Fruugo User Guide
Fruugo is a global marketplace currently operating in 32 different countries, across 17 languages and in 15 currencies. You can access the seller central from http://merchantcentre.fruugo.com/web/guest/home
Our current integration is via API/SFTP. The functionalities we have developed are:
- Download orders from Fruugo
- Confirm, ship, cancel and return items
- Download packing slips for printing
- List Products
- Update Products
Account set upNew table is advertised Account Fruugo where we set up the account details. User name - Fruugo account username Password - Fruugo password Language Default - The language we use for optimising our products. (Default if empty is EN) Then we have to set the Shipping Template from which we can send the dispatch time. Please note that the Fruugo integration requires every seller to be on a separate account. Thus if you would like to integrate new sellers please contact Support/Integration team.
Products
Item Account Fruugo
Country exclusion list - tells in which country the product is not available.
Every day we push full product data to all products which are available in WAP to Fruugo.
There is NO specific optimisation required for Fruugo and there is NO available taxonomy for this MP.
The product creation process is as follows: Every day we generate and send a file containing all our live listings which are with list/update status different from "error". The validation we have before sending the products are:
SKU_MAX_LENGTH = 50,
VARIATION_MAX_LENGTH = 50,
EAN_MAX_LENGTH = 14,
CATEGORY_MAX_LENGTH = 250,
IMAGE_MAX_LENGTH = 150,
TITLE_MAX_LENGTH = 150,
DESCRIPTION_MAX_LENGTH = 5000,
PRICE_MAX_VALUE = 99999,
QUANTITY_MAX_VALUE = 99999,
QUANTITY_MIN_VALUE = 0,
MAXIMUM_IMAGES = 5
Then Fruugo optimise the products and if they are successfully created we will receive "Not Needed" as List/Update status. If there are any errors we will receive "Error" as List/Update status and Item Error with the relevant error message. When we send the products for listing we push the whole product information including price and quantity.
Please note that we are sending VAT as well and depends on the category the relevant percentage should be applied
We are able to update only stock once the products are live. If we have a product with List/Update = 'Not Needed' and update quantity = 'Pending' this will trigger the stock update. Any other changes in the products like title, categories, description, price have to be pushed with the daily product update/create. End Item - runs with stock update cron and set the product status as Out Of Stock.
- Orders Every time we get new orders from Fruugo we download them with "Pending" status. Then we have to confirm them with a separate cron which runs aromatically and if all the details are correct the order status will be set as "Ready For Shipping". If the order is Out Of Stock we still have "Ready for Shipping" status but the order flag for OOS will be raised.
In order to ship an order we have to set the carrier and the tracking and raise update shipping pending. There is NO specific list with carriers we have to use.
We also can return or refund orders depending on their status. The available reasons for cancel order (before the order is shipped) are: 'out_of_stock', 'product_discontinued','invalid_delivery_address','customer_cancellation','legislation_restriction','other' Which we can specify in the internal note. The cancel order is when we have a ready for ship order and we need to cancel it because of the relevant reason and set an order full refund or partial refund. Please note if no internal note is set the default reason will be 'other'
The available reasons for refund order (after the order is shipped) are: 'unsatisfied_with_item', 'item_did_not_match_description', 'damaged_item', 'wrong_item', 'other' Which we can specify in the internal note. The refund order is when we have already shipped order and we need to refund it because of the relevant reason and set an order full refund or partial refund. Please note if no internal note is set the default reason will be 'other'
<img src="/public/temp/aa4eb9e612a727d809a164a460ef468c.png" alt="">
<img src="data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAkYAAAD6CAYAAABESohLAAAACXBIWXMAAA7DAAAOwwHHb6hkAAAgAElEQVR4nOy9d3BjW37f2TMaTdZEyRrZ3vVqg72ybEtre732urbs2lVt7Za1f2yVN+cqlYKVpqSZeTMv9wvd/TonNnMEEQmCAUwgQTDnnEkwRzAARCaI+Nm69wIk2M0Oj69faPJ8WD/i4oZzzz04OOeLE37n0sZekNNsfVeYSAORB0QeEHlA5AGRB0QeCF6oNLh0QhDt+lmXbC+IY/+AXXfo1bf9ILvuc/IswkQaiDwg8oDIAyIPiDzAp5kGx8JoN8C6O8q2L0EomiCOQCAQCAQCwcVCEUa7fjbccTYn2tnN+Bfs3fiP2b3xd9m58XfZvSnZ35Nt79Z/qtjt35LNeefvy+a6+9tJ+we47im2f/8fKvbgH+GW7OHvJO138WT8Lp5H/5ls3kzJ/rFiWf8EX9Y/xZct2X+OPydpuf8saf8FgTzJ/jnBfMn+BcECyf5L2Q4K/yUHRYqFiv8rQkX/krDt5yQiB8nHTXzOyS0QCAQCgeCLzCWppWjDGWJj28Xmtd9i888usfGTL7P515fY+skltn6qmONnSXvtEtuS/Vyxnde/xO6bX2H3jS+x8/qX2X3rl9l76yvsvf1V9t76Jfbe/gpOyd79Bq7L38R1+Wu43v0arstfZ//yN3C/l7QPvo37w1/B88G38Hz4bdm8V35FsavfwSfbd/Fd+y7+j76n2PXv47/+AwI3fkDg5g8JSnbrV2U7uP1rHNz5EQdXv0qk947ytPHY553eAoFAIBAIvsBcSrUWbSxMsfnal9l67UtsSa8/l+yXcPzil3C8/hW2JXvjlxV786vsSPbW19mVXn92id03v8HeO19n9/VL7L71FXZf/xJ7l7+F871v43r/V3C++WWcP7+E651vsv/h99i/8gPcV38Vt/R67W/g/vDbuC9/Hc+1X8V7/dfxXv8beD/6Vbw3f4RPshu/ju/W38R/6zfw3/p1/Ld+ROC2ZL9B4M7flC14928pdu9vcyDZg/+Ag1vfJ1z9fytPK4SRQCAQCASC5wqjfUkYTbMpi6JLSVH0PGH0dXbe+DK77/8tvLr/Gee1b7D7+vdx5/337N/7HTzF/x2u97+F8/K3cb71VTyl/xvB+r/Gm/2bON/5Kq63fwnX65fYf++b7L9xCfet38Kv+W/xfPAN3G9dkluRvB/9EM/lL+G9/Et4r3wL7+VLeN//Gv6bP3pxYXTze4Sr/59zK4wSiQTxWPzVsXhCjrNAIBAIBK+IMPrSkTCSRdGRMEqKojeSrUVvf5Ptn1zCU5UhBxQ0/x7bf/kjwvNLHFiuEd2dwnPtu3ILkq/hConAHOGpCuKHK/iL/yFe9f9FqP19/AX/moDxjzmc6yC2qsFz+29x0HqDA+Pv4b3+axw0vMlhy2sE1f+GUMsVQvV/iP/2rxOQhdFvHAmjYFIYyYJIsvv/3rkWRglZYPCKx/8VfgCBQCAQnEvO2GL0NXbe/BLbb/8moYVuQn0FhO1Z7P71DzicmyTY8C6RzSE8V77O7hs/IrK9SND0W+z8ySUCAzWER+9wuDZHfK2aUG858e0xIkttRO1aQgOVJFyLxP0LhKr/D+KHfiIjdwgvjpM4WCPS8zP8d1Ndab9xIVuMUoLiMBhhvG2ZDuMkzeoxbJovuGnH6KmeZnlyR3mOuBBGAoFAIDgPLUZvfUMegL2X/X8Sjx0SWR+D6Crum79LaGqMg8b3iThG8Vz5JrtvfJ/wxgKhxn/N7k8ucTDdS3jwMofLfQSKf5vAQC2R9r/AU/KHRFd7CE9PEluzEllo5LDlXWI7Fvz3LuF79PscDumJLpYRzPsH+K//UBFEF6zFKCWKdtc91Ob2M962xN66B+9e8AtvHmmgv91Jm2GCVt048ahwCiEQCASC8yCM3v46jr+6hH/IRmSpkP1H/4rDzQUOGt8hNNrJQeNVIttjeK5+l703LuHR/xHx4AZRxyhxTy/ezP+QsGOBg4p/hSfnj4l7PSQCQWLz+QSbbxLf3yAy9YiA5r8m7h0gkP0Ngg3vEVufIOF1ECr6J/g/+sGFE0YpURQKhDFn9uJ1KW4IXqUuqVRch5oW6CifVPaJliOBQCAQfLGEUSwpjL58oivt6WOMfpmd17+J88Zvs/f+t3D8+BJ7H/z7uG7/HVw3/iNc1/42rjt/D+d70qw0ZUba/t3fxVfw37D/0a/gevsbeB78Izw3f539d76JN+Of4cv75/ju/6Y8Zd9X+HsE8v8p3hu/gT/7d/Dd/B6++3+foPb3CWT+J/g/+j6B20lR9CLCyPz/ng9hlBQQU92rzPVvyNuxaPzVEkZxabC4Et/2sgn8+6+euBMIBALBRZiuPy9N1/9K2lT95wy+fuurbP/ikjw7bffyryhT9N/4ZflV8WH0lbTp+t/F+c4v43zzS7je+648XV/2Y/T+d3Bf+z7u97/OvuTL6MPvytP1Pe9/Hc8H35ZnpXmvfEeZqv/R9/F++E18H/0QvySGXnTw9a0fEK56mdP1E8TjyS6gRNp26uipFbwkBmLEYjH5/MfPSSTiR64nnyUQUsKoxzyD3x3iVUWamSYx3bPG8sT2qa1GUprEYlFiUnql0iiROGHPvkecqJzej5/35LXHYb6UxxMIBALBq+7gcd0VZmtjHcfbP2Ljx+mDr58ljr7GztvfYvftb7D71tfYfedb7L77Lfbe/TZ70hT9976DUxJG8va3cX3wPVwf/gDXh99l/4PvsH/lh7g//B7uD7+P+9qv4ZHso1/Fc+2Hx36Mrv8a3pu/jvfGr+JN92N0Uxl8Ldsp4uhIID34Oxxc/WUizT/7lFqMlJpUqlRl0ZOsWZVK/fj9qVcmrzk+RXmfPJg8dvL6VCVvVY0Q9B0+EZ58/mdQwZ8uLF78+tRzTHSsMNO7dmLfqfd7ShykNJKEk3K9sv3EuXKaHH8m8tvkjDhFqD6WxmlhCgQCgeCCLgmyvuNj2w/Bvhwcb39H9nq9+ZMvvZjna6nV6HXFA7bs10iyN7+seL1O93wttRi981Wc7371FM/X38T9/jdxS16vX4rn619TPF/f/RGHun9DwqtUviQ+QYWXrPljIS8zk9NIEubQvcHk/Era4Ri7Thfho9skK934IaP9HdTW1TNhX2DP4yd93LFrd51AWDo3xpZji9BT9NuRMCod4cB/UhhJRCNhwpEnL47GohzX/4+JGFkgpB9PxvoUNRKLhgkeHCZbcBInXpWgjraIRqUwj4Vj+muqK22y80lhlDrHv7tMc0MN7YOThGNx3HubbO462dtz4HLt4j9Qnl+Ow8nHkVmeHaGhwcLI7Mpj947g2vKknZvA4/WwvbOJN6C0womGI4FAILjowmg3gCM5kDce2CXqGCe6Pfl820nZ1JHFTrPdlE0/3/YUi+/NPN+c6Tb7mM2QcM2TiD0pIM6C1OIgEXYM8pM//zEbhzBuKeD1u5n4PG4s5lrsaxuMTk2zaB+nsbqawZl15ZqdGa7ez5JF1ObaPN3jc3g9TmxNtex6D2ivKWB6fZtBayWX7+SysL5Om6WRhR3fyUr9FGGUOhbxbqDJfMDdQg2zc+MUlqjZDUpxjjLQ38aWL0rswMe+N6CcfxjE6ZIEQoKh/jY2vBESh0E8/qByPOjD7fPLThkl9ub6ePf1KxQUZKCu75b37bv2CAOrI51YrP2yoPC4pTjHmJkYY6i7mVJTo3yuZ3+fw6QafJYwklp+JForH1JU10pbpZ6WvgkWxpvJL6+lsrqE3sEB5hanaW1twNY5Spw43bY6mrp78MuXB3l4/ybW/nGMxZkMLzvxOeZo7uhlwz7Khz+9h8PrpqO+juG5JRZXVqirKqR3cpbJwW46+meS4lBIJIFAILjYwkiulM5ZZSAJmk/SUpQKJhnGwd4M+Q+v0tQzR3u1ljKLGfvsONriAkpztVR1dFGUc5dykwm1ugRZZuzPc/X6R5gsHeztbWJqaECnLSQn+wF5ag19nbWU6tXUNzWjMVVgrlZRqi5nYs35fGGUFBL7M83829//H7DO7BDcGOEXf/UXXLl2h/7ROSorCzCYDNz58DrX7mXQ2d/L/Zvv8dFHt2iw9VNlLkJfUcada7e4fieLmdVVim/f4J0rl3lU3iOHv9hj5q3blVI7Gbc+uEpHXxcP7l4lS11D8e1f8NPLuawvDfDan/wh2voWLNUmyg0aCrTVtNRm86c/fZOe6S05rFg09lxh1Fefy83sfCoM5YxPTtBUnYeqrpUmq5E2mxmNKoMcjRFdZTmV5iqabFaKC24x5ZQ+pwAlag2uBLhnW6mqKaM0P4es7IcUqUspL7aysj5LhaGUooclmGztVNbqaWtuQputonlgnIiSup843wgEAoHgFW8xkkVEPHp+7CX96k8JI/fyANX1ejLuP6JYVUGzzYDZWE5+fj759/LQWVswlBezsL5BU1UxUptMfGeSG1lFbHpCRH1baKsryc26SbG2DLPFRlejmgdFpcwsLWOsKqd/ZI5mUxnVfbPJj+Tpwih9f6/pEf/j//6HWNts5OaosJpNFKjr0Gjvk5n7CH3dCGOt1Vy9eYNHReVs2we4ff0OmaoMsvOyKDE0UV2ZzYPsh9wuqGWwrZZrORY57KW+ei7fr5G3Vfdv8s7P/4qrN+6Sl1+MPjeTumorbU215N25w92sIkpLCtBqtaiMtfTYyviLv/xTdA19LyyMWqoy0LVNsDLeQompQhZGOSYLNbWlNFuMFGuL6BpfY2Ckhdz8PEbn1+lsKmVqNyoLo0c5uezEYNymp6LaTO7NhxgqK6hvqKOpoo/BthryCgrJvfkIXVMbekMunUOjTHe1U1Jdz34yeUWjkUAgEFx0YSR4pjDyO+aYmB7DVmmid3KKmek+OhprUOn1tLU20jo0Tne3la2dbYZ6bXKLUcy9Sl1bvxJQZJ+W/lFWl6YoLsqhe3QJ+0Q39rlpVHn30VW3Mt7fQ1FRKf3zyoyt+DNbjJR47SwMoy03ce/uXYwVleSq9TRVGclX16PW3CO3KJ8b797iTuZDqurruPbh6zy8n0GZsYEi9T0yc7OoqG7BoL2Htt5Czu0H3Lp5mQ/ymuTwV/rr+fMfX6W5sZycwgrGu+t46713MDQM0Vuj4upHN7h77wpX336Xm/dzKS0pRKspJbvEyMx4H7ff+xk/v1qoPEck+gxhpDzPXJ+Zh5lZqMqqmF5YZLS3gaa+UQaH2hkf6cbWYWVydYfxqRFmlxbRFd7mjfc/ZNkrXR2jypDPw6xcVOX1cuvP1EADBSVqFtZWsRoa6LA1UKrV0Gyto3VojO5eG1OT49QadVS09B61GIk2I4FAILhYCGH0CUgbdvzEtP0XuVpeUPXUQ0p4jx87vcUoGUYizPTYIJMr28RiEZyufQI+L659L6FIiKFmPfcySllzHeLdmuLa9ZuM2teIHEbxuPdw7e/j9fpxezwc+re59+Fr/OFf/ISGviX5LpFQgIXJcQZGRtk/kFp14szPTbLs8ED8APviAk7nBhOjozicLjxuNx6PG7cvSMi7zdjoBIEDRRClxi2dJozO5PDSuYKxNIfGrvGj9Dvt3NiJeySIJ2JPpLEkNJ81m1AgEAgE5xshjD42ylTveLICTW2nv6amrx/N0jrhd+ekL57U1PFjPz0n/fV8nFlpSuind/9EwyGCB+FkV1aEQCD4jL6iBF63k60dF9HTjiakZ0/zvXR85+ck3fNnpaXf49j9wJPpoqT1010FHM2EO/pMHv+Mkq8nPrM0e/aTCAQCgeCcIoTRK8SzhVHSr4/cGiO1hqQExHHrk+LL59g5pezXJ62VJCUUjltMlHDSz0/3vXTkB+jIJ1DSf9MpYkMaVxT/GMLo46D4JIoeP5tAIBAIBGdECKNXiBdpMXoVeNnCSCAQCASCl4UQRq8QQhgJBAKBQPDpIoTRKyiMmtWjHPiV8UKvcovRVNcqM32KE0zRYiQQCASCLwJCGL1CpMRDQ8EgB4+tlfYqkZqVNta2JHenKftEV5pAIBAIvuDCKOVYcG12l5qsPppKhmksGhL2OaZBQ/4ANs0orzKpfLW75qE6oweryFfiOyXKFZEHRB4QeaDoi5EGosVIIBAIBAKBIMkXXhhJK0R83quKfNEsFkkQj5yP55Cf5QsQlxexl7DknkAgEAi+4HzhhZFAIBAIBALBZ8UXXhjtTsKiFZZbYblFmEiDzyEPtCp50L2czJRinLhAIBCcW76QwijVZeHbhA++A29cgne+BG9fEnbWNHhLpN2Z0+6dL8NrlyDzH6cy6Of57RAIBIJPB2kVgeDh8UJQ6dsXiS+0MHItwuuXwF4DYT/4NqTV7YWdJQ22l6P4tiCwDTvLUbybCZGWL5Bu3nVlfFHTz+DaDz/vb4ZAIBB8ekjLNvmTi31L+IKRC5ncX2hh5F5ShNFaV3K/tKi74EwEwpGjhVWD4ahYQf4FkQa5S7S+B9e+LzKfQCA4vyQeE0b+AyGM+KIJo30hjF4aUgZPCSMp4wtP02cQRt97eZ+HQCAQfNEQwugVaDESwujlIYTR2RDCSCAQXBSEMDqHwigRj8tdRNKHG4+f7nRG2p9sOEle9PRzE2lhya8nLvzkJBJKXFLxfs7JT43nyxJGqSikzkvwWFpdQIQwEgguAlJZHz8u66XXl3yHVJhP1EHPipUcp2ednCAeix3VI5+0vBbC6BwKo8eJJwXHcWZPnCJ4OLFPWq7iWZkrPfPJgiaeHv7xF+vo/s84fjLgtOPJ1xNf0lPE3BPC7RkC7nnC6CAYJBSJEzo4JBoOs7E4h+sgDIc+5u12AmHlQ7loOkkII4HgYpISSsk3p5bjjx8/KpfTyn7lcOJE2Zmqj+R7nFKep18r8UQZf+JHsnLd0X2O7n8cznHcHt8+WaILYXSOhJGUCSQWB1rpn97k0LmIpalb3heNKgONlXyToLOxkblNn5TVkK5KHPoY6R0iJO2JRohKGSWZyQLONao0Kipae1mdG6ele1zef+jZYXpqXlH/0dix4IrH5H1Rv5PpKbtyPBY7EipSZowlxZfETK+VwmIVWq2eDbc0mCVOJJIa+CZlWumBlXMPdhdpau1ic2Od5Q2nvC8Wi5341fAsniaMUmm3PN5Lz9A4k+MjdHXa0KsKKK+uoaG5Dp2hiqV1t3L+BWtCEsJIIDjfKCVajNEeCwVFBpZW1mlpqWcroBxfmJ1ixxuWz4ymlbOR5GLYS3NTbHsOnyiTU9upInN6qIsytZ6aphb8ctEeI/qUxbNT1zo3FxieXpe3o5HjSTNH5XBol9JiHfuhA9qb6tnwSPWHVOc83jigtCop4YSf2kMhhNE5EkYpUTBQkY+xdRrfygAFuRpsbTVk5xZiaOzAub6IviSPtz74iJ7pFfrqdDwsLmdmuJXX/vpNxheWqFGrMDXYCCS1yVB1Lq+9c4PNwCGzXTV8+N6HaMstzM1M0Gxppq/LSkF2ARqzFfvUMKr8bFRqEyPDw7Q0NNHWUU9+YQmVlk78+5toC/PJKChk0K4ImzpNJtZJJ9NWNfmVVvq76ijQ1rE4P0eVLo/8Eg3TK3uMdNeSde8WD/J1jAz1Y21qoaa8mPxiNZPLe4x2mcnNyqG8roM1+zBma28yHePPbzFKfUEOdqnQaemdstNSVoqmzExdXQ0j05O02SzMLe4lTxfCSCAQnBNSLTkH6/zkJz/G1DZDwr/NvdvvczurmL7RSTpbmxgYGqFcnUNecRFjU3bqqrVk5Rdj6eqlo8VK/+AIZn0++SVaZtecDLZVkpedi6HKKt8muDHO7XsF+OOwtbbEnmuHer2WIr2JdccmTeY6ZmbHaLF10dFeQ25+CdbOfmpVD7iSoaeloQJtWQ260grWtzapLqvEKwUc3uRP/5f/ifyqFkpLChlf3qS9QkWOppKRwTYK1TpUqhLUqkLqbGPsOWYoKSmkudfO4kQrNd0TcvzSW7b8YlbaORFGcssKDNWUUte5wMHGMLoSLUXqHIaWN6koyefuvQzahmeorzBQ19JNl6WcK9eu0t4/SK2+nLqqEu5kFVGQl83srvTrABIhF5nv/YQrBVWMdlgor7JQa67EZKymqsyEqUxF2+gStioNuTm5VFj6sA82c/fOAyrLKlAbCqhp7aZSp6a8TEO5dYBGUynV3Sty+K0VhTws0FKhN9JgLuP2zTuoNTpMhjI5M7e3NqNV6ykqKMZun0BnKKfd2oCuVEOpqpj2Nhs6tYH83BymZ8bJysrHn4DDA6n968W70lLbDapMelfduFcmMOjUtPQMMjXWi0lnYHhiI/nZCGEkEAjOD6lycaLNwB/9+U8Zm5qiQF1MV2cHBp2OsnIjjQ31qEoMrC8NkZObyYPCIuxbG5RkZpCZX4rN2khpSTFtrc3oNHry8wqYmR7mUWahHPbmmJW7OXVH9xxtUqFuHWd+sJmCIg26Eh0jA90YDWb0ZQXUt/Vg1KlpaGjA0jZKhSqbkbUAo1Y9GY8yKC5vlMOJ7i+RnfGABzc+4p3rDxieGKe5WsPtO7coUhdgaumhRldAfWs72hIdqqy75BaXkpNdwnYgQiQcfiIt/EIYnQ9hlGoZWRtuIktXTYelmsqaFkxl+RhrGylVq6mtqkKrM5Kbn0t+QQmFRSU8fHCTtt4Bih5lYrHW8PBBDrXWFtxKqygLM+P0dNm4m5FNVXk51Y3tNFRWUKavoMJgpLbagN5Yi0anobaqgmK1llqTCU2pmnKNHp2xgPaBYfSqIlpamykrr0VVmEld/5ocvkWXRVF1J5E4BLemuX/3OvqaNsZ6OygtLqO/qwm9wUyZvhCT0UBOkVYWRqXFpei1FfR3W9Hpqqk0qWmoqyUrR8umY4W+4eknWnee12IU8TpotNrwyUkZw7XjwHcYJRo6YHt7R+52vIiIrjSB4BxzVP5tMzzQR3lhFnq9kUJ9CQMDvWg0anQGA1arjaL8XOprKiivqKSgJJ+aBgulahUlpRosDRbKNBX0dljkMrvCpMZSZyYjsxS5AyKwSV5mLoNj03R3tzPQa0NtqKG+2kBzVx/lJQWoNSpU2hpMpgI6BobRaUppqK+mVFdDmSqH/tVD8M/x4z/5EzrnlaEN4d1p7ufqme5r4A/+9C+prK4iJ7eAvOx75BZmU9vVT52hFFtXJxqVgUazloe5Bdg6J1lbHKNvWlnnKH2Mkl8Io/MhjORj8v8I06M9NHeOQCKKvugmpdVtrO24JG3NxEAvvWPTeL1eJoZ76OgZwn8QYmZiiPW9feaGB5hYUESLRHB/k5bWFuyb+wT2d1h37LLj2GJ9fRP33g4N5QXkqqpZc/lZGrRy+0Eu43Or+H0e1ldW2dhcZc+1z8bmFnsrk1y7/Cavv3+d0RW5EZTtjWUc+8fpvrU0Sc/wDMGAl7XVdVzObTZ3PAT2N+ju6GZhzYFzd5v11TU5Ds69bZyufSymLH7x2s/J01nw+53MJp/hhYRRkngsSjg5vunkQL6TKXzREMJIIDjfKCVblNnhHjr7xjgMh1hZXWZ/f5/1tVU2d5ysTvbz4OYtOsbnifl3yX70EZXNA+x6PGxvrePY3mFjfZO93W1cLhc1+oe8/tovyNcrLTsSftcWXTYbw9N2+f3i2AB9o8qPWMfiLJ3dfaxv7bG5ucLevluuA3yePcaHR5hbWMQfBtdSL1fez8STrAsTYT/2xVUSsQjz9lm8Ph+jA130DY2ztraMw7nP9sYauy4nKyubRCMBBvu6WN724d1dZnZtWwlHCKPzKYxOXJ8caL2zvYEvnBoA9+yK/bnHnwgfXLsO9qXcKokor4udXc8pYSVFRvSA+blp7EtbqT0v9jDPjLPy6tnZYHJyAqf/4Kkhv9B0/Qsqfp6FEEYCwUUmKZtCfhybO8q7eIStrQ1CKXGSfnbyzf72GpOTk+wHD9NmpaWdmVZHvMi4zdQpm0szrG64nrjuRcd+vkg96BctRudPGEnjjaSZA4m09ykRIA3SjsWU6Y6xtO3UzDH5NV0wyOcpIuJoGmTadEcl/Dixoymb8eMwH59uf+IBU8GfnLovdQlK1z8+HV+JhxK3J8J+TISddbq+4Cn5SXi+FgguBFJdkZoNll7+pvzNpWaaHdUtsv+g1PHHymwZ6fWkeFHqk1TdodRBx2W/Ug8pLmGOw1PK/jSXLY+V+el10VHdlpqif/QMqfOSz3BUl4np+hdCGKXzcRxpnYV0YfN8B5DHGfbTiIf8hXvG/YUwOhtCGAkEgscd7D7PAaRUJkuuYl72LN70H/qfBqLF6AIII8ExQhidDSGMBALBRUEIo48hjFKtIZ+VxWSnVwlciwlZGK12Ku9j0c82HufJfMEIMakrjgS+gwjRWNLxl7BnpkE0rOS9lsuJ5CKyIs1EnjnfeeCT8FnXFcJebhpIPRo+adgFx/XGRUzjFxJGkodPaVxKIPTZmD8Y5ZAomzNRWRjZW2JEiOIPfHZxOG/m8h3Kn2HwMLUd+dzj9CqYzxeV/N3S9Facq9+DUPzzj5MwkQafRh7wh6IcJCernJXDSOwzrSuEveQ8cKDUD6n36dsXyURX2gVBdKWdDdGVJhAILgqiK01BCKMLghBGZ0MII4FAcFEQwkhBCKMLghBGZ0MII4FAcFEQwkhBCKMLghBGZ0MII4FAcFF4UWEUf8x30tPG7CuOLT9N0v1GvTwunDA69jd00i/FyfufdLyYuu55yZ/u20IK41kzPJ53/GUjhNHZEMJIILgApBwpphwfpspmqb54lu+55x0/PlFxMJy2iv2LVvCKY2Ilbs9/jBeNz9mFUeKUeKTq1WOnmMfPk+5g8vj12Elxyh/gURhpjinTnSufFv5pfgSPwk279uNy4YTR6c4RjzNsypupEg/lWPqHIHsrTct4x+co71NetB/3pqp8UEnvpidWtj++PhWX9IydHoeU5+7HPXjL1x6F/aSokxDC6GwIYSQQXDzk8vSUcjhVOT+tnE796D5aWeG0sNPqk/QVDdL3Pa0yf6I+SLfod9gAACAASURBVPfQnfZjO1WvpN4f1zufzPN1Inn63HAHZdpyxu3rrM7Z2dgLHN03FY7E/PQg2z5l2azTHkl59md+FMm67olERPbqc+hhaGJeWeQ8HGB9ayO54HlKcJ1NJF4cYZRM2aB7hzXHPsQOWF5ZP0pE5RTl1b29xo47mHaZ5M/Bd7Q2zhNBy//jbC4vEwwrIXqcDpy+0Ilw07e9Lul4cm2zM7UcPbYUyHPOFsLobAhhJBCcY1JCIhRkpKeT2XUnPqeDnT1loe9I0MPmrvPEuck38v9oyMvmzt4pxx8/M4Z9epi+kWmkasTtC6JokuQ1sUP2gwdPluOxEDNjw3R2drKy/eQaaUchJPeFAx62d06Lb3pcnpUcTxdGKZHhXRtHZWqUBdbESDeWqibGpxbo7Wik3NyIOxCk3VpJfVMXrbZKBkamGR/qx9pQiaGsknJTOXW2bvb2NmioNmLrHGK8v5eiwhxa+seYm+qnoCAfS/sIe9vL1FQY6OgbY7i7g8LCHDpGZliYGcRYWc/qvJ2S0nxUuiqm5haYnOiiqsxE1+AkE73tlBvrcXhT69XxwlwYYSSpaYnF3ioyyzrAt8TtjGI2txx0tVnoHpqUW3dmRrp4dP0KluElPI4FWroG2NuY4+r7HzC67mVpuo/e8aWjDObatNPa3oPH60Vz9wqqagvbLj/2iS6G7KssTQ1jbbKxtuNhY34Ca3MD82t7LE71Mji7zOrcJO1t7Wx7D/E6FmhusjE8tSh/eSS2l6bp6B4keBBkbLCb3tEZxge6GZialsVVc2MDy7sBnKuzdPb1YJ+bYtK+qjxzWk4QwuhsCGEkEJxfUi0c7WWZ3MspYnhxnZ4qFXcz85haduDeXqClt5+leTvNjVamV3dxb6/QYWuif2wR394yLd29LC8v0tnahn3DDQf7tLc20zk4jj/5a3prsoUPrtyno2cU+2gb737wkM09N0PdrcyuOZnrrOTy/VL5B3hXZzvLDkWYRZ0zXLuRwfhoH5mZecyvLtPW2YfD6WGkx8bAxDJ7W6usb+3j2lxlYqifgf4RVtfn6WjrYG7NCbEgHY11DM6sEI8G6OpoZWU3yP7WLKMLG/J90ruk/E8TRnHlWZZHmqjqnDjaP2zrYHh8hpGeFgr1WuoaamgdnJKPddbkcy9Lj3t3i6raCkb6+mi1dtPU2cz49BwdTTWU6UpkATM+MYnVZqOmto6+sUnqmxuZnrNjq6vAaCil3GhhanqCWouN3uEu6q3tbC3OUlnXwuTMMJX1jXS0lKEz2FhfmiAzu4BynQZrj/3EZ/0iXDhhtDRYR2HNAARWKNBWYdHno6uup9pQglpdiq6ylsrSPJoGZlgYsPH2z39OubmGvAIVrU31ZOdkcv9uBkNLbjk8dcbb/OyDeyxt7WLMv42hshytrh5bo4Gq5hYKHmbR1m5DVaQm7+Ftmtpb0RQXU2ZSU9PaRsn9DMorjWjLa9HmFVBvqePWrTzk9irvMo/uPSQ/LwdjuZ6PMrKYXVzi/ofvMLW5ib6ggM6ebvS6ctRZtzA09+PeXmZ4akl5ZiGMPjFCGAkE55dUZbnQY+QP/+DfMbTqZ6xRRaFOQ0mRgZ6uZtQmLTlZeTTaWlGpNeiL8jDWNGFSl8oiQFepJzu7kLKyMtQVFZjLDJhq6rlz5z5TW0prxcGendf++I8otgyzvzrM9dvFbG5sosm5wTvXCuhrryNPY6bBWExmXi4PstRIV8ZdczzIKmHJPklxQSFqdSaqpiH6LOVUWtqpq9ShNxqpqqlGrdFQV1NHbXk5+aU5qA2V6HUGrJZazJZ2lhYWaSov4lFuLpm5OuaX5phYWH9hYUSqVcq1TKnWxMryIi1tFppq22msM2MwGChU6Wi0tdDQ3MTivJ16s47G1na622w097cxPTzKUOcQrYPt1FQa0RsMaAz5mIztrK0sY21tpba5jZnFVWzdTdRUlqHX69EYCqkq72ZzfZFKSxsLi5PUVVXR2WTD3DHCyvIkFQ0WbE16Koz9uPdX0ajU1NZamF7d+9g9MxdOGG2MNZGtbibknOFRURmt1XpaB2boadLx0UfXMLcO0G7Woa+sRK01YFKr0JtMqI1VNJvLuXX3IWZzA/NbPjm8mcFOMu9coUhnRpuXx+DIENqSMmprSjFZW9CX6llemacwK5P83ELmV1cpU2WRpyqgurkZncrIyFAfOdlFFOUZsC9OkZNdgvRpxHYnePe9K1Q1WOloNvNQpcYf9JB3KwNfxEfm3UwcO070Rdnk3M+gd3JT+o2B26f096YjWozOhhBGAsH5Rakr43hcXkaadfz07QeYtSqs7X2Y9XoaG80Ul6lRlRiYW15GV1yAqqiIrnE7rVU6tAYtKqOGQpWBoZEBirX5FBfrGJicQ1tQwIxDEUZB3z5r88O8/dpPMNtaKFHV0FSlx1BZSU5uKV1djWiqrBhz7pCrNlJX3yYLo4TbzvvvvIeprgWXO4DVlInNvkW7sZi2sXW5RaZxyE7J9df4oKCO7ele1EWlqMtL6BseoUxVSGFRHi2TW0AI7f2rZJcaqK9vw+UPEgiGPuYYo4T8KvWiNDU0suzYx7PnxOncY3JgiPHpBXyhCPbRDrl3Y2d3C99BgI2lWdZ2dvC6XDh3nDicuzh3NugdGGJhdYm1FQf+gB/H9jabjm3cPj+O3V32HKv0DAyxvL7M2so2gYBP7rp0rNrp6h7E5/ez4djD5/ewvrXFtmOVleUdOY6OxWm6uofwy8s6Pb8b8UIKo6NkifpoNOgpKi5ietPDQGU+V+/cp6qmDa93jyqThsL8UsZnF2hpKCPnUTadw5NYzSa5u83WWI6xrodgMo4zQ61oVKV0D07QZbViX7TT3tLF0FAHvcODZN34kOwiLWMTi+gzPuRubiHdvVNMjbbTOTxKR2sXdvskrV0j2Ax5vHf5MpfvqFCGq8UYabGgM5pZX1+gxtrMQeiABlMFkvTZnuyioCif/lkHYy11TG36cS8NYm4ZSKbjcdOhEEZnQwgjgeD8Is1ckpjqaaFUraNzeJ7p3jaGJ2fp6+hgdHSQ9p4W8h7e5+GjAton7XRUFPPRnXtU1/WwtTZLY2szza2dLMzPYOvpZqS9iSvvv8vP37vOkkuptJyr4+i1xdQ0teF07VCp1WJtsmIoKSJPbWZzfQ69roKZ2TF0ei3dY8pwiKhnjeqGVlLyZbjDTP/SPgQdlGmLMNYolWN/rYGWsVUCDjutza20dtuYnV/A1tLG1uYapTmZ1LYNsutYRKNR0TftYGWqnbreqScGTfufN13/Y4+J/exmX7+sW14gYfT4PZSbzA92Mrmw/fQplI/vecJnw2nTAZPvw27abF0E5XhH6W9uZtunZLr0a1IzA+xDHahLpF8ba8k4ylPVXoqfBiGMzoYQRgLBxUCZ3v3YPvl/WB6Xs+VTKqCZoR4mF5/snkltu9Zn0Go1NHaMKmNFH5u2fvIGp0/bV+aPHe97sen6L1ZPPM/vkP8F/BgdzaB+bDadPEsuORv7aLZdmnuax6fap8+kPt2evE/6/qddJ8dRnpl3+szA53HxhNEJfwopXxUp3wfJFefTPihpW9mX9l4+rlya7psh/pSpkyemRaadm/5hnz4wLD0uyjVH90zzt5R+bzl8MV3/pSGEkUBw/jnhY+exijq9NSW9nD5Z9j+rHE/WAY+FmV6uP15vHIdzMkwlbko9kjr/SHg8UUcdiwjlWLLeOTr+8afrXxQunjB6DNnv0GOZ4+WR9BmRdq9niX7peDQalVXuy0a0GJ0NIYwEAsETvuqeUWdIIkUqx6PRT6HC+pQRwkjhwgujT9sDdbo37PTt05Cb/qIv5uH04yKE0dkQwkggEJwox9M9Y59GWrfSq4YQRgoXXhhdFIQwOhtCGAkEgouCEEYfQxhFYnG53zEQ+mzMH4xySJTNmajclWZviREhij/w2cXhvJnLdyh/hsHD1Hbkc4/Tq2A+X5QEUZreinP1exCKf/5xEibS4NPIA/5QlIPwJ+v+OYzEPtO6QthLzgMHSv2Qep++fZHshYSRPHo8/tlZNKqMyXcuJGRhtNKpvI9GPtt4nCfzBiNEY8rAbF8wQiQa/0LE64tukUMl77VcTnDte/K34XOPkzCRBp9WHvik4y2l8kXkz1c3DaKxuFxXpD5HafvzjtPnYaIr7YIgutLOhuhKEwgEFwXRlaYghNEFQQijsyGEkUAguCgIYaQghNEF4XnCKN0x1mmz5x53Cnaqs7JziBBGAoHgovDCwihx3O167C+Jc4MQRheEF2kxelwcpfwpSV5Mj/e/mtNQz4oQRgKB4KLwcVuMEo+9T/fxJG2/qnWFEEYfg/QViD/t8F/2PZ4mjFL79h2b7LqD8oKKmyurHCQnp6SOBzx7uAPKgogSB14Pbq8yYP88/VJ4HCGMBALBq1aPHK/M8PHqlOcLo4T8P3zgZn1nV9727G+zs+3kMHLsIfxVrxKEMPoYxMMh9t1eef2beDSazGgJDg+ChCNHSuKkC/fEyeNPXQJEDiqKx71PKKxkRmWFj+RSH+mnxqMEg0F59PyRe/mjQM4mjFwro/IKzo7VOeoampkaH6V3aFY+tjE/QUFONj32HbYXRhhbWmdxsI/23nklXT41z+GfP0IYCQSCl0oijnt/X3aDIzv1TZafsWiEg4PQk8t/JEv21PHUOmrHS4ukBS1vJwgFvXi80lLjEAoGiUp1RfKE9HA/rjBKJOutlX4ruaXVSJ0K3S1atKUWtl0epoa7GJrdIBELMtzTzvD0SnrEXhmEMHoBlHwbo6PGSE5+IcP2BRrKtHRPKh/68vggS1suood+Nnf2kLJS9PCAHYeDcCzB6tQwCxtO4tEDdvdcirCKHLK9u0vwIHyUZ7rqTOjLdGgr63EG4wT3newHpS9KgoDXjdPpIhAMsrW2xGD/KFL23d12EIwmiEfCuJw7eH1+DkLHLTsv0pWW2h63VfCwpAz70hQ1VQ1YauvoaG/D3NBIo6WRmvp6yvQaSrVFVFQ0MjKhLHYrhJFAIBA8px5JlrNzg21kZ+fQ1j3KQHstFU39cp1x4NpgaGiSKHG5XHcfhKVf4Lj2ttn3Rwh7HAwNjsvH9/f28IekqxLycbdP+qGsiJbthVG0qhJ0xjL6p1dYnJrAPj1MeZ0VV1BaoipOOHTAwUGQYCj8sYRRXP4XoKWxhqrqWmbsW4z1V2Gu6qKnw0pNk5XqylqGJqfotNVQmFfEdjC1OO6rk0OEMHouUjaSCHHnZ3/E7dIGyeUlmnsf8SAjE1NDF10NZlpsDTzKzSY3P4+GnmFqS/PIzc9Ha6jDaq6izWbhUVEeeZk59Ewt0GUuIzsvi+uPNPKXIrgywP2MIlnsHPiDhAJ7NGizefPaPWZmx3l46z6dbXV8cPcRLW3tGDUmBgdsPMrMwNTQQ4sxh5wyM1NDbZht/UrM01qlnjnGKLk4nX9tjLLmfjanh7B0TrA42oVBU0bb8AzzU0OUqkvQ6Aw0t7VgLq+lb3hZvk4II4FAIHg2qTGbNXnX+fEbD5D0Qme1ims3HlKor8Q+PUZteRUVlSU8zC1CZTTRVFtBZmY+uSU6Bgf6aaioosKs5mFWPgZTPWNDrWRlZ3P//k0md6Wf3Am0GbcYWPLKMiYU8FBv0FBtVPHB9fsUF2kZmRylTGtioM9Gbfd4sgyPP1cYJZL1xP7qKAVFaqyWGsprWujqrKCqvIU6cyV9c8uMtVoxVlZjbaglL/cR636lHhXC6BVaRPaF4pP8RD1bc7z3kz+nqLaNimIV/UMDFBeXU6PXUmc2kmuqZn1ploxHxZQWlLCwukG16hEPH+Zira8gt7ySwfYmjCYjGdklzCzN8+BBEVKbkHeuk4c56qQIg625fmqqKsjKvIeltYVSdR3e7QlulxgJuLYoeZRBxu1rFKr1VFbWYSzIom1s5alC5dnCSNk+3F+nY3RRkmY0SC1X5U0cREJ0NpRToqtifnmLgY5azLYuZkcnmbZvKZeLrjSBQCB4XkWivIT3Kbj5Ntey1DTUlGNpH8BoKsbW1kGFWkupPp+hlR2qiwu4c+8hHRPr9NaaKCxWYzYYUZcV09I7TLWmiIeZd+mZnqNc84DBDan1J0bJvRuMK8008g96fVYWtg4LBksfCxMdXHn/HbQNXUcDpB+v6/xPE0bJct4+2MHIkkvqF6G5rp723la6O8ZwbK1QXaaiwjbI6vww5VVm6qwWdgKpYSSvTgYRLUbPJdk3G3bTUF9HeZmWyqY2KrR6BkYHUKuraDCW0dRYw73MR5QUF9HQPUhlYQa5xcUYDHXUletpqK1EU1PLQHsjldZ2rKYyikvy+OBOgfzLQRIjNdoSahvqMdXb6G1v5FFmFnfv3aa5rRW1zoJ7a4KHahN+5waleSV0dzXwMDuXnrElrNo8Omd38SwPUtX8MVuMTnvqtMF66eOc5JkGyV8+FwExxkggELwMUsJgsKOO6iojhspq6swmWrsHqahQ097VjVlvxFCWz6M8FTqTidoKPZkZ+RRqy+jr7qRSa8BYraFrcASTXkujtZbC4mLu3PiQMYcyhMI+2IJGW4a51kzv2Cw1qmJ6+tu597AYr2+LX/z5v2PIEcUxZcPcPfnCLUbpyGOjYtJs5RO7k3WFsh2LRZPDUF49hDB6AVIftMe5xezCCuEEBP1+DsNh/P4AocMY3vUxsoqLmd+UmjDDVBQV0DY0x+FhlPBBgGAwQCB4IA+Ek1Zn7rcYePvye6gq24/vE/azND/L+p5Pfr+1scK6Y4/DUAh/4IB4LIw3ECQRj+Hz+kkQZmV5SXbbHg765VkB0ZCffa/cdnmCFxJGKTF05Jfi6SZdL/wYCQQCwQuSLH+jQTdzs7P4DyOEQ0F5TGgw6Cd4cAjhAGZjDrXd0/K5A7ZydLWdeA/C8uDrgN8v1yWhUIhwNMbaVCcfffAW9/I0uI6GCyVwbS0xt7SONFEs6PMRjUZwO51MD1rJfFQm91JEgm72/crP8lRt8CLCKPG4z7vH64bkD+mTE4NeLYQwOgOnCoJEnEg0eqSaoxFpvZmU2Hjy9Fgsgtfrkwdnp8JMb+F51gyzZ8bjKQjP12dDtBgJBIJPg6dNa5dETCw54zkajRJLqyOeDCRGwOcldJje5fV0MRL0uuVFUl+WH6PzihBGnxNH0zA/IzkthNHZEMJIIBB8cTlq63nhlpln/aAWwkhBCKMLghBGZ0MII4FAcFEQwkhBCKMLghBGZ0MII4FAcFEQwuhjCCNpoG04Ko2h+WwsHJb6SOPs2uPydP2ldmnsTZzw4WcXh/NmnkCYsDQ4OxbHGwhzGIl97nF6FezwQMl7tncTXPuetPX5x0mYSINPKw