Hemi UI / Hemi 3 0 UI - Functional Scope and Wireframes / Do Not Read / View Single Product (1)
General Flow
Note: Below picture shows general flow of product view. Most of WF and its fields are the same as WFs and fields described into “Create new- Product“ section. As a subsection will be described only the WFs in which we have differences; The main difference between View & Create WFs is that users will not be able to edit/fill the separate fields in View mode . And also, we will not have “Finish“ & “Complete“ buttons visualized.
“Summary“ section
This section will be visible only when user has chosen to view the product. At this stage we have agreed from this section user will be able to perform actions from summary page. (Actions like update price, stock, zero stock update, etc.)
As shown, this page will give main information to users regarding the products and its listings.
We will have a counter for components and listings. Also, we will have visual indicator regarding the product status on each MP ( green circle means that the listing is active, grey means the listing is inactive, and the exclamation mark is showing us an error has occurred)
“Listing“ section
As visualized, the button “Add new listing“ will be disabled;
TBA: Fields that we need to be shown into rows;
Users would be able to see additional information for the products via clicking on the row ( i.e. on-clicking somewhere on the row, the row should expand and show additional information)
Into this section, user will see all created listings. Into each listing we will have following options:
Via clicking on this icon, listing information should be opened in view mode;
Via clicking on this icon, listing information should be opened in edit mode;
Via clicking on this icon, users would be able to perform actions like Update Price, Quantity,List/Update the whole item, Zero stock update, Delisting, Delete; (TBA: Others will be added soon)
