Hemi UI / Diatleslinqn (TBD) (WIP) / CRUD (Create, Read, Update, Delete) / Form Fields / Field Types / List Field
List Field
View:
Standard view of a text. Showing the label of the value. In the case of Multiple options all value labels are displayed separated by a comma.
Form:
select type
Default Validators:
List Validator
Options:
MultipleOptions (custom option that allows for more then value to be selected from the list)