9I5cMnQRoP81nWFcJebhpIKzR4AmGiyffS9kVM4xcSRtFYgmAoxsHhZ2PBgxgRYjhmY7Iwmm+NIf0Fg59dHM6b7fvC8mcYCivb0gC8zztOr4IF/JIPjhjWt+Nc/R6EE59/nISJNPg08kDwMMZh+JMJI6lS+SzrCmEvOQ+ElPohlHwvbV/ENBZdaRcE0ZV2NkRXmkAguCiIrjQFIYwuCEIYnQ0hjAQCwUVBCCMFIYwuCEIYnQ0hjAQCwUVBCCMFIYwuCGcTRsfeTBU/GSnP2EnHlUnfGYqjsjQnZPJm+pIi6a8nvWsnzzz2tp123xMeuJOLEB7tT7/v0b60cNOu/SQIYSQQCC4KZxdGiePyPOWoOOXc+LF64Bk3/8J4yb4QwkhaQiO1vle6i3LFnfnTr3vecTnshLJmjGwnPFefevLRmjQn7/HilfhZXax/XGF0eBAkEDpMapy4vCyJHPNEglBqv7R6s7SdkOIVlpc8kfbHImEODkKnRD5G6DB17TGJRIRAIHB0bfBQWfMndhgidKh8SePxCKGQ8iVNRMMEAkp+jUYPOUx6fY1FD+U4yOdHwoQin9xrqxBGAsHFRl4fUiovT5TfT5blJ3mx5TDS64/nrF75RP1wMvzEs+ugU+qeTyKMIpFD/D6/PIsteXtikcgTsxoPQ4enrq0p1S8+f4BITFrxQZrkIoX1dI/cnzUXQhg9EX4ifiwMUuu5JPelhMpRJjo6nrb2S3KtsFNCPil04nHiadsn1pd5LD4nxdrJa+LJcE6Pc5olW0rk148ljBSlHj/Ypt3aydhgK8WlaspNJsaWnezZh8nLL2Z8ZZuNuWHyC/OZXnGxszJCUUEBo3PrTE10oVFpGZiyM9XbilqjZXzJCZE9dAVlOMOwNtpBYYGaqQ034f1l9EUmec2e+ZFWyiqrWV7bYayvDV1lLauObUba6zGWW3AGDpnoraOopIyNfR/TvTYqqhpZ3tiivbGcsooadj0HjHY3UG5uZG/fy0BTNcXaKnb8qWVazpZXhDASCAQnyoS0slwuux+rN5T1wo6Py+tKJteWPCq3Ty2QTl7/5LlP1iXH+9Pfnrw2/Qe+XCcl7UQ9+ALCKJGsmD3rExSUlNLc1sHMzAQttj6CXgcV5VXs+mP0N+nomFkn5nWgVuXT2Dkuz+w1V6iZ2A6yNtRCsaacltZuNjfXqdZqqGuyUldnxR1Kpdvnm+fOtTBSEjeBfbADnamWjZ09RnsGCCpNH6wuz+EMPFlxprbXlufY80dOhHV8jrLt21nCXFmOTmegZ3z2ZADKm6NzQ84VOofGT6xmPNrdxsyai721aUbmNk+EfeJZ5P9hhju78Rw+mXmel4+eJ4wkYv5VasvraGurp31qEw73qK/UU17TxurKPFVlRiqarCwvzlNtNmKxWFhaXaRCr2df+sIsj5CvqZXDWh+zUl7XTcC9Sn6Glu39PazVVlaWpjBVNLO+NkFJdhluvw9zcTHGOgtL6y45Lh0NRmzjK/LzWioqGRwZprW9lcXZMYxGPbpyIzUWJU41dbVY6iwM9g1jKlVR09bL0vQ4Ntsgs8Nt1HcoizG+yK+l0xDCSCC4iCTL2EiQ3qZqKm397G6tMjKklCdEAtgX5jlM1iXpLTcy0QP5eOjE8bSzkuXv9sIEJl0Z5dU1bHvDp9RFypu97S22knW0HGQ8SG9fF/tK4zqe7VVqjSbqrW24lZsetfZLxAJO+npHkGuzMy4JkkiGtWPvpbCsDlfwkLB/G212JgUqAxvukLRCLmZ9Dt2zK0z1WxmeXaap1oh9dZMybT7DWz5mW2uoaOxj1+0l5NtGk6dmdW+PBoOG+V2lp0EIo09LGCUDie7N8O4v/pqmkQX2HUtkXHmLPK2RhZVt+rotjMzYaarSo9GZmFvcoLOhHJW2lPGpZQZ6mhiastNaW4nBUMH6vp/JzgZKSrVYuyeObjXZZuLq7TJ8nlVUai09k3aGWhoo0lfhi8SY7qyl2FjDcE8jWaUl2Jo6mXf45Gv1t17jx+/l0t1pRlvdylhfH4vL8/R0DzA20IaxwkSluQKjvpK55TVUd97jUXEx3UPzeF3L6A16hu0O5vqtlNXUMTbYRUuvIr7SF6V9mjBKfUWkrimfc43GinraO5vonN4CvNQbStCYO3DubGDS6jA2NbG9tUlllYa6uga2draoLq/AGw7SYqlnN5Ag4d/B0tTIrvw9TtBR18qGY5Om6lZ2dhYx6Bvle7ZVWNnZ26Da2MCSfQRTTYu8v9tiprnPLm+3N1bT0mGjtaObrbV5tEXZVNgGWZgcQK810d7TTXtrBz2dzTQ09jE/2YuuVEtnr53lqR5qW04K0Y+LEEYCwcVD6t6RWOwq4833rzG15WZluIWrH1zGUNvC9tYGza0W+vv7MKrVVDT1sLe9SlVZCRpjBavLq9jaGukbHKDSUIa5uZ9YLECTSY9Ka2RkTipfobOyBH3zHCt9leSaWtmYnaCksIiZHQ+786NoVBpm15bJufY2heYB1md6KSguY3tzlUeZt1iUqxE3eQ8eMrm2z8rsKFtuH+Ptzag0ehwHYVZGOynKecj1h1qcHgcmo5b+6S3W53qwDs6eKB9fRBi5lgZ4kJVH59Akfo+Dgvs3ySrSYt/wyMc3ptron11gvNfC1NoeTWY1mwGYH7UxvO5mvrOOEn0tI9N2vN49tNk5mBtbmFpYTd2Iz5tz3GKUal6MU5t/jT977QYrq0uo8h7RbGvEWFZHVXUptY2NFBaZWJwZIOthBlmZ+SwuTVOYl0mRXoWluYminBKszXUUF2vIzdEzPtTOw+zyozutDTeTXdyKb7OPD7K1BAMebNVq3n//MmZrIxpdDf5wDMdCP3/8//2vXM2uPoqj1VTAhx/e5OrVazS09aDLyWd4uB+tyoBBk4+lrRNVdib1llpU2lrKSwqxLy9QknePu7fvUFhSLHcxGfLuUy+JifgB23vuJzLYU4VR8guxMTNKaUkhltZhhjvNFBvNtDbWYOufxj7QQalKQ8fwJOMDnahKS+gZsTM73o66VE1H7zBmTS75ZY3sbK1Tkn0HfU0rG3vKF6XFVM+m94DJdgsatZaWoQW5abVRX4MnFJEFY2VFGc3d/YyMjdDcUI+lpYPxkSHqzRUMjM3S216DutTAyPQ8wx02Ko1VNDU2UG+pp8JkpHNgnIFeK8YyA/2TM3TWVqPSljGzqcTh9Kbr5yOEkUBwAUmVF4c73H3jz7iaW8fyeDslWh21FSYaGprQm0ooLCjANjhDY4UWvUaNWm9mbqyV7LxcNBU6ioqKqaixUmYswVxdRWmZlc5aHdr6ETn4QUsZmUWVWCo1VNdUkV1iYHNjnoJCLbZqFT/968uMLixSqSmlc3iBsW4r71++jNnSgUaXx+oBJJyTXLtZSrLxiL2ZVh5p69lcGCE3N5esHA1TU5LIMmAoyCCnsJhHj4pYd3nY9/qemCDjf44wcsz1YWoakLdjnnXKy+rxB/ZQ5Rezcwhb0620T8zjWZ9DrVVTWdMsnzvaa2FobR97ey2aimbs84tsry9QaajGL59xtvGznwbnVxglP+gD9y72mRmKH90mX1WJIxfzSAAAIABJREFUvkjNQF8bWrUJo6mIuuYWVCUaetqtFBVIGb2Q3t4OSouLKNYVUWOxoDWY6W1rIrdAi0FTQXdHAxmFKXEDS3213HrUgHutlwc6M2vTPTzILKQo7y6Vjc2U5JVi39hmvLuO969/yO0H2cw4lPTWFWTSPjjNa3/wbylu7MOsKpBbiPIK9Bi1xXQNDGEoKKKtzUpJaTUlGbexdXdTWphLYe4jsovU9AxMUZX/kLbxLeJ+B5P2tWQSPF8YyefJ/yOsrS7iPowRP/SzZJ9hbmmDiHQwesDi4ipBKf2jfhaXF5G7gqMBVhaX5EFzzp1N5u3zbGzusOfYYt4+y5bTq3wG/gBRaXDeQYClxXUiyebloD8gNwvHAi4WlxaQgvc515mZkbrRwLWxwtzyqhy/iHeHlZUNeX9w38nigrLt2VpmdlX59XXg2mRpTXl2/+4OK+t7J57wLAhhJBBcPFJl5c7aKrMTfVy/cptyvZGKigZa6yuoqqqltKxI/qFX19SJUa+mzlxNqdZIl60GlbqUEkMJRSUq2nqG0OpzqbVYMZksNFSWUmZVWrK7q0u5nVXOjttLxLdCVk4R46N9FKoMclecLusW1x4VolfrKS8zUZCbR2FBPqaqBvIKHzAv/+7zUZSRwcDsOvbpEUYGbORrqhjptaE2GCnOKcTWYiEzqxSzPp+H+SU0t4+wtbnI7KrjxPO+yODrWCSELxBUxs/Go/i8iqzx7DjlJUQS0UOCIalbMMH62gKu5ISYw1CQQ2nZmZCPhbkZJidn2HP7CAaCRKKxM7fqfxqcX2GUqgzDPtotdTS2D+P1epgam8DhWGd2Zp6F5Xlmxnq4fe069a0D7G2tkXXtMvp6G1tb+ywtTLCwssrs7ALrq8ssLS9TkX2Tn/38TXLK2o/u5HUsMzS2wqHfwcDUPERDtLc0UFVTz7YvxPpkN6Y6G8vLC8ysLLM6P83Myo587ez4EA5PhNWpfqY3nGwvTGKuqWd0eoH5mUnWHf8/e+/V3EiSpmvu7Zrtmp293F+xv2Pvzt6t7do5ZmN7Zs70iJ4z013dXV3VXd3VXZ0lUlJrkBCE1iRATVCDBEBQawESFKAWoAAh+KwhAiABkslkZonMLPpjFmQA4eHuCDj8e8PD/fu2mBmfYDUcYmpmmdmRARwNDmaW9kic7dDU5GY2vMfK9Ahr+zGim7N4R2bfShhl02YX5d96/2rOd87S/Rv7D/pGcvK5WUZePtll+ZkXqXSDyCs3cyR3Qntm4nluGrFcXyAQvAtXfeX2Co12B0MTKxxuh5maWSS8vMDCwhJLoVnsumoKSlUEFjaITPfzzd++prUvwMHeAZPTo0xOTRNe32R6ZorI2hyFf/mcT37/Ja0B+bHR2sI0U8u7V+VuLUzRYHeyfZbgIDxPc2MTM+E9NhfH6On3MzY0gNXqYnYxxPjkCOlpPVI99zZob2igqbOLkySEgoM0uls5TdvR1XFcjY14RxY4PzugrcXFZGiP7ZUxBqdCby2M7iK3X77LpnwoI0EP5WcsjN5USGY6c3SP2dnQ9YS6yRnkuc35X2b2sdzyzBh9fT62j7KTxC7fqsFIqxjuEAbXDfOh1c8XJN9v8rWMtGT08q4lpPJS0KxPiqv3c/ZTqSSJpKz6peWt6f2cH5t8as65ORMQs+VJaVLyPpk8s0s95TS5+8kcVwzZ/Zw06f0f4A5EjBgJBIKbZPvSjZV51nZPpP3T/Qjz8yu3VhpfT+Q+YSwwyJB/grMcW5buM+X+Nd/324Of/ksjN/kLg65XOd+0P2+2V9E3CKM825Ozn139lns8ddMO3LAv2VXbHxqPQhhdG9i7lt7fMPa5AiF3uf0dSxuv6ps9lrPMPysOsvlkG77cUHOWc141pmxZclp5mPLGEtDMMstr0ZEVLDlLON9pub7gtW0n0y94voSv/5O4TgLB4yLrH+i6f8+1H7duwiRbcu0zL2s/XucT7+bS/bybxFxbkN6X+v+sXbnhJyljw/JuDLM3jJljcp+fYzPecrn+Y+JRCKP7C7vttOs+yXAtcvioEMLo3RDCSCAQvI7cJwB5/u9e1588yJnj+0MIIxkhjB4JQhi9G0IYCQSCx4IQRh+RMFrJzHNOxiCVENu7XIOj4zjJ+KU06nZ0nCBxcSmu5QOuWyLzs+j8Ar7+397fb0IgEAh+bIQwegthFE+kOD69kEYdfort+CTO+WWctam4JIxCfelnnhckk3FSiO1drsHp5TlJ4lwS50zavxDX8gHXLSHFW4vj+TLJk/8EZ8mf5jcgNnENfuo2cHwa5zQTm/BdicWTP6mtENsP3wZ2j2JXr3P3H9P2QY8Y7S3Cp/8TtHwCQQUMFYOvVGzvcg16C5IMlYK/LLNfcimu5QOu21ARjGlA9X/CN//7+/5lCAQCwY+HGDGS+TCFUWZm2ukOlP0f8Lf/RWzf9xp8Ja7hu1+//xW++p9B95+zDfR9/joEAoHgx0EIow9YGOWSvPiRVqM9MtLDg2K5/ruTnXMkEAgEP1eEMPoIhJHsA+h91+LnwUnsWhidxBLvHDvsMSMumUAg+DnzMGF0meec8cpdQdpHX04+byjog3Ts+FEIox+SK8dZGWeK119mvoOtW+e94bicd9a5VtoR2JuUXL6vpIfEh7lqfBnnjdJnSSTyHEi+qY2JESOBQCD4ccn1vn+zn7+vj35IHy6lyzojzkZneMBJuZ6w32TT3mnE6PLaqWU6EkEicR2JIBsJIZGQnQonc/bl+mds2QcUJ+2RCaP8hiC5Kr/y+nmZ76k663E0e1xy3JXjmCsrhF7zZUp5SQ39thfTyzsaZ9ZpZLY8uS63Q4c85HPletXORQgjgUAg+BGRBEieBMl3BnyZa2eubUpuyIxs358mP8pBNovr/dyICLJX7Bwbc3lHVITcKA039h8kjC4z9il2QE+Tm7GFdfY21lmLyMHCI+FN5FNTLC4scnieDeGUV4L0N35yyHImEPiHOBT/sxdG2QaRODlmanKKw7M4J4cHnMdkVXt6tM/xaey15+cez4lxms1c+hc/PWJ+ZpaFhXRg2vWr+GI5lbhu0Kk4e7u7UrR5LhPs7e7L+zfqm7t/Fj3g6PSCVPyM/cMosdMDZqfGmZie4yKV5Ohgn7OLjEp/zecQwkggEAh+HLJ99fH+OpMzC1wkEuwf7BHPjOwc7O9xHk+95ob2ksMbx2+nybwXO2VuapKtw3PJfiQTF1d5XImy9M19bqS2+DnJ1PVE3bPjKEcnWZv29sLo5GCLtdA0bruLjqZu/P4JZqd9DPaNMzHpo6nRjamhjcmZGabnFpny96DWWZkJ7zAX7KKhtYdgbzOFL+rYOdqnrdFMYHb1tZ/5ffCzF0ayIE5iV5RQpdIxvriIva4cndMjNY7lMR8TcyE21xbx+kbYPY1LUZSHfUOEtw9ZmQwwPrPEVmSFkZEJDi8gHt0lMBxgbnmddFNOxk7psSn49Rd/xj8dZml2gtnlJbY21xibmOQsBUe7IfqHJtjbXKSusJLF9Q3W1kIMDQyxEdlmbmqUuZWI1KoXJoOMjs+wH5UD1fob6zD3zhFdHqTG2Iy3UUO1oQVviwGjoxlTvYLBhQMp7fHuOkvhyC0lLoSRQCAQ/Ahk+9mTNUpKXlFvaiM0P0lpyVOaB2c4j50SGOxnZXOf1blx/KOjnF5csLEyJ9mcneMoo74Bljf22FieYWRyhrQcOdhYIBAIEo7sX8mcdkMFZbVqvBNzeGxK1M5OdiPrTMxMsb2/yUhwkrQrqvhJhMDIFImLGLryZ7h9c9L557sLfPLPv8A0sAKnEebXdjIf4fJBj9IuswJwdRqT1Y6/r5vnL8tZ3tnC39qNzWKmf2yRvlY9RRo7kfAMzvZexvzdOLv9zE0EMKprcLpaCPSN0tqgRas3UKOp50jSbveH5Pqp+PkLo4wIN7/6nP/x50LSUsNRWUitso46XSOdThvNjTael5VgNhupdzRjqS6j3mRGU1uPWaejvcnBi8oyVDUKGj0DuPVq6vX1/OXbMvYygj261M8rpYb42QFPv/gdwdVNpvub+exXv8LkasdlM2JzdzI1MUbFk9/y2QsFodUFjGoDJmVatCmoVpjx9bVQrqhFUfCUhsEFKW+fS4V9YJ7j5SFUtjb8LQYq1GbanA66B4aw6GoZmt+V0m4tBOkcHJf200OoWYQwEggEgh+B7ByexB5ffPKPfKdshvgOL4peUVerxO5qwma30tHipqS4AIupHrvTSUFZIUabnTpNPTqjBU9bM+Ulz6ipVdPR7UVTW4pOXUthleFKLHRqvuYf/v0v7J9f4lK9ROPsRF34BHdvP3pVBYUFJVicbTRaanlZVIrB4qa66Bsahhal83fX53n+t7/Q4F/jaCVAx7AsmK4fr71eGGVF0dH2Kpubm/S0mtBqbDisbgYDw/S4PNjczcysROhud2Bu7MTv7aGtz8fkmB9Hkwun1YxaVYm5sYn+Vi+eFjM6i43mjn5imdG1D4GfvTCSr3WKk+N9dAVf8qRKj1Vdz1BgGFWtCadeh8tppcZsI7wyT1mZEr1KxeTSKs36aooKK2h12aixmAl6u9CbDFQr6plcWqSyrJbdzFO4vdkuvi5TcHK0TeWrKg5PImjqVDSYjVRVlFNVq+VE+u2E+Pq3f8e//6mUre0w9QoV+joF3YMBnHojutpK3H3DeF06XEOyMAq2aNF1zXK0OCCPGLkNaA0m/vLHzwgsbmFXlzO4dCylzY2wnIsQRgKBQPDjkUomOIrM8eSzT9CZbChMeoK+fnQ6LTqjifaWJkzWZlbmByitKqNKZ2JlY42qgkLKa+vpSB83ORnsaadeqUZVb2BxdphqpSVjzBKcR09oUj3j82/V9LgNdPiHsVTXsLiyRNGTP6J3NNPZ4ublk79Sb22gp2sAa305gbD8RCFNk7ESTduUtH+RmSj9No/SEme7eBodDIzNsrO2yU7kgND8DFOTSywuL7FzeEw4vMbOzh6LoWWGPI08+eY53qlFxoNeugf9rISXGRkaZudgl15PE8G59avyPwR+5sLoUnrUBWc0OS2odQZ6hyfoaGhgZHIcp6OV7pYW+jzNPH35HWWVCrzTczgVhTwrKsLh6mfI04KnvRV7exvj/gFa+nz0NZj49ukTPv+6hMNMGzpeHabG5ODi9BCDSs9JLIpVW0Hhsxc0dvnwdjdSWKzA5xui1enG292Mw91MS1MbTTYb/rFxWhrdjAX7eVX4LX/7/Z9oGQ5JeZ9sL6Coq0NZrWJidZ+JTjsDkxtEZrooU1lw23RU1mjw+CdZGOnD3uaVP70YMRIIBIIf2cxk5poermHTazAYrEyOB7G6GxkfHcbd3ERzWzsDXW08+/pLquoMTE+MUvDqCUXltXQOemlrbqa/t4+2Vg/+AQ993iBGbRHf/uVvFFRmhBEJet1O6rV62vommRlqRam3YK3Xs3F0zli/i9KKepbW95j2N1FcpWYmvEd/gxp9q/+qup4GHe2jESJTHVi6R/NWR7/LqrTL9GjTLT2TGUVLxRgf9tI3PJk3l/ZD52cujK65TCU4PTnN//6yz1WP17A2NrIvTem5pLepkckV+dFUroDNDjfOBzwUl5bh6hrJZn5nmal4nIsLuWFdJhOcn8fy/DykckZ2skr54jCMtraMunoTWyfXaj55EeP0PHYj/aU8qe7ykvPTE6KnZ2LytUAgELwnEvEYp2fZfvp69Veao9UpXK5OpKOxPRyNNjajcj9+TXpVcfp/il63gbKyCnzT4Uw+aQGSlOxYMnNK/CKeSZ+xcadn8mBAKnm9f5niIp6Ok/kD+zFKXfsxkle/5b++y51A7orr7Kq6myvvPgQejzDKmVz2kHQPSfsWpd9qKDd9S7ypTnf5rXib+olHaQKBQPDj8bp++o6Ub9GP3141dl3Wm469vRPFH97z9eVrp3d8yDwaYXQ/snrlrZxx5Z/zg9VEyjff98QPgRBGAoFA8P7Itxn5jn7vSJ3np+inrGP0BxVGHydCGD0ShDASCAQCwX0IYSQjhNEjQQgjgUAgENyHEEZvIYwSyUtOz5OcxcT2sV6D/eML6Ts8v5D3T84T771OYhPXQLSBD6cNnMaSxC6+32ObeCIlbMXH3AbOZftwnmM33ned3sf2IGGUnvNykUhJjV5sH+c1ODy54CKeIpFMcXRyQSyefO91Epu4BqINfFhtIN0/fB+SSWErPubtIp6UbEUix2687zq9j008SnskiEdpAoFAILgP8ShNRgijR4IQRgKBQCC4DyGMZIQweiQIYSQQCASC+xDCSEYIo0eCEEYCgUAguA8hjB6RMMp6As06zPrhA9XJeec65Po+JeSf//3zSyOEkUAgEPyY/LB24M4SMvmnQ2g81JbJzoJzzr/HaaQQRo9IGKVJpZL5jShXLGUdr2dcumccq986Lh17TWNMx8O52djk9PletK/ctt/huv1WvlIcmZT0Px1XLfuDu84nN0bN/WFGhDASCASCHxfZDtwO1XEzmsLNkCDXx++xB3JiOdbYnWU/LCTITZt0M4+o8Hz98xZG2UYR3VpEq6rB0tjF0kwAe0uf3LAuooz5h6WgfomLc84vZFfoiXjad0MCkmfS8bPLdEBYeYl7mnjsjIuEnFb+DcQZ6LRTXlnP3MIybpeJhZ0L6fjcxAjr++kSkpyeZYO8Xkr70srYyxTR4yiJjKZKHkewmkxsp0+/2Mdt1/LtV9/R0NXPiH+YvZM4XMY5v4iTiJ2TkCpwyclJVFpiKQchvN3qhTASCASCH8XSyP168hRPs4mKagNLy0s4GsyEj9JHkkyOBtmJpu1HnNNzKVq51PefnKb3U8yMB9k6TtuUtH852XakMoHH5aRyn7400kdtdQWtgTk25kbwTcxL75+fnxBPxIlGT66CyB5HT6Rj4wOdzIR3pP2NWS+V5WU0eYJSunRQ17xPIoTRz18YZUdwxts0/NO//ZX1owShQAt//vN3VKuNLK6s0Gq10d3TSGF5FQqdiYC/n6rSCioVKgLTs7Tb7HT1uimpUqDR2lgNL1BXU0l5yQt6pjfkgmIb/Po//pn61nGI71P48iueFVfT7Q3Q1d7EgNeHtqaQiuoqBgNjWE21FFdUY2nrZW58kNKScrqHZpgOdlBZVsyTvz1nPfN1xPcW+O6PzzkFuq1G2tvdKDVKqqvLUSqq0di7Cc+Po64owtodYHVqCGtL/9WwaRYhjAQCgeBH4DLTzx4t8C//+s84+hfhdJ1vv/sLL0sVDASCtLU0MeT1oqouoKK6huDoODptNSWVNbi6emhrbmbQ60VXV0x5jYaZUIT2BhVlxSXU2zquRoi0z/6DP5caSJBEW/RnClR2nJpyTM3NdHW4KC+tITC5zGSgmeKKOry+IK/+8gmajjHp/OPjY443p3jxbQl9/W009o/l2UohjB6BMLpS8pdnmMq/4fPvKhjqb0Vn76K9UU1D1wAOlQaLtRZnYBZfi51nz19hahtmztdFRbUam1aP1abC0NpHp01HRUUB1i4fve4arN7Fq5LC4x388pf/g64BH3V6NV5vPwZ9PSaLhZbmFjQqI2urI5RWFFNcW8d8ZJvaF0/5/Is/UW8wYdQaqCgsZGppGX1NBauy2CdxsETBkxJpVKtRUYnRoMbaMUC7QUlLbzcalYaiZy+pVtZTpVCzlVZQ3B5qFcJIIBAIfiRLkxmlnxt08i+//IRBn49qnZah/m4MBj0Gs4U2dyM6QwMri15KKkooUdcT2lyn8lUB5XU6PK1NaHUGejvb0ak0VNWqWJj2Ua4wXJVzvhvi209/Sbmph6FWE10jY5iqypgNLVD49RdojBaM9fW8+uYJap0Bi9mFw1THyPphJocUxqK/UWkbkF4lE2LE6NEJo2xjXZ4cwONpobq6ggaXDbOrmxanEqenH6uiDmdDPSUKHTqtCpvNQnlpHVqdmsa2Liy1dVhsShzdXhoNKuwuJyq9ibqSr3H4lqT8Lw436evqxKpWYLPaqNUrGRwcoF6rQW8w0NbWQVVpAUajDkeDi+qaUrQmC8p6HXZTPcUVSoJj87Q7lNTW63j57QvCp9kRo3m+/cNz0gOuzqpSdFol9vY+WvUqWnu6qK3V0+y0U15SSqt/nI2Fcdr7R+TPL0aMBAKB4CexM+e7K/R0dWKsraLBaafGUM/QQA/1Oi1avYGOthbKy4ox6uppbGqirLIUg8lMvUGPWqOjxe3GZHDQ0+bE6mjBaKzDVK+mqNKUKemcoe5eWt0WyhUNdLt0qMwNqItLWdzawa4ppUxhZGpmngZ9OcUKHROzq9hrX2LqnpRyCDSW8X//l39mau2Y0EQPHcNz0vtixOgRCaPsDLP46T7DQ/0sb+0ROz1ia/eAg70tdvYPOT06oq9ZSUm9g62jGCvjHl6WqpgNRYjF4+xsbLK7u8XuwRH7+/vshKd5/tXn/OmrbwmuHmULYmV2FP/INPFknEhkk+PoMdtbEXYPo2zOBSl9UYB/YQ1i+1RXPMXdN87+SYxU/JjhQJCdowtIHDMxOspCaJ14dhVB4pxwaE16HrwX2WB7e4u9wyMOdrY4ODpkc3ObxMUFM6MBVndPiB3tEFrfyvv8acSIkUAgEPxIpkb6m2RxcpjgxDzJ5AUbkU2ix0dsb0fYOzphZayPkoJSxla2uDzZoLjkGZ3+WY7Pztjb2Zbty84uB/t7nEYPsShf8vvffYahyXtVzv5mCK83wP5JksTJHtMzs4TD66RD3J1Ht/AHRonGLkme7hAYHuUoluJ4J8z0Ylg6fzs8z+joKDOzK+zurLO6tX9r4nZUTL7+mQujW9y9aussesjRmTzJ7eI8ysGRfC3umsRMKsHW+gpr27tXE6nzSrjjnFQ8xsH+YeaxXoKDg32pId+cKP2ubgQecp4QRgKBQPBTcbtPTl6ccXhwnHkRZ/9gn0RmufNdPfjx3jYrq6uc35ggfXf2Obbke7ikEcLoMQkjaYljQlpGmV3KKPt2uPbnkH6dzJmAJi2TzwwxXvmNuOFfKLfxpd0BJDMNONdf0vXSyPxllunVAPKCskvpOe91muRVPbLlZOt4y0dGtv5SfdP5SWv2xao0gUAgeA/IduC6v87zoSd153JfnWsHrm3F3b728vdT8vlZ25F145J77EY50vs5NiRtCyVb9BrXAlExYvRIhNEbyDq9kvalxnm/2r4tXt5UQL5DrZs+LX4KxIiRQCAQvD9yb8Qf4rhXFjHZm+afBiGMZIQweiQIYSQQCASC+xDC6C2EkfRoKSW2j/kaHJ3GSSTlx2zHp3HiidQHUS+xiWsg2sCH0wbeNFr+JtL9y/v+DGJ792uQSKYkW5H9HtP7j/F6PkgYxZMp6bnjybnYPtZrsHcck77D01h2P/7e6yQ2cQ1EG/hw2kD0PMHZxR0Tfd+CdHQAYSs+4jZwJtuHXLvxvuv0PjbxKO2RIB6lCQQCgeA+xKM0GSGMHglCGAkEAoHgPoQwkhHC6JEghJFAIBAI7kMIIxkhjB4JbxZGOT6eMofy/TFdbwKBQCB4nMLoMuMrT7IHue5uMrbjpq2Qffnd7aMpm99dfpzep60RwugG6S8jkUhkvmD5S8q+n+uL6K7z7jueS9qpV9YJ2NucLzmhlM5NvvXqke8/YpT+MbyF7yaBQCB4xGT7a8mW5Piuu8uxYt556eMPEAWSn6NEui/PCo/LD2rE6FJySHy7TpeXufbrw7zRFsLoIY3vhnPGrJfprKfRm84br7xQZz1Z53i8fqNIuumx9DUOvmTv3Nf1yPWKfZfSvk8YZSLK0dtsxOTs4jSzMCU0PYhBo2NmfZ/NhTHMBgfTa7tX5QsEAoHgYch99LUgyEZLyLclt6MpXHu5vt+xsJxHTiSHTCSGyztsUjYqw9t5vr6U/yVOabZrsbcNSC+nAx10T62ROApj0ipxdQc5O9nHWW+gf2SOvY15lIoaPGMrJI43sRvUDE4tsDQ1hl2vpqbexujUCHplHX3jy5zurKLT6+gOygFu0/X8qRHC6GaE5KMIrc2NzK5ssbG6xFrGjcHZ0S5r69vZxNdXMLMfO94lnBu8VW6DecgvE8wEe2ntHCSWCQMilXsQYWZ2+er83Og52bpFVmdpa2ujvb2d6dWdvGOvi7fzJmGUbXR7S35a+rwMdTTSPbYqvdfRZKWpuZ3m5jacbgtmYxPzWwf55QoEAoHgVn99sLWE2+0mvHVAaHGe3RNZqBzvbLK5fXiVNrcPl/rn3fTxnH72hi3Jho+aHfXhdjUSmFjkeH+TmdV1+XiOR+28cCJ5r+/uv+8TRpcZUbY22Uvr4Ah9bXYCMys0m6sw9k1zmYgRj0WxW/R4PK1896KElZ19Olx2hueX6W1pobvVxauXFUyH5RvsyHyApo5+juJwvhOi3mBloK+XZlcTVlcjmailP3nrEsIoQ3bQRl/6nDKlg83NTVz6Cp6XKAnMhtkNTdPbO8jkxBBmix3fzCLhhXGcFisdvmm2V2fp7R5gcmaYRqeLkbl1TvbCNNgttHh6OJRVEJsTbXz+TQEDQ1McHEcJ9rpp6Z0gNNZFZbWJveMN7PZGVvbO2F6axOlsYCEi/4hSlzHs5c8oqm3k4GCTVqcN32SIlZlxAv4A3uA44aVpBoanb/0oXiuMMo19Y7KbnuA0C/4O2nyyUg/2d+Bq62Ko14Ouwc1U0IfF3ZN3nkAgEAhypxyk/59Q8vUT6m2dbEfW0FS8oFRhYiq8y9qkn0HfCEF/L0aLk8mVNebHhrCbrXinVlmbGcY7OMzIqJcGp5uFjUN2VqdxWM10Dvg5l3txSl88IzgXwlRXjtmm5etXRTR3DXGeggVfH2aHi/3zC+YCPbjcjQTnNknEdnE1OphcOWBrOUj/xFKerXiIMFoYbsE7u8ZorxXv4gHnWxM0eCelY8vjg3j8cxzsb7C0NI/baaSzt48Wt426Gi3B6RAbKwujZ+f1AAAgAElEQVTotSa2zxN4WxpZ2pYDuAd625lc3iE8P0pzo4v2/iFimWDrPzVCGGXIPg6b7Lbw3//h3xlf26HVrMFsc1GrrWegtxubTk9FbQke/ygaRRUlxSU09fix6lRYzFYazWYqVOWY7C4MGg1KVSUtXX2UFj1hVr4BIHmyyV8//Ree1TUSje7jsir4zR+e0NzaidOgp7aqiNLyCuq0Tmw1z/jtZ98xthy5+sL8dh2OliBHBysoSp7wm68VHO6F+dXf/z/Ud0yTPN1hdmntwcIoe5dysb+Cw2nEYrQytrBF8mwft9VMl6cds9VCT6+PzuZGrC1D8mlCGAkEAsEtsvODPMYy/vHf/sTa/h76WgUNDU4UJisDbU04LEYKaioYGh6mprKSoqIyen3DaJRK7CYTbrtVOu50NKDXaqmuraK7t4vnhc/ZlUxVlLryEnp8QQx1tbiaLFQZndjrlTgabShNLsaGOtEYnNRXPMfqcqFWW3BoqyiuqKCwuI6l9TDLmacgDxJGl7KNPN6YxWi1YDGZiZzC1nw/Df559mcH+PppCTNrO2yFF5kaDdLc7GZyap52lwmTu4e1zXUmxwaxuzvY3V3H7GyW8vS5NLyqNrJ3GKW72U5rVw/1Ki07UvH3Pw35MRDCKPulp/+kEkS2wvQ61Tx5WYRer6Nn0I9Sp6CzvQOzVo/GqGZ4Zg6toorKSgX9wWkazfUY9EbsegNKQy2Dw8NoaytRqOvwj0+jqilkISOMjne3WF0Y5dmf/0hlVQ06s5nKagUWs0P68VQUP0dpsNPTH2RuepTqZ1/xXY3z6gvr1VZgdA/icdajs5h5VqhkLTzHZ//631A1B7mMn7KxtZf5UA8QRjk/is3FCWaW17k4O2Hv8JSL4128fV52zy9JnGzj841yepH5Af3IDVMgEAg+PjL9Y/yMjcgqDcpCXlYqUNfr8AW8VOu1eFyN2MxmavVapmanqCmvoKpKxejUDHq1CrNOh9NsosaoYTgwiLKmCkV9PROT45RXlbMrPZE7ofzZE3QNXewcnjE/aKW2sYNelxG1ToXS1sby1CB1aiP6mlr8wQAahQa9opgypZbWdi87+7ts7R09WBjl9vsrc6PMrm5K+2fRffai5xzvhBke9jE8NsvxyRGjgwOEtg9JnR8RGB5m+zgBsUN8g/2Edk4hGWNrT36ktr48S8DvZ2J6hcvkKcODA6ysXz9u/KkRwihD9uKP9TehN5qYXV1nYniQ+aUQQ34vs7NzTAYGUVQ/o6BSx8TiAi2map6+rKLdN8F2eAm/d4ihYS+LyyGGh4MMdjn50x8+5U9PnrGeibhyvDmPVa+lvdvPzlaYJpMeldnB6OgogcA4Gxsz6I1W5jcPWZ0axmw0MzQlz/lJs+jvZXhqle3QBPo6FdZ2DwPdPQRHAnR29TM3GcTjHb01qvM2q9JuPPK++6BAIBAIbneR0t84/W1WjDYnK5sR/GmREFpiIOBnbmqKCX8frwq/pkptYyG8iL6qgKJyNf1Ty2zMTzLs9zMw7GN5aYHg2DhtTg1ffPZbnhRWcyLlf0pfdxeRqNzHRxaDeCfmmR72Mr+5z3S/B63Ryt75GcGeLkLhEAP9w+wfbmCzGBme22Ztzkt7YDbvicnbrkq7fKM5uH0DfnP/dp5ZA/T+GpcQRg9EbjYJgoE+IplJdHPjfhYi0dd+6Xur0zQ6rAyMzWcPvLGcd24Lb8j7IcIovQpCfv/aj8TNVRFCFgkEAsE7d9RyH5qIMuj3kh5ESduV0cAQG0eJO9b2yC/WZgM4HHZGFtbz3r/TdUveyxurzt5UuwcKo9SVrcgs/LlaWZfIrMK+vLUS7q79q5GqK1c0qes0P4D7gXdFCKM7ls+n/RhJSyszS/GTUiO4XgqZSiZI5CyFTO9LPhuk5ZTpL/16qeRNpPSJ9PmJKz8U8Xi2vPTyyWz5l1d1yXMXkGkw2XSJRDKz5D8p1SO3nrkIz9cCgUDw05EWCVlbIouBHFuS6dOzQiKN1N+nRYW0rD+7lP/1tiTXlYskLDLnZcuTbEzav9GVXZDtlGRTMuXcXP4vPF/LCGH0lsi+guT9XAeQdyGPuLyLM8UfHiGMBAKB4EMh4+U5+yrHrtyZOuvn6EeeyiCEkYwQRo8EIYwEAoFAcB9CGMkIYfRIEMJIIBAIBPchhNFbCKN4IsXxaUKalCW2j/Ma7B7FpO/w5CzBnrQff+91Epu4BqINfDhtIN0/nMbuns/yUGLxpLAVH3kb2D2K5dmN912n97E9SBhlo+mK7eO9BmkhlEzJoUaOz+LSJL/3XSexiWsg2sCH1wa+D8JWfNxbejL2cXoFM9d2433X6X1s4lHaI0E8ShMIBALBfYhHaTJCGD0ShDASCAQCwX0IYSQjhNEj4SHCKOtkSwroLDnsuj/PN6XJW46aXm6aSNzK+7488iJPCwQCgeBHRQgjGSGMHglvFxJEUi+SqJEcjWWcgMmOJDP7qbSAkvOQHVteeyyV5hm8yS+H5IzsOj7PtafTa4dkmYM5+WfqI3lWFQgEAsEPiRBGMkIYPYBr51tZQ57vXTo70iKLAdnI5xrv6+M5QiJ9PGfUJHfSo5w+KwSuHXtlBUfmpLw8r5x/vWYC5UOCyEaWxmhr72AnesHJwQZHmRUqN3PLpt/ZDLMXvchWJ+e4VHM2QiucxuUDR5FF2lubWdk55mR/k72Tc/n93d0rt/M3R49ODvY5OJbT8cBRLIFAIHgbbjpXfH3/fnl3/551vpi5sZOOZ2zB7cIyN4053q1zA7hm+3lu3JSS4wE790YyGwkhzc06vP7mN3vjmv5/I2TIW8ZK+7kihNGDuGRna4P94zMuUwnOLzKGPJXg+CiaiaN2HTPm6mXmePLGj+4uYtE9NiK7yO06P45MpgqZt5NEj45I5JVz/cN63U/hdcIoW59oeISSKiWLC1O0tbehUbyiaWiSuZE+OgfGiB7tMdTZgrPLR+zigml/NwWFpfjmwkwOddLjnyG6v0FneztrWzv4e528elHMZgw436C8tITJ+XnaO9vobbOj1ZmZWF4lPLvE1OQYfZ5mBkYWOD/cpLvFzeD4PJFQmInRcYZ6W2j2BEiSJDjQQXNbDwcnt+MKCQQCwduQkSDsRtbZP45xmYxzke3fEzGOotEcAZTf36TyjssrfqW+OOeGN00idsbm2iqhlTCnF7K4uRIzaXGSU5uL09OreGFSd59KEIvF5Cwvk5zFzq/rk427dtPu3OwULy+JnZ9LURj2tjZZ29i8sh933fRGhTASwujeH01GrYcneymrqsLd4mMq0Ex5vYWtoxjJ2CGD/T72j08IL8+xsbdPKhljIxxiYW2HxEWUoQH5+OZaiMjesdQUt8JLrIQ3OY9njPvpNqa6Cmr1JmY3oySPt5lfCUs/mIPdCMsLi+wenko/xMPtdYb6Bzm7vCS8PM/a9lH658XKwiz75wkSZ8fs7Kffy1cNrx8xyvy4Uqf0djZhtbmZXVmnv8PC4MQ0vr421HVKers7sNodtDe34nQ4aekZoKO1lb7gON7uJjQqDT2eZuytPYz0tdDZ58XtNLAuhYJOMjLkwWR0Mrq4QrDLRVO7hxZnA90dfszqSho6PPT2ddNoN9LQ2MlQfxOuxm4adBrMbjcdzQ7a2z109fTTZDIQnN+TOxihjAQCwffo30MjXVRXluPoDTLR00KdxsLu6QXxow36/AGOT04JLcyztX9KKh5jfXWJlc0t4idb9Pv8HJ2esRZaZutQHt3eDIVYWY9wdi737x3GOirVTkZHx9jY2mH3+IiToygHG4uoVEoWduVRdxI7fPbP/w1j34L08uzkgOFOOzUGN+mclkc6KVQoSXvWiawushs9JBwOsbVzKqXf3ggRjhzI++EQa9v7cr4Xexhq6hjob+VlkQK3ox5Tm5dY7Iydg+M8MSWEkYwYMbqH7GOr6V49/+UXv2Z2O8bKsIs/PS+muqKakelJrHoLFlUZlXXVKGs1eDrsfFdahaK2htbefhwmOxZ1GeU15VTV2pgc6aOsspyyZ9/RProq5X95vMJn//JfqXUHuYztYagspbCsGM9QgJqXz2locKI12Oj2uNAZHNgNJoaGelHW1dHUOcCgp5nKoudUGRtZnAri9gzJ+eYECHz9iJH8/3Bjlem5dY63ZtGa7PT1t9LT20GD1UKdsoq2zlb8k2Ms+oLY9Cb6x2YJeLswOxw02i3Uqqrp7GxhdG6B8f4WhmeW6GioJ5z+zZ7sMDoyx8XJFiaLCXeDlZlwmGF3K+1N/Zh1avzTCwS8bVisFnzjc0wMNWE2tdJg0DK4uMS8v5NGRyO+0TnGezoYnd+VvyMhjAQCwTuQflSVZqpdwd//y6+Y37tksc/C01dPKa/SEgwMYrDpUdfWolAoqaq34m13UFRahLJWIY2sm5xGVEoVFWVVKIxOZkcHqCgp59Xzl3jGNqT83epKagythNYinB1voyx5wpfflTI57uOLz/7I2LosbBZHu3j18gVVxpa0W2XU1UXUVpVTV2/B5bRQW11KYa0af5eLlyXl9Pc2UVJaRlW1hcmxHj797b9h9kwSnurls3/7Fab2AUlQEdtBU1ZJZ2cDSudgWnJRU1BKz0Anbb6pPFsnhJGMEEb3kh1NuaC/UcEnn35NR5sFbWsfHruWpu4ejBo9OkUlgZll2hoVlFaXY+4NMjXgoaRCjdlgQauopGvQj0NvRFNdgrt/mP4GNc3DoUwpsD0f4PPf/IYalZavn7zE4nDQ0ulBUVrLUQo6jWX86otvmAstYq6poq6qjI7hZel8xfMnlCuN6E02drNTcm6Mkd43YiQRP2WgsxGz1crk8jYrMz46uj20tLXS3tvL1NQoS+Ewq3MLrK1u0Ndmw9zYxfzUGK5mN50D/UxPjbAY3iZ1vkeD2UBDRwfHUt+TZHSwHbPFxNDEEqtzY4S3d1geG2NmaoUel5aS8jL6xxYJBdspKiimOzDBRmgdX18vS1sRVmfHWdvapMOu5rtvi5jZlDsTIYwEAsH34TKVpNdSxn/8sZAOp5mGti5abBaaml1ozGrqatWML0VwqpVolXU0dfmZHHZRUF6G1magtq6e/iEfWmsdWqWWJs84XTYNbcNhKX+XuopaUyer4XXpdUvtl/ziD1XpGZYUlyvYzgwYGUq/plyp4Zu/PWdkLEhFaQ2hxVGUVRUUVVYyH5pEodPQ09yAq92Ht6GCp6W12CwOJqanqK98wavKeubmp1GVvuJFsZKt9FSG+C7qPGEUo/Tb56xLtiJ/+oUQRjJCGN1DdsRl3t+B1WLBanLS1+3E5vHS5bLiGRzCaXZgUZVSWFGOXudkqK+Br54Xo1SrGBwZwW60YtNp8Q4HcZis+LweyqpKefHlV7SOyCNGJ9sh7GYbOp2RPt8E7UYlCoOF5bVlNJW1pAdEV7w2/vS0lmTqBF1VHRNTAaoqKnC6PYwMdlNbXkL7yCzrMz5srQN59f/B/Ri98dSH5X01iXtthuVteQh4b22WlcjureHdNImzA3pbXXQNjMt3QmJtmkAgeEeyczOnBrqxWCzorW30Nztp8fTT4XLg8XRgaTSjqq6mrKQSlbOdEU8DT18+R6XSMzTYi8FuwGCyEggOo7eaGPEPUF1cxN++/oaOUXnEKN2fV2mcjI6PszgbQKWopbSyGt/EJKqyQnyhEzhdpeDpS+Yie7jrK3G29dPUqKOsuASdtYkuj4vKsiIqdSb8XW04W4c4jExRWlZBU8cw2xvLuCxKXrysIDg1Q6tZw9fPSwinpzIk9zEqlHgH2nhVrKC5wUBj/zhLY104+sakOooRo3yEMHoIqTg7kU15UtplkngiKfnkiWfmCA049LQPTUr76xOdqBs7iSXSE+JSJOIJEvG4NPEtLVNOtucoL3hKUZmC8OH1jP/o/h7bmblBifMoeweHktlPnyvPx06SSMgrCeKZyYFHB/tET9O3BJcc7u9IE/vSkwfPY7dXErxRGF2tUJD/Z30IXS+9z3/v5rG70lz7MbpeTZfujG7nk7nMOenvLvtB35ZAIBA8nFSS7c0I0YuEtJ/I9u+J9HB3nGablr7xFSlpyN+BpaGT81TaFKRtQZxEIiGlT/dw0Y0Zyl48pbBMy8axbB+S8Qv2tiOsb0ak+Urpc5KJGLF4gvj5CdGzC6l/v4hlbvdSccm2JOIxDg4Oiaf7zFSCg/0DzuMpUsmEVMcrG3CSHnK65GBvm5Pz9PuXHOzscJL+PJm+PR6PS33p8cEeWzu7Uj+brkN2IdG1GRCTr9MIYfQArmb532OZs6sDct95XepE/IJYttHeWKae9SF0a1XaVSG365Q7svK2q9I+BHIdOd7v1PFNy1AFAoHgbfuf6/93dj1ydyyvAstZova6fiotaC4yN82vK/C1fdxdffxrxsavV6Vl8rzjvNcV8ro0QhjJCGH0E5MVLz+1V+cPWRgJBALBz4Hrm9OP02u/EEYyQhg9EoQwEggEAsF9CGEkI4TRI0EII4FAIBDchxBGbyGMkqlLzi+SxOJi+1ivwUH0QvoOLxJJDk4uOLtIvPc6iU1cA9EGPqw2cJG42zP/Q0kkU8JWfMRb2kYcRC+4yLEb77tO72N7mDBKXnIWky+a2D7Oa7AfvZC+w2xjP40lPoh6iU1cA9EGPpw2cBH/fsIonkgJW/ERb2kbcZAWQzl2433X6X1s4lHaI0E8ShMIBALBfYhHaTJCGD0ShDASCAQCwX0IYSQjhNEjQQgjgUAgENyHEEYyQhg9Et5NGOU6nsz+//h8cwgEAoHgzQhh9EiFUTpMR9o1uhT2Qgo38UPnf0kqU8YPlGEmr+uwGq8t957jDxFG59FDIpEdchempJJymI5UIs7O1i6JpBBGAoHg8ZHtY9OBq2Xb8UP3hRnP/rn5XoVqko+/q13JDa10bVPuqIEICfI4hdEt8hpJTmwuSTzlxAHLOZ5uuFlhlXpDI0vl5nMrxtjtRivtZ/LN5pGf53WZ6bhjV/nnlnnHD/b1wijjqTW+h16nkwK0nmWUUTy6Rl2xkrXjGHPDPZhNDYyvbN1ZL4FAIHhU3GEb5D48az9e389nhVVe353pi7Ov847l2YSMOMvbUrdsl5Tm9ZXPnHPTvohYaY9KGGUN+eqsj3qNjonZMCN+D/Nb6fDDcBBZZTFj9NOjJFmyoudoK8xCKJL3nryfL2DO9jdpsRmwtA1IEeDTgQbTfqAyifJCgRxvh1lY3sgv8zJ915AJuCrnSF9bCxaDCe/4vPx+MnkVGVr6gaVdKpweMDUyJUedfwthlP5xSKVEpigofEHH4CgnmTA/J3sh9HU2VtbXcDi0WC3NTK/t5H1egUAg+DmT7et2QtOYtWp6J5aZDwwwsSjbg+jOKjOhjVtiJpWSA72e7q8xvbwm55VjO/LDh6T/xzCravCHDq7SRDfn6ewPyKlOIrR4ujiV1JM8spQuI1cwXcWczB3RSkQZ6OxiYX4Co9aAzWpiJFPf2zfeQhg9ImF0ifwEKMbTv3xCqbGL5FkUXc1TnhRU4RkaJzQTpLWthxanlpq6aryBGYZ6XVTUKLF29rM0NUJrazedLgN1ag2+6Q1CU70oaqrRGpwcZsREwFHCp397ycLWEdGdNRr1dTh7h1hbGEerUmPR6RmbCxPo6aK9uYn+wVGW5wOUl1YRmF5hzu9BpdUwFtqW8httM1Ft7obkCbNLK0R31rHrqtE19LO7tYq+opSmwQlmvQ387vffMDo6RHOX/9aP8LUjRpn3Tg93OY3F8Dbr8YytXp030NTJwsI8Nncra4uTKA1Nt/IWCASCnyvJTF9nePU7vq02c3iRpFNbzJMXL2jsCLAyN4zb00mL00FtjYK2wCxzvnYUdRWYHW3MTw/T5OmgtcmNSqGiZ3yF/dAoyhoFCrWFyLFsPKJrU/z6n/6BUnuP9Lq7xUL5i+8o1ziZnAxQV/qMb0qrGBn2oVLWMzk9gdVsoLHVz/72EipFCe7+aQ4ii2jKy3H3B5CkWWyb2qJS2tpski1JHi1TVlrL8HAPLUOTeTf7Qhg9KmF0PTKyOt7OP/3iF3j8U5hNtbT29KPT1NPT3YFWpaW6ooqV