ShipHub Authentication
| 1.0 | Danail Deltchev | 06/17/2025 | First Publish |
The purpose of this page is to explain how to authenticate and handle ShipHub integration and creds
API endpoint: /login
Method: POST
Parameters:
usernamepasswordaccount_number
Example:
curl --location 'https://sandbox.shipping.run/partners/login' \
--form 'username="test"' \
--form 'password="test"' \
--form 'account_number="111111"'
Setup should be taken from Courier Service Providers where we should have a dropdown with all working integrations. In this case we need to have ShipHub which will point us to the fields we need filled in - in this case the parameters:
- Username - plain text
- Password - password protected field
- Account number - plain text
Mapping of parameters is self explanatory 🙂
Successful Response should return an AccessToken which is to be used on every other call and the Expiration time in ExpiresIn
Success response example:
"status": 200,
"data": {
"AccessToken": "qwieuo12iu3o1j2ej12iej...",
"ExpiresIn": 1200,
"TokenType": "Bearer"
Error response example:
"status": 401,
"message": "Login Failed. Please check your username, password, account_number or contact support."
