VeePee Zero Stock Update
| 13.02.23 | 1.0 | Bogomil Pavlov | First Publish |
| 28.03.23 | 1.1 | Bogomil Pavlov | Added better error response |
| 03.04.2023 | 1.2 | Bogomil Pavlov | Response Mapping Added |
| 06.04.2023 | 1.3 | Bogomil Pavlov | VeePee Status details added |
| 20.04.2023 | v1.4 | Bogomil Pavlov | Listing Type updated |
The purpose of this document is to describe in details how we will send zero stock updates
Stock is shared for all different channels on the VeePee account, so if we sent zero stock for one SKU for FR it will be zeroed out for all other channels.
API Call: {{BaseURL}}/stock
API Docs: https://pinkstaging.pink-connect.com/swagger#operation/uploadStock
We use the Shop Channel Id from the Account > VeePee as header parameter.
We use the Incremetal Quantity always set as true as query parameter.
(Default: true
Default true. When set to false, all products that don't come in the file will be set to 0 stock.)
You can generate a csv file and upload it via API. The file must have these headers:
- gtin: The gtin of the product when it was created (Required when sku is empty)
- stock: The amount of available stock for that product (Required)
| Field | Required | Hemi Field | Hemi Note |
| gtin | Yes | Product > EAN | |
| sku | Yes | Product > SKU | |
| stock | Yes | “0” | Hardcoded as “0” despite the stock in Hemi. |
We pick the offer for zero stock as per abstraction - Stock Update general requirements Please note that Update Stock and Zero Stock Updates works is a same way and if we have both flag set on pending we want to push only the Zero Stock Update to the Marketplace. (In cases where closed is not set as true). Also some Stock Updates may be also zero stock updates so we need to be careful and follow the correct flow.
"INC_STOCK_20230215103536"
After each successfully send feed for creation we need to store the filename which is returned from VeePee in the response and need to store it in Marketplace Feeds table. All products that are included in the feed need to be marked as Product Account > End Item - Sent
| VeePee Field | Hemi Field | Comment |
| FileName | Marketplace Feed > External ID | This field is used to get the response of the import. |
| Marketplace Feed > Type | (v1.4) Hardcoded as “Listing Stock Update“ | |
Get the import status for a product import
API Call: {{BaseURL}}/status/{filename}
API Docs: https://pinkstaging.pink-connect.com/swagger#operation/getFileStatus
UPDATED: the change was successfully imported (we treat this as success)
SKIPPED: there was no change compared to the last feed (we treat this as success)
NOT FOUND: the reference does not exist in Pink Connect (we treat this as error)
ERROR: the data was not imported due to an error (we treat this as error)
*Example pending response:*
"status": "PENDING",
"result": "ok",
"errorList": [
"string"
Example success response:
"status": "FINISHED",
"result": "ok",
"stats": "OFFER [ ERROR :0, UPDATED :2]",
"errorList": []
Example error response #1:
"result": "ok",
"stats": "OFFER [ ERROR :2, UPDATED :0, SKIPPED :0, NOT_FOUND :0]",
"errorList": [
"line: 2 gtin: 123123123123213213213321 reason: Gtin: 123123123123213213213321 => Invalid stock value: \"a\" ",
"line: 1 gtin: 1234567891013 reason: Gtin: 1234567891013 => Invalid stock value: \"b\" "
In order to store the errors on each item we need to map the GTIN on each line from the response against Product > EAN or Product Account > MP EAN (MP EAN is with priority) and store the error message which in this case is “Invalid stock value“ on the correct product account.
Example error response #2
"result": "ok",
"stats": "OFFER [ SKIPPED :0, UPDATED :0, NOT_FOUND :0, ERROR :0]",
"errorList": []
We can receive an error without lines as well which we want to treat as full feed error and mark all products (feed objects) as error
Example error response #3
"result": "ok",
"stats": "OFFER [ SKIPPED :0, UPDATED :0, NOT_FOUND :0, ERROR :1]",
"errorList": ["Format structure unknown"]
We can receive an error without lines as well which we want to treat as full feed error and mark all products (feed objects) as error with the relevant error message
Based on the response we need to map each product and we will have to update the products either with error or success as well as the Marketplace Feed > Status and Marketplace Feed > External Status. If the product zero stock update successfully and we do not receive and error in the errorList from the response we want to update: Product Account > End Item - Not Needed
If we receive and error and the product stock is not update: Product Account > End Item - Error Product Account > End Item Error - store the relevant error message
Any Triggers or Validations that are not specifically mentioned, changed or removed from the above mentioned scope should follow the standard flor as per the Stock Update general requirements abstraction.
