Catch Taxonomy
The way we need to optimise the products is we need to use the Hemi Name from the taxonomy file as Item Specific Name or Variation Specific Name. The same is the case for Item Specific Value/ Variation Specific Value we are using the Hemi Values from the taxonomy file. Each Attribute need to be added as Item/Variation Specific. Please note that there are some root attributes which are applicable for all categories even if not included in the taxonomy file. Such attributes are: ”variant size value” no required enumeration "model number" no required enumeration "season" required enums are - “Summer“, “Winter“, “Autumn“, “Spring“, “Cross Season“, “Cross Seasonal“ "adult" no required enumeration "restriction" required enum is “Sensitive “ "keywords" no required enumeration "gender” required enums are - “Male“, “Female“, “Unisex“, “Girl“, “Boy“
Please note that the attributes and their values are not case sensitive.
