Decathlon Authentication and Database structure
Summary of Changes:
| Date DD/MM/YYY | Applied changes | Comments |
| 04/05/2022 | Typo correction (NL-Netherlands) | There was a typo in previous revision in “NL-Netherlands“ |
The whole authentication is happening with API key generated directly from the seller account on MIRAKL. We will need to use this API key as a Authorization header.
End Point: https://decathlonbelgium-preprod.mirakl.net/api/ If you need the API key please contact Bogomil Pavlov or Maria Mitreva (Unlicensed)
Please note for Phase1 we are doing only GB Channel that`s why we will have it as default value and only GB will be visible in the Account Decathlon > Channel dropdown.
New Tables and fields
Account Decathlon- Slave table of Account table used for the account setup
| Field Name | Type | Required | Comment | Default Value |
| End Point | varchar | Yes | The API endpoint to which we are connecting | |
| API Key | varchar | Yes | API key required for the authentication | |
| Channel | dropdown | Yes | Because we can list one offer on many channels we will need to add a dropdown list with values: |
BE - Belgium CH - Switzerland DE - Germany ES - Spain FR - France GB - Great Britain IT - Italy NL - Netherlands PL - Poland PT - Portugal RO - Romania HU - Hungary CZ - Czech Republic We will display the full country name and push the code. For Phase1 we will need to display only GB | GB |
Item Account Decathlon -Slave table of Item Account containing all Decathlon specific fields.
| Main Image | varchar | N | ||
| Additional Images | varchar | N | this field need to have the same logic as Item > More Picture URL | |
| Discount Start Date | date | N | ||
| Discount End Date | date | N | ||
| Free Return | checkbox | N | “true“ or “false“ | false |
| Eco Contributions | varchar | N | this field should have the same logic as our Item Account > Item Specifics. |
We can have more than one and need to push it as: ProducerIdentifier1|Eco-contributionAmount1, ProducerIdentifier2|Eco-contributionAmount2 Which basically is Attribute Name|Attribute Value | | | Price Additional Field | varchar | N | Additional text message for the price | |