8Bw1lUUUVZYytLgqqXitzoJZb6K2qozu3i7qVQYUZYUMT01TVVjA5oVcTup0i5ef/ZLndU6ajXW8KKhEoVTitJpQmzs42JimouQV5WozXk872to6ahV1RM7hZG2Uv37xNfWaGir1HVJ+jtpyHH0rV5/DWVdCZ3CdoUYtKoOB7/74GXX2HsIzflQ1RmnEKBqVR8EeNmIk/z/fj9Db3ILd2cRiOML21qH0/kBjG6GdI+YCA2g1Wjp8c/LnFEFoBQLBIyDbRx6ujvC7f/p7dO3j9NgUuLt70Ct1dHQ0oDLWU1ahZmFlkbqqWuqrSugJTtPVUEd5nQKD3UhphYa+7jbUNiPq8hp6g5OoS4qZTHf+gMdcg8Zio7xcxdrKHKXFVSzMjaGtq6G0SsH07CT1pnqarEacnlF87hqeFldRU1HHwGA3f/r9r6hv8hKa7OMPv/4N9fZOTtMZX+yir66lu9uNxpW+aY6j+PZb5nZPiF/Ebn3W6Fkiz248Rh6JMMoOKZ4yEfTRYlVTValEY6im1+dHo1bh6WhBozagVlTQ0uqmvl5HvU6B1d2KWq3G5WxAo6pHo9AQ8PWgrDPSYKunub2dkhclbGXaz/LkFAFvJ0+/K8ZmsVBaUEyT14e/y0WFplVK891//H+UusfYCHZQp9RjNqpxe3zMjg1RWVCI2mBkcFoWQ6sjHZTW2liYGcE7No631YmlsRWboZ72/mEGmsz87vOv6O3roayokqXwEoGx2VvDpA+ZfL0b2WT/8IRU4oKTU/kHE7+4IJ00GT9nYzN/YrZAIBD83JG7zQSTgTF62yw8LdRgVyrw9A9hUqlpabZRa9RSV62mtcWFQmujxaRE73Bhrldhtump06tRqIwM+7qo0OtpdThwt7RRUljE3H56WGqLbz7/Hba2Lgr+9iX25k7UyipsZgPV1XXU61TYbWaKFZW4bBYauqcIDbv49lUZzR1eVsPLdDjV/P7TLxkYm6PbWc+vfvNH5tL3t8kdal4V095m41WVheWpPirVVkLLMwRmQpnPeH2jHBXC6LEIo+tpNwujA7S0dXN0es5qaI7I7h7LS0tsbW8Tmhmj/OkTrB0DnEajWNTPqdC7WdrYJrq/xcLCEsuLS+xsb7K+uYO3TcNvP/mEZ4V1sjJPzxvaWqHF3czUcvpRWJIxbxcji2FO9reYW5SfM69NT7G5f87Z3hrLq1ucHq7jbmwmvBvlOLJEV08ve6fXSj00OUpLUxOza7tSnoHeFoam19ITi/B1dxGYCkHynOHAINPTk0zNr761MLp63n3naovrlRFipEggEDwmsv3h+twYLncHkYNztlcW2NjeYWV5mY3NDVaXJygreIm5oYvd8yQDxgqKanVML20QPdxibmmRxaUVdrc3CW1uM+918/lvfsMfn5Sxk+7qT3eZGJ2RyjlaX2BxNcL2xgId7Z3Mr25zchChq6OVsfllImurhDbSaipBYKCHsZl1UvFjBns7GJsNEzs7YrCri5HZVblPT56zODPLzs4mfZ0dtHu62Du/5GB9htHF9bzPKITRIxNGDyJ5wcZKmHhGF2xtrnJ4Lg8r5s7vvxIY+5uMjQTZ2Dt8hwnJD0t7O8vrNQxvg3DwKBAIBD88Uk98ecHa2jrn8nxrDiLr7B+d3e7DMy9ix3tMjI6yEt7NsR2Z5frZaQ4/5pf1GlslhNEjFUbpScPpxne9ZD5nCX2mscjH5fTSrP/08ss7lt6/poS8xp3K7ueck116ebW08zJTp8xcqOz+zTrn1i87IfB6P1vu3f41hDASCASC72E7LlMkErJtyK76ul4qf9035/XzObYj1yXLHZnnTIDO2oecfv8yv3/P9vG5tuamLcjaCMkOZc6T3s/YN7Fc//U8OmF0P/l+JXJ9UNyZOt3QEg/1Iv1+EcJIIBAIfiwuX+t36M7UOULnQ0KMGMkIYfRIEMJIIBAIBPchhNFbCKPMSJ7YPuJrcHwavxrZSk++TiZlp2JiE9dAtAHRBnLbwPdBtKWP+xqkbUQ0syotazfed53ex/YgYRRPpDg+TUgXTGwf5zXYPYpJ3+HJWYI9aT/+3uskNnENRBv4cNpAun84jWVmD78jsXhS2IqPvA3sHsXy7Mb7rtP72MSjtEeCeJQmEAgEgvsQj9JkhDB6JAhhJBAIBIL7EMJIRgijR4IQRgKBQCC4DyGMZIQweiQIYSQQCASC7yuMLjNuatJ+kq72kzn7aRcEeWlS0n5C8p+Uukqfm+ZDQwijLFm/ElmHXdnlGa9zyJVz3kN9UaSdRcqN43Ye1y7ZM87CpNnx1+9dOea6J//7PG8LYSQQCD5E0k5wJUOZS9ahbo4j3DchOcLNcXD4fVfY3cpfMuqyc+Cb5b6+rEvp86X7/Xf1d5frGDLrUPIhURZy/Sr9kMIoj5x6fPje/B6OEEb3/QhueA7Nehm99iCaeo136uvjVw6/bjbkPCGW2a4P5nk3va8jya2TtL3GsZgQRgKB4EMnffN4SyTd7GNzPT1LIxW3Ul7nd5VGFhbpc3LzurzZd2f6ZWk3J83tytwWX1JZGZtx3+e4iobw2nNkMZWNtJArqHJtwpVQyqTL3jzn1jnvc2VE3fV1zM/7jcLoMnOjfnFEi0VDm3cCuKDDZsYzugSJKB6XCY9/ktPTIzpcBrxjC6wujGOzGDDaW9iIrNNg0xOc3yRxtkeTQ8fgpBzI9gdXst8DIYyyTSgRZdTvZXF9Xwr6Fzk8lt+OnUhR5V8XvSYpHd/OO37rjiLzd2VmlJ6BITYPsjF0Mj+Oi3POz+UwtLHjHdZ29kmeJ7g4kyPcnx5E8A958Q6NcJQJxnOX0Do/PHntFy2EkUAg+JCQu7BLQgvj+EenyEalTOrrm+UAACAASURBVJOKRVnf3CCytcXu7h7b23u5J+WPVGR2IytzzK1uSsFVZydH2Y1e3Ex6Vy1u1OmOxJn3Lo73GRrwEt6T+9nsDej2RpiDE1lA5N7eSiTPmR0L0tffz8LqTn4ZuWVd7ec+PcjEVTvaZWtvj83QmtSPH+5G2N6X7cWd1ZX+xFlbX+VM0lw5N9lv0B73CaPLlGx7ZvuddAWmGB1sw2JpYGjAh9vdzFB/F8UviljYOWdlvBdLUwsNRgsbp7A17cXc6OHo/Jzw4hiuBhdDg700trbgMDo4SNx59d4bj14YZR+D9TTU8qxcw+joIv0tSr4t1zC1tEl0b52u7kFWlufp7mplcnGd4711+nq66RuZIbq/QXeXl9XQIoMDvUwvb0sia7DXIwmZ/VO5YY12OjE4Opka99EzsgzJE3p7utjcP6PbUkGh2iGlW/U7KTPasVQXo3MPSu/5GxUUqZ1EtnY4Pj5iYniAwNgSqcsEU0P9BOfDhCe6+fpJEUvhFabmV279yIUwEggEH9KIfJqDJR/ffltEU7OHvWiM0HSAobFVTiPjlNZUoFJrcHcOEAyMsb4ZYqC/n4mFdS7jJwz2djLgG2b3VDbk+ue/5P/9fRnHW7P83X/+v2geCROeHWZweI7jo33GA0N4h4LEUrCxNE5Pr5+TeJLVmRHau3tYXDsgfrJFV3cf20fnhOfGGPAGODqX62qrLqBaY8A/s0h0f4vurl72o0eYFMX0zW2zMT3M4Pi8ZOBnxgYZGg0R3Zrkq2+KWQkv8OJpIeHDGPPDvQQX1tKqieG+TvqHp6T8J3299AenuIid4OvvY2ZhjbXQNPryArTNHhR//pQii4celwFLa5CtSJit7R2Wl5ZYXp5hYGCI4ZFhBrx+zqO7lBV8Rb2rh1DkgOTJNp7OXukab69O0+sbZXpqlJnVSOb7uHyzMLqUr8NuaBSXswWHXUNFuZ7l8B6+zmY6eoKMjwSw2hoYGR+nydVAc2s/6bMGO9zMbctibn12EL29ndDSNA6bg87uIeQhACGMPjhhNN1v4e/++y8ZCx8R9BgoUBpQVSvwBf3oNUaUpc+xtzRTr6zDYKim3NiAWafE3tiCxWBDXfkMtVFPncpOR2M9SqON6hffMLAclYYbS54WsrAVY2V0AP/wNO3WWgrLyqis0WPXV6Gwd0n1CAebUDW2Yqsuwtkn/2DG2vU8K1EQnFvl8HAXm/oV//bZUwK+bj79xS8wdARZHe/ixasa1jaW8Y/OSucJYSQQCD5Esn1T4jDEZ//8j1Q3+NgLDVNQWEBxQSVtHa3obTqMFjsNDQ04rG6MxkrKVEZ0qnoc9nrURgcVhX+hdyndx4K7/hs++6oIm1HLX//8FzwjM3galfz7p3/B6XBQXVqJsraGrmCIqUALv/3kN9SZHCiqVJhNSsrrm2g11/CqpIxatZGawuc09k1e1blbV8A//eoLQvtxtmb9fPfH31GiNNLscmCx2agqLaektISOLg+f//pfqbYNsB+Z48XTlzQ2WjE0duLztFBSUEhpdSUWqw2LvYnxiRmGe1xorS7cDjNGo56nBXUsTI9QVlGF26rH5G7HoSzjN599SUWlkt5eL7Waagb9g2iVtZTXVWAwWyksKUClqKOppRtVfTXujg6qKqtQ1dVQUlyKVt+AUVtEbXOQyPIYvpnVvO/jIY/Szo/W6WluRGe04vMP0uFuwWpvYHwpzM7WKp72FswWI70+PzajnqmFJdz2Bkn8bK7Osbg4h8tpQ2fQMRgcxqBRsXqULZ8Pgkc/YpTl7GiPwVYtf/j8G+x2FY6eIRr1dbR2d6Op06KtrWZyaQWrppQqVQ3NgWkGWixU1+kxaA2oK6sYHB5GV6dBW1tOz+gMLk0V3qVDKX9zeSHdUzsczPfx1y++prrkOWW19bR3eumwKTF7hqV0y0N2Ku0ttGlq6BqRR358jbWUal2km+hwm4V6i5WSojL6R2bpsCj58kkRgwNd1FXUS2lOTmRlnosYMRIIBB8OmcdT58esLY7w1eefUqmo5NnLApyudoZ6WqjW1KDW6rFYrZj0DiwWBe1DQWyaasqrS+kdm8WpK6F/SZ72YK57yqvSF/z6k09RaVRUlJdjdDioVShQKrXYGzvoaHSi1dkxGnSYTFpevSqmztTOZLAHpb4R1asn1OjteDo6qCktZ2pdfmx2mUpwcLBPk6aQz78pQFuvw24yoahVY7Uaqa4q47tX5TS6XAxPTONp1PDFV8/wDvZQVq3GoS7hebUFb6uZr74to7O7k7rKQiy98s3v/9/emT41kqR5+r8c2935sF/GZq1tbXds12and6ePqZ7q7qmqrqrMygsSEJeQhA5AQhJIAgQIcSPEIe77voQAcejmWYsICcSRJFl95MH7mEVmEOHh4Ypw+fuTu7+v+02lNA9OE+n38vzZS2qbe4ithHlVZmBqyE+drYF6g412n5u//7v/RGv/GEZTNcHeXgzVlVSaahgeHcZkNtPZ5qHZ4aKs8i2zm1vonv2Jr373O+qsdnqDA9hMr+mYVnqKlEjXyQ+YfH2p/ptLnTAc6GJqaU89Fgp0MrG8x2X6hE6fk9F5ZTgzxUCnh4GpNXKpc1YXt9VrE8e7+H0tanpyZ/S0tzIyt/le56G/NU9eGF3mJ5/NDPgw6I30Dk4wPuKnb3KOwe52xiIRevwBzGU/8Ky0jO7gOMNd9Xz13Usa3F7W1pfp8Prp8nqZWZijsyPI5GgH33z7e/79V79nYlv7Yp0dbOKy2dBXleHoCHO0v4BeX0NfZJPtuQEqjQ612kUX+vEMjjM94MPk7lKvXRhqoys8r+7vL45hrNDxuqqOyMISnXYr1WYXu9trWOpN9PV24Q2E1LTKJLsCIowEQfhUKAzLxLdnsZiqaXJ72I3F8LfasDp6iO4s4enw0Bnoobevn97AIL29PsIzCwS7Ohke8PPdN3/gd199RXg7oeYV8Nno7O+lyeplaKCbzu5umo11vKnS4+/qpm9ojNHBXgZCEbocVl6VlNHRP4Sp5CW//fo3VDoGiW6MoasxMbm4Tnerm+WDwlJZWXrandSYLAxOLBAKuikveUOjq43u7k4ii2sEHFaavN3EYrv4WmzoTY0sr8zR7A2oQsFaUUF4eoH2hjqcwWHiR7uYq8qpb/YRi8dw1tdhc/rZWJvG4Qmqd21vtVBRqiMwMkqHp53taBynqZLe+T2met2Uv9Xha++krauNmbk5Oru6GRsZYnAoTJvbQklZJV3haTaXxtFVGlhY3WMo4CCyk2BnqhNnX+TGyMmHe6Vx3+6jfNQ+nYGzuzx5YVRMLpu505VX+Hu4w8fKniZylid76J/RZtIXe4AVFG98Zx5LXTVOX4BEfoKh+m/eeyCfWvU8uJ6Hd7eaFAubm8evJ9MpngxXngUPeLKJMBIE4VMkd3ntmaVM8H0o/MmVoNqZx2qoxNHee7ONvbetvCef3CVas5kk4LNTbWxgYftEPafE1nmXyc5kCp7GyvU3U6meYfm2+DLv9XVdbs1bWU2XvfYGK/Y+fpcncvExdf/GnO2HxcX1+bwX3YOpHyuMLos8sPNedvn97B2Pu1sOSQVv7CLPwp8bxuCviQijW66PBRfJK/f34jhFhVgS2h+34mxcX38fV7GRlIpRcMO8ui53J46RFhvjulLlbpy/W8YbZRB3fUEQPgMK7WKh3brdnhWHIrl2T7+/r6Hww7O4Lb4+VshH27/PFV6huF3W8rl5ruDufl/5bpT7Vnt820YU3//29VcC6UbsoqLr1R/Ut5/TzXvdvd/t40Ux8268jw/sMfpCEWH0SAqVTOFGAMh7KJy//cX6mEiPkSAIXwrFcdv+vCb2pph46ogw0hBh9EQQYSQIgiA8hAgjDRFGTwQRRoIgCMJDiDD6AGGUyeY4S2Q4T8r2uT6Dw3hSfYcXqQwxdT/90cskmzwDqQOfTh04S2ZIpLToxj+XVCYrtuJzrgMJzVZcFNmNj12mj7E9Shipa4PlZPucn8HJeZpMVhtPj5+nSWc0DwrZ5BlIHZA6UKgDf66HkNK+SH36fJ+B0glycp6+eo/K/scu08fYZCjtiSBDaYIgCMJDyFCahgijJ4III0EQBOEhRBhpiDB6IjxKGKkhBoqDjf2MGxXl8S6UoJRqsLF3JBO3WUEQhL89Iow0RBg9ER4jjLTYrJf3Rji9GXwsdyVslDgiVyJHOX4VwVY7fjs6983Alfn5a1ktyGVxNNXrPC/JZAoBzZQ0WjAz5X9BEAThL4cIoycsjAq9IX+LnomffQ8t8OnfVBhlM+fs7Ee1NEdRkpli8aEJk/eRTZ0TPdIWdbwdea3w5/byFEPhSY4vNOF043NeZjk+PiIjsdYEQRD+IvbmsQEsRRg9YWGkmOjERSK/Vk7R0VyGdOY6HPptZZK7ff6Bipi8OOc8kXy4FEVLftxfyssHjhTWnrmZz+XPEEaFNdn25kcoLa9HCQI/4LOyenDC9MQom7sxDvYOiJ8es3sQ43Bnhf6BEMfnKaJrs3T3DnJwniF5dkCHzYDBOcTF6TaDoQlSl7ASGWF6RVtdeTHUg9XhZSLcj39oknhsn9FQhP39bfoHhziI7tPm1tMWHOMomeX8YIO+3kH2Ti6IbqwyEg4zPz1FeHpJ+6wSrVYQBKHIrlzbl6Jl5G4ce0hAncqSIE9LGBUEwFK4h5rKCrzD04x3tuAJjKrHz/ZXCE0vqvvHsSjniYxay+LHh1qMj8N1Rqa0Ve5Pj2NcJJUej0viR0ecJZJX66QNu+uoNjtwNRjoCmnpleGgTDpNMqUIFEinUmSzGWKxGCllHZtshuOjQ9ROlOQuP37/PSvRU3wNBhaiSbIXp5wlUpqoOzslfnbORfyEi6Ryz5xaXqWH5zKbJpFMf5Aw0nZzDHV34HI2E1rYZH64Dbu9GXO9iar6ZiLTEeyNTlZ3DpmZHFAXyfUHenFZjTQ0NeNt76aj1Udbq4dmazMOpw19bRVtPQFMNZVMbSsL8OZwNBrYPMmyPTtIYDBCn8eGo32E9YUIdpsJq6sNV7MVp6MRX88Qa4sRrEYDrS0dOKxNOByNmGxWGusdrB0qz0O0kSAIT5eCXVsb9fGszE78cJU6i1sVQEfRfc7TcLY9S5OvR/3Rq9iKhBK6JZMikbppK0QYPUFhpKxqrNBa/hv+99evOAcG7WV8+/wHqo0tzIz30tjux2c18Lb8LYb6VrpbzJSUvaaq2sTQQBdNfj/tNjNlb99gtHcyE+qmvKSEH5+VMrer5AhtNT/R2BWmv8WMrdGFzdVAaDREU4MVm62R8GSEJrOZrm4fb9+W4uwYwW8to9Ro40ipp+l9/s8//j3fVzdgq6sksrpLr6Oa333zgm5/C+VVlZSVvqSyopwqSxtz40NUl/6E0RNgZWoYe1vfjS/Mg8IofywZXaRKV4nHrZTXQyjYQnllOTaHG4+vh72dBWqrjezGDwl43ViNldg9HoK9XaysrBNoaMbR0sPO9gqOqhqq9DV42vx093Tj7/Bymr9dm91EaPmIzOECxkobfl+A5bU9RgJtNDaaqa5rxNvrZ21pnp4uL8GuTqz1JhrMdvy+EIsLYXzhScKtfua3Tos/giAIwpOj8IN8I+TiP//dP2D3eaixuFmcClGlK8Nib6PPW8+v/lBCeCRIeXkJFnc/M+EOHMHxG3mIMHqCwqhgQXMXx+j+41/4+o2dLnsdbb392I1W2n0ODG43DbV1TC1t4DOX8/yH5wxOLtDnN/Gq/C1mn4+mWgM9g8PU1xl49ayEwbEl7NUVjG1oc2v8hldUNvgIttkwmM2UGWoZCw9gtDiIhIJ8+/UfsXu7qf7xj1QaLTQ1urHo3tA3s6Venz5coVpXRkXJD/zTP/+e4bFRvI5mdKUl1NToaO4apNNaS1tPEGOtgZ/+9CM6vZmaOjP76mu861H2LmF09Wtjop/gxIq63+d34u3oZGVpHrfdQbBviJHIFKvra0yNDOL1urG73fSNDDA+FmZ7c4PJ0CyLkUFqqmro64swPRHEbHezuLzC6PAAiXx5LqLbeFx2bHYHoclFZkNjbO4fEery4nC20NUeZGhihJ2tVSbGQ/T5PdhdLnp7exgemGNjfZ7huXnmhkJsRBPFr1UQBOHJURA180MeyqsMfPP//onn+gb0b8uZXo7ic5RSabHS3DGI5c0zyvT11NWYiaod7rfcbWQo7ekJI00LXDLc6cfV3ECNsRWvxYC/dxBHvQV/ezMGdyvOugrKq6swGpppsVbyRleBodZEZ3szdU4XDrOVvtAwdbVW2lx2DLW1/Me3PzCxqQwXQYf+BTX2TgY6rOgbnTgaDFSWlvC6yg65E/7lF/+NofUzJjrr+bG0kqGJZVprSglENtXrM9EFSiv0rM6H+ef/8Uu6g35KSl/y+scXVFdX4uoaoN1qoCMYoLbWRqDdS/nrV7SFptiaG8XdOfT4HqMirrzNir4s6pCfuoL19YR1Za5V6tZcq/wNizzRMqRuddNevYdslnT61lytXI70felzWVLp+/MRBEF46hSE0VRPI+a2MINNL/jl8zpmR4PUGuow2VxMjgV5VVJDV1szr8re0jm4wPJkgJaBqRt5iDB6gsLoatjoLMZUZJqjiyzJsxPOLhKcnpxwenpKOn2Gy1BNa88oSlUZbamn3unn6OyCTOqCo3ic05M45+rk6jTrEwG++eorfnhtJD/lhYt4lPnZaabnFrhQ5hOdHrC0uEw8kWYj0surilriSlFyZyzMz3N8nuYifqSu0aKSTROLHani5eQwSjqbYXd9keX1LY5Pjjk9T3AWP+H84oKjo7g6P2l9cZb9eJJsIs5B7OTG532MMFIFT/Ek7qJN+dLcPqaIKCWPu8fvT3/ffYrTFfZvXnt9j7shA9490VwQBOGpkbqIc3x6wWX2ggPVMzjH2soCuzGlZz3H1voGZxfnrC4vEI0nSZ0fcXBcmI5w3fafyuTrJyaMbvGumfmpRIJsVjuXTiZIp7VJ1velVzzZYtEo8bPUO+9RbMRPYlFOzrUhoNx73N/V+912K/iAz1GMRL4WBEH48imEVSn2QLsWPkrv/0PXijB6ssJIDSqYyWgV5qqHQgsyWOhJuR2UUB1Oykd1vt3LoaUvClyYD254OwjizSCH6l4+zXU58iW86tq86knJ53e7Z0VNpwZJzAdHLOqRKUaEkSAIwpfLVW98wS7kA+XeDJpbHLT32t4V53EqPUZPUxg9RUQYCYIgCA8hwkhDhNETQYSRIAiC8BAijD5AGCndbalMjrRsn+0zOD5LkUrnyGRznJylSKazH71MsskzkDrwadUBpX34c1DmZoqt+Hy3VDqr2opMkd342GX6GNujhFEme8l5IqtGepbt83wGsXhKfYeJlLZ/lsh89DLJJs9A6sCnUwfOk1mSqT9PGClGRWzFZ1wHEpp9SBTZjY9dpo+xyVDaE0GG0gRBEISHkKE0DRFGTwQRRoIgCMJDiDDSEGH0RBBhJAiCIDyECCMNEUZPhMcIo6v4R2qMiw8LICkIgiA8AWF0mQ9YfBU48p7gx3kbUlheSov9d32Pq+uK8/uEbM2TEEaFoFbXgRyvo4DeFwzx+rq7AbDekTIf0PHDJi6+vxK8L9/rQF5/mR6jHMlkgkwmv95ZNkMikcivMScIgvDloAXJfXz6QoDfe8/lcmQymXvtSfEySO/OO3cr2O/18YfsxPvOFygEBC4OPHx/fo8L8JjJpFXPNW0/RVYNQpzm4iJBLn88lUySvGdNzaIFotS1OLVnekkymVSX4foUeBLC6DaXueyV8VdQomArlVqJbq1EvFb2M+piqmpqtSIVzisVUT2fKVSuu5VeiVKtfklyyhdJi1ZdiFqt3usqGqkW0VrNO6t9qdT0+exufwkL5SikK7jWFr6UioDSomznPkgYFYo/0t1OU1MjTm8nezsbmE16HC4n7b1j+XSfSrUVBEH4+VwvlK21w9l8+36jjS3a185fr4qgte/FS2/cXLWgcF657mo1hXx+mkBR7MC7l+fI3bBR+fQP2qh7zis26p0PQLMhSvrHCqPLvKG4iG3haqrD1dZLLLaP01CDMxBmd32eVkc9b0r0rG5u0eGx0xoYVMsQbG+ka3JDvX53cZgmRzcHe2s0mKvoHJhgY3kOm81M7+TSjXt9LL5oYVR4uCd7q7gabIwubbI2G2FlR1tk9WhnnY2dwxtpb163yfp29M75ooTqf6n4Nh3eZpp9PUTj2ppp732vmSRbG6uoVbDQg1VQ04UKeLKLz+2i1dNN9Lw433zm6VOGBsZIqHW7+MvJo4VRQeycbk1gavSpeYQGgkxOjqK32Jmfm8Tt7tCUvAgjQRA+awqt5AXtbherebv3vl4ZheOtZcamlq/Sa0NEWprlsV6aHHaGIuvX5/PXxTbnGJtbu/c+hb9jW3PYGxqZW9llYTbEekwr18H2KpsH8VtrZ15fd7izxua+Zs+uRkJufFrlF/UFEyMhNjeWaW1uxul2sbR3/M7ynL5TGGmf53BlDFuzG7+3DZ/Lx/jUIh2OBuajORK7s/j6x1kd66FKX0fX8CTpiziN5nJaxrRn02GrpNbawdLsCE2uFlrsreoC7Dsz/Ric7fmbfdwf4V+0MCoYf+OP/8YrfRMH8SM8dSX86VkJ/eEFlsYH6B8OM9zrx6g30Tu1wkpkCItJj7crzMLYEP2DIULDPVhNNobndzjbWsRSb8DsakeruxmsulcEJpdZmp5kdfuIlekgVbU2tveOGB3uYXF1jaGhYVYWZnE1mPF2DjM74uP//vYPhEZDuJ02nC12lveOiQwHmN0+V2ozJt1rApF1VqdGWd+PsTgxgL7WwOZJir25cYz6En77XSV7e7t4G40MLGwSXZm87uEp+jXwPmF0MN+Po30QSNDqsOHt6kFvNNDb30eLP0jyEYvZCoIgfMoU2ruzrQl+8V//C8auGbXNc5prCY6PMznUR21NHevRM+bDndTW2Tk4O2Mi6OPl999S2djD4f4c9ZYmZtdjal670928LDVyenFM7dsSekbHcTU0Mjq5wGBfG6+/+Zo6dx9bqxGM9S72Y8cMdDZj8fZxnFRySPHiu19TaunkNHaIteZ7vnlTS2hqgelwH/3hGYY6ndTV1zExs87MWIBaQz3tQ2Gmw/30jU4T7mnF3NDA5EqM/fUJ6g0GnC2dnCpNdmqfqhevaW+zU1LnIboWplRnZHpqmK7ROfUzFPd+nb5HGEVXJ2n1ddDfF6SlqYXZlR16WhzM75wy0mFnKZZmNthMMDyLz2FiMXbJ/mI/PTNbbM70UquvwWRyMTEZoq2jk46ObhSLtz0/gsXWRl6qflRr80ULo8u88V8d8fLf//EXdM1s4K+vxuX1Uau30tJgo7WlhfJyHeMzs+irdOhKSugciuCz6Xnz6i3tbT7KKirxeFqps5morqiieyjE6+cvWThSfnhs8NOLnzjIv8WLnUlelprZWhlHV1nO21odg6MjGEz1dLqbMJgaMZvM+DweLA4v/a1G9K4eViMBKnS1lJeVs67UkotVvn9ezmG+jp5tjPG63MT6aoSyUh3lZVWMTo5TqzdSXVpGuU7Hi9JK1vaO2T/QermKu63ePZRWmAB3htNqYyAcxuNqoSfYS42xnkhkAlOTk9OrXilBEITPk4IACNgN1Dc0oNM3cby/xk/fP2d5JUJFtYX9o1Oi2xsEupx8/e9fU2W0UlPXTHiwC5Opkao3P6KrrqJE16TmNWgrQe/uUfe7W8y8fvOGtwYvO3NDlOjMjA91UqfX8+bNCyrKK2lsdFFa8ZyBZa0nSGGyx8Y//OJ/Mr64SZNFh93XiaVOj8PZiNPTQfXr18zMR6jWlfKm4jWByTns+krelFXi6eimtvQZnvY2jIZG6ipe0RsK8/b5j2wpAw3pKPW6agKBVgwtI8oBqv/0JyY3djk8utXb9JAwymnPbnWih+aWVnXaRbBvAG+DDaPdx+nFCS1WlypsjjYitLZ5MNssHKRgbSpA29gyqZM9At4G3pQY6O5uw9vmw2qxEByZYLg/gK3Jy1n+R7gIo78S2vNNsbi8woCnnq9fVGDTG+gZGqauqp4mkxFXiwdTnYHBkWFqavVY6mpoCw7iNhspL3mL292C3mhiZKSfCkMVlvpGekdG1HOLh8odMpgrXhCcXmN9aZHJkT71yzUzOYDeZMRYX4u7xY2uqo5OrxNnexC7yUyrkq+5kW6nBYtrSJ34/PI3/4ufLIF86RMYK14RnN5ka2mWqVAAXY2F6clhamqM6MqrCAS7eVVSibGyktKyKjw9A2rv0dLa1o3K/v7J1/kx8OQpMxMh5tYP1L83lmcYGZ1gX/tZ80ETFQVBED4pCt5PFzv88de/xOJ084evfoe3M0DN2zqi0WVevqlQf1xG+jy8KdWh11ehqzGhr7Hi9zrQ1dioK3tGpamRrr5JNdudiJ9nJbWcnh9RqyvD1dKEztbJ6VaEV2XVBDxN6KpqKCt9Qa3ZxdTEGBUVz5iO5p1cMgnWl+Zpb6zmxU/lGCyV9AyHMOursNrMNHu6sNRUMjI6QG11FXpTLR2DozQYqtQf7U6vn3pdLSOhPmqr6mmw6BkYHUX3qoSd9K0eI4OX+O40b97q2djdZnlr79HCSKFgAjbmI8xuaD/ANxYW2I5qoxyHJ6f5CdSXbK7MsLqvDdklE6fELzQ7okzSjsfP4TLDQmSMtVgC0nHGx8aJHRVsjcwx+qtReLYzo0FszS3qS1qZnmBla4vI5DRz0zOsLU2je/2MakMzy9EY3dZKfnpbRWhihZ21RWZn54lMTbG9uUZkcYnJ7lZ++5t/5bfflbCf72RLnmzT4XNid/k5PM+wvTiC1e7hMKF1Ozqb7AyMzbCxvMD8yjqzkSk2d3YZ6OliYGCQ+ZVdtTu19Pt/o31q/6r8yhyjthYXLrePWCLL5twoTY0txFJwurmAgrYDEQAAAz5JREFUq9lOx2CE83iUbk8zE2v7HG/O0huavlO53u+Vdu1yqQ5li7u+IAhfEvlG7Ty6QW9PWN3fnIkwGhpjPDyhGv2lcD/WxmY2Dw4JB/xYGhws7B6yMtFLo8NFZGmXo/0lXC0+VvdPr7JeCvfQ0NjA0MwOyeNtBsKz6vGJkQAOu4vZtX321mdodvk5ip8yPjbI/nlhqsMlkf4OHM1edqNHzE6HWd3eYToywczcHItz01R8/3v0Di/7uzGajc/5qdLG5MISm6vzzCwsMzM+wdbWGnPzawz46/n1v/6Kb78vQ+0Pyp4xnp9j1OJw4Gpxs3mcZH95lN7I9Zypx3qlXebnOilXqHZEtRf3h3i5czzvHKTOiM3dtTeFYx+bL3oo7bE9SnOzs5xoc5vZXJpnJ3qmnb/nRcejG3R3dzO1tH11/Ka6/bAXW7j2eGeZvpFJbTJ2wdfgrnbhPSf+PHf9vDtnsReF+rd0FQmC8AXyuNb61gTl22fvTGC+m+5nmftCRtkL5iMzeScbWF2cYu809U6nodj2MoEuP3Pru+91HPq57vo5xTbkh9ZyRTai2FZoHtnFAqlo+kZ+/9reXH5StuZJCCPVxf4qjpG2qXEdFNfG4hdUULn5F3qVruiax8QbKsSkKN4v5Fecp/K/ur2zMjwm39zNSvWOmBkS+VoQBKHgqn7dphbaYa3tz8cTyhv2QsyfwvFCG3s7FtDNOEbX8Y6u8st7qV3nfTOG0t04Rjdtzx0Bopb5Ppty+eg4RvfF6ZPI109IGL2P4kr63oBZt3pV/lKoX4xHBmv8OYgwEgRB+IxtVPH+gyZKEVnvCuL7MCKMNEQYPRFEGAmCIAgPIcJIQ4TREyF+Y45R+i/e4yUIgiB83ihDdfGieUXx8/vnGH3pPEoYpTM54ucp1aDK9nk+g6PT1I19pcJ/7DLJJs9A6sCnUweUNuE8eXdtqw8hmc6Krfic68A9tuL0EyjX33qTHiNBEARBEIQ8IowEQRAEQRDyiDASBEEQBEHII8JIEARBEAQhjwgjQRAEQRCEPCKMBEEQBEEQ8ogwEgRBEARByCPCSBAEQRAEIY8II0EQBEEQhDwijARBEARBEND4/4Dthd2L9OcqAAAAAElFTkSuQmCC" alt="">
<img src="data:image/png;base64,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" alt="">
## Additional Info
