "Supplier Reference used to regroup Products as being Variations"
"example": null,
"label": "Supplier Reference",
"locale": "en",
"value": "Supplier Reference"
"required": false,
"roles": [
"parameters": [],
"type": "VARIANT_GROUP_CODE"
"type": "TEXT",
"values": null,
"variant": false
"code": "skinType",
"description": "Skin Type",
"locale": "en",
"value": "Skin Type"
"example": "Dry",
"hierarchy_code": "skincare",
"label": "Skin Type",
"locale": "en",
"required": false,
"roles": [],
"type": "LIST",
"type_parameter": "skinType",
"value": "skinType"
"values": null,
"values_list": "skinType",
"variant": false
API Call: /api/values_lists
API Docs: https://asosuk-dev.mirakl.net/help/api-doc/seller/mmp.html#VL11
Example response:
"values_lists": [
"code": "brand",
"label": "Brand",
"locale": "en",
"value": "Brand"
"values": [
"code": "adidas",
"label": "Adidas",
"locale": "en",
"value": "Adidas"
"code": "puma",
"label": "PUMA",
"locale": "en",
"value": "PUMA"
"code": "nike",
"label": "Nike",
"locale": "en",
"value": "Nike"
"code": "new-balance",
"label": "New Balance",
"locale": "en",
"value": "New Balance"
"code": "color",
"label": "Color",
"locale": "en",
"value": "Color"
"values": [
"code": "black",
"label": "Black",
"locale": "en",
"value": "Black"
"code": "white",
"label": "White",
"locale": "en",
"value": "White"
"code": "blue",
"label": "Blue",
"locale": "en",
"value": "Blue"
"code": "skinType",
"locale": "en",
"locale": "fr",
"value": "Type de peau"
"values": [
"code": "all",
"label": "All Skin Types",
"locale": "en",
"value": "All Skin Types"
"locale": "fr",
"value": "Tous types de peaux"
"code": "normal",
"label": "Normal",
"locale": "en",
"value": "Normal"
"locale": "fr",
"value": ""
"code": "dry",
"label": "Dry",
"locale": "en",
"value": "Dry"
"locale": "fr",
"value": ""
"code": "oily",
"label": "Oily",
"locale": "en",
"value": "Oily"
"locale": "fr",
"value": ""
"code": "combination",
"label": "Combination",
"locale": "en",
"value": "Combination"
"locale": "fr",
"value": ""
"code": "texture",
"label": "Texture",
"locale": "en",
"value": "Texture"
"locale": "fr",
"value": ""
"values": [
"code": "cream",
"label": "Cream",
"locale": "en",
"value": "Cream"
"locale": "fr",
"value": "Crème"
"code": "gel",
"label": "Gel",
"locale": "en",
"value": "Gel"
"locale": "fr",
"value": ""
"code": "lotion",
"label": "Lotion",
"locale": "en",
"value": "Lotion"
"locale": "fr",
"value": ""
"code": "milk",
"label": "Milk",
"locale": "en",
"value": "Milk"
"locale": "fr",
"value": ""
"code": "bi-phase",
"label": "Bi-Phase",
"locale": "en",
"value": "Bi-Phase"
"locale": "fr",
"value": ""
"code": "mousse",
"label": "Mousse",
"locale": "en",
"value": "Mousse"
"locale": "fr",
"value": ""
"code": "spray",
"label": "Spray",
"locale": "en",
"value": "Spray"
"locale": "fr",
"value": ""
Taxonomy export file
In order to generate the taxonomy file we will need to create a new record in Taxonomy export with: Marketplace = B&Q Status = pending Category for Export = all (or we can specify which exact categories) Email = email to which the file will be send
Please find example file structure how it should look like after exported. We store for each category separate file.
